Ring. Activation sound
Re: Activation of the Rings sound
Post by ЛИЛИЯ-Р » Mon Sep 12, 2016 17:17
Mickle https://www.youtube.com/watch?v=VGAyw907LJU activation of bells. All have been invented and the Internet-a lot of different tools. It's simple. Nothing secret . And tuning forks have been working on and trigger and rings and pour and SP for them. Each pile the frequency.
https://yandex.ru/video/search?filmId=L ... ath=wizard
On this page, just a lot of different kinds of methods of activation. Thousands of years kolachalama cleaned okrono with bell, set up to do good , to fight , and of course "abused" for good government))))
Мицкле
Post by Мицкле » Mon Sep 12, 2016 17:50
LILY, what is SP?
Post by ЛИЛИЯ-Р » Mon Sep 12, 2016 17:53
Post by Шалтай Балтай » Mon Sep 12, 2016 18:14
Мицкле wrote:Inside the bell hanging of the so-called "language" ( the bronze(?) stick with a balloon on the end ), and the stroke is made.
I know, thank you. :)
But if I understand You correctly, You are trying to incorporate the bell in the bell to get binreloc:
Мицкле wrote: Speaking of bells.. If you not configure the product and the language in which the bell beating?..
If you take a binaural stereo recording, one channel - one frequency, the other - the other of two frequencies to form the desired effect.
it doesn't work, I assure You. Otherwise all was crazy from the bell chime, or from any string or stringed instrument :) You will receive a polyphony of sounds, binaurally - no. This is done differently.
Post by Шалтай Балтай » Mon Sep 12, 2016 18:21
ЛИЛИЯ-Р wrote:over the Millennia kolachalama cleaned
live for thousands of years? :shock:
http://www.kolokola.com/archives/3287
the oldest bell is the bell of the fourteenth century,
Read more: http://www.kolokola.com/archives/3287
Мицкле
Post by Мицкле » Mon Sep 12, 2016 19:06
I know that You know :)
uh... Not - binaurally is probably a bad analogy, a parallel came to mind.
Humpty **All you need to do is to make the product vibrate on the right frequency.
In General, there are, for example, prepared the Ark VAK with its unique fixed frequency sound when you hit it. Is a dozen sticks-duralock, slightly (or not slightly) different weight, and therefore give different frequency sound at impact. One of them is selected (or multiple) appropriate to that Aku-waku stick to create the desired frequency. Type have a customized set - "Language - Aku-wack" with a specified frequency of activation. az "Then, it would have been fun, then a b is good!" ))
Post by Шалтай Балтай » Mon Sep 12, 2016 22:23
Мицкле wrote:And there are a dozen sticks-duralock, slightly (or not slightly) different weight, and therefore give different frequency sound at impact
Yes? interesting... 8)
Мицкле
Post by Мицкле » Tue Sep 13, 2016 6:01
yeah ) .. And "languages" can be, can also be of certain measurements made, inserted in some kind of "taped". The depth of insertion, in theory, can influence the adjustment of sound frequency.. I Have now no opportunity to stir up trouble, but I'm not an experimenter in fact - so, "pagaliau" as proletaria thoughts (hopefully the topic). :oops:
Мицкле
Post by Мицкле » Sun Oct 02, 2016 15:10
Solfeggio ascension Frequencies ( text + download link ) - http://z-yanson.livejournal.com/16392.html .
( "Anima Sound Medicine" 320 kbps is and Vkontakte )
Post by Шалтай Балтай » Fri Oct 14, 2016 11:27
I come to the conclusion that like it or not, and Dominanta the vibration frequency of the product, whether the Node Ring is solely determined by the resonant frequency of the product. I'm talking only about sound frequency. Those vibrations (sound) that serves the product from the outside (music) most are nothing more than a modulating. It's the same makes sense, of course.
On the other hand, "forcing" the product sound vibrations, the theme creane interesting, but at the same time is not relevant, oddly enough on tech. moment. The trick is that the device of such power do not really need. Even on its own actually, and passive - enough. :? No, I activate the product from time to time, but it's so ... porrazzo. Real tasks and not particularly. Except that folding.
Maybe it makes sense to archiveroot for now.... 8)
Малика
Post by Малика » Fri Oct 14, 2016 13:53
Good day, Humpty!
I've noticed that the day was to activate the harmonizer, and the goals are faster achieved. Have noticed (but it may not be related) my instruments from other manufacturers also began to work harder. It could also be due to the fact that over time you get used to the vibrations and cease to feel-to notice, and then something new gives rise to a new perception of what was..
And kuwaki and kadutu use all the same without the activation, working very good, happy)))
Post by Шалтай Балтай » Thu Nov 10, 2016 12:12
I gathered together then one device, but he needed a session. The data is spread almost by itself, well maybe someone ischo useful
Sorsa: http://greatdreams.com/hertz.htm
NOTES AND FREQUENCIES OF THE ORGANS OF THE BODY
Code: Select all
adrenals | 492.8 | B
bladder | 352 | F
blood | 321.9 | E
bone | 418.3 | Ab
brain | 315.8 | Eb
colon | 176 | F
fat_cells | 295.8 | C#
gall_bladder | 164.3 | E
intestines | 281. | C#
kidney | 319.88 | Eb
liver | 317.83 | Eb
lungs | 220 | A
muscles | 324 | E
pancreas | 117.3 | C#
stomach | 110 | A
CHAKRA ENERGY CENTERS OF OUR BODIES
Code: Select all
crown | 480 | B
diaphragm | 315 | D#
heart | 341 | F
polarity | 288 | D
psychic_center | 416 | Ab
root | 256 | C
solar_plexus | 320 | Eb
third_eye | 448 | A
throat | 384 | G
thymus | 352 | F#
transpersonal | 273 | C#
unknown | 293 | D_
unknown | 372 | G#
unknown | 410 | Ab
unknown | 445 | Bb
MINERAL NUTRIANTS FOR OUR BODIES
Code: Select all
calcium | 320 | E_
chromium | 384 | G#
copper | 464 | Bb
iodine | 424 | Ab
iron | 416 | Ab
manganese | 400 | G#
molybdenum | 336 | F
phosphorus | 480 | B
potassium | 304 | D#
selenium | 272 | C#
zinc | 480 | B
actually - it's simple. I like the theme in a parallel branch about the rife machine. The main problem is the presence of the carrier, so that vibration into the body. This is the main problem on which zapperi Clark - poorly functional.
BUT
there are also rings and nodes. Sacred Measure gives 144 MHz-type of vibration. All you need to do is just to otmobilizovat this "carrier" respectively. frequency.
I'll post a video later.<
Post by Шалтай Балтай » Thu Nov 10, 2016 12:54
2 LILY
speaking of tuning forks - http://www.toolsforwellness.com/85166.html
it turns out we are not the pioneers :)
Post by Шалтай Балтай » Fri Nov 11, 2016 1:35
Kuvak of the bronze Pigtails, Sacral (144) Measurements 3.5 Size
Perhaps it makes sense to call this mount:
Mount platform
Post by Шалтай Балтай » Fri Nov 11, 2016 1:36
Kuvak Copper Rod Ф5мм, Sacral (144Мгц) Measurements 3.5 Size
Creperie on the web.
Similar products (with mounting either on the platform or on the web) on sale at the moment, not planned. These materials are laid exclusively from the research point of view.
Post by Шалтай Балтай » Fri Nov 11, 2016 1:37
Warning.
In General, and Vlad N in particular.
If you think that You are so sensitive and experience discomfort from the contemplation of pictures of products from copper wire, I would NOT recommend You this video for viewing.
I respect You and Your opinion, but just warning you that I will NOT remove any photo/video/audio materials from the site. I was sorry to lose You as a friend, but Safety is our FSE, and if there is even the slightest suspicion of an uncomfortable perception of these materials I recommend to refuse from further viewing branches as a whole.
Good luck, Humpty.
For those who have products Slimowski the cause discofort sensations post:
[youtube]http://www.youtube.com/watch?v=iYYrsvlcJNA[/youtube]
A couple of moments on video
  • Somehow, I twice called the Knot of braids brass. I got excited. :oops: This bronze.
  • Perhaps it makes sense to divide the mounting platform and mount on the web
  • I'm in the end of the video said that several sessions were empty. It is not, I checked - everything works. The fact that Sessi low frequency (100 + Hz) are too quiet.
Used in the video session:
Code: Select all
adrenals | adrenals | 492.8 | B
bladder | urinary bladder | 352 | F
blood | blood | 321.9 | E
bone | bone | 418.3 | Ab
brain | brain | 315.8 | Eb
colon | large intestine | 176 | F
fat_cells | fat cells | 295.8 | C#
gall_bladder | gallbladder | 164.3 | E
intestines | bowels | 281. | C#
kidney | kidney | 319.88 | Eb
liver | liver | 317.83 | Eb
lungs | lungs | 220 | A
muscles | muscle | 324 | E
pancreas | pancreas | 117.3 | C#
stomach | stomach | 110 | A
Малика
Post by Малика » Fri Nov 11, 2016 14:14
Good day, Humpty!
Looked at the first photo and was surprised unusual perception, do not see color but see the vibration of bronze kuwaki, this is very unusual, hard to describe.. When it came to watching videos, it seems understood that he saw the residual effects from activating, and probably this could be. To view the video: first felt in different parts of the body something similar to a massage, and started with the chest, in the tenth minute sharply worn out and a little nose in the keyboard is not touched, half asleep I waited for the end of the session, will now go take a NAP, very sleepy. Nice condition. Thank you.
PS On kuwako that on a stick, what sort of color do not see, will look again later.
Post by Шалтай Балтай » Fri Nov 11, 2016 15:40
Malika Thank you for your review!
Малика wrote:in the tenth minute sharply worn out and a little nose in the keyboard is not touched
similarly
when replayed session - almost got knocked out.
I chase a few days at 15-20 seconds per session, a total of 5 min a day. And then almost 15. :roll:
Влад Н.
Post by Влад Н. » Thu Nov 17, 2016 14:06
Humpty, I'm good to Rings and other products on this basis!
The technologies You are promoting here is very powerful. They can change people in a very short time. Just those changes that have been happening to me, I did not expect. I myself, to be honest pain in the arse, due to the fact that I have a high tactile sensitivity and all things moving on this site for me is very powerful!!! The questions that I asked, I asked only to find out, is incomprehensible to me me things. And I have already found the answers to your questions, just didn't want to advertise. Humpty, thanks for the warning about the power of this video until I press the play button :)
Post by Шалтай Балтай » Thu Nov 24, 2016 11:40
Малика wrote:PS On kuwako that on a stick, what sort of color do not see, will look again later.
Malika
I have one thought. Here's a wonderful product "on a stick" (smile :) ), you'll be "intelligence and wit"(C) Pizzolongo :) . And I have a suspicion that it differs greatly. :)
You can try to look for product how would wider? I'll try to explain. I guess that the aura/glow products simply go beyond the photo. I will try to perefotografirovat product with greater, you know the distance in order to "capture" the aura.
Brown in one video, talking about the ring in size 3.5, Tauricheskoy Measurements, shows some metroi area. It is possible here is the place to be something similar. Glow products wider and just got to the photo size.
If You get to review products based on the above I would be very grateful for your feedback.
Thank you in advance
Humpty
Малика
Post by Малика » Thu Nov 24, 2016 13:51
Humpty, I will also be interesting to look from another angle))), because the luminescence was not able to see..
Post by Шалтай Балтай » Thu Nov 24, 2016 15:12
approx. will do. The product really looks "naked". IMHO the aura around 50-70cm.
"About how many to us of discoveries C adnych"maybe cudn's. :)
Post by Шалтай Балтай » Wed Nov 30, 2016 0:53
Шалтай Балтай wrote:approx. will do.
