Card sleep Monitoring
Re: Map Control sleep
Post by Михаил_ » Sat May 28, 2016 2:16
Of positive news to get on the first seminar will become a lot easier despite the filter, only it will be WITHOUT a second to start.
Строитель
Has thanked: 6 times
Post by Строитель » Sat May 28, 2016 11:26
Ready to sign up.
And .... But what about summer session? It is not cancelled??????
Thank you!
PS I Apologize that in this thread :oops:
don't want to interrupt the logical chain
Post by Михаил_ » Sun May 29, 2016 17:14
Well to register I all so need to add fundamental/descriptive texts.... so to speak the boundary conditions, etc., and ask all operators to approximate your schedule to provide the information because everyone has their ... trips and other stuff. T/e/ in General, you've got to understand that the recording session is not instantaneous and a period of weeks to months as the workload of the operators.
Summer session (Seminary?) ? well, until canceled and is not assigned. there is little wanting and still using the same filter who weren't before. I wrote about it. Well, it took more than 70 people free seminars and more - are paid. And they balance very low, those who changed really. BJ on the same base (including handmade) people changed a lot more... well there is the effectiveness of the application of personal time and effort. I want to hold such things for those who are really ready in terms of not only interesting information he wants to hear :)
If 15+ people wanting it is not enough. There is still time, let's see.... I'd better get to large groups of seminarians can confirm for the participants in order of effectiveness, because things are built on the principles of mutual training and that different participants give the fact that for example working individually with one or two or even 5-10 seminarians not to.
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Post by Иван Славов » Wed Jun 01, 2016 11:55
Last night found that there are several threads sleep at the same time /in other words - different dreams 'one and the same time' if we can say in common language, though I concepts clock frequency, amplitude, etc. are confused, so I don't use/. Sort you dream multiple dreams in one and the same time', and realize that despite the realization, again, take all these dreams.
Wrote all this above, so that those who are actively working with the map control sleep paid /if awareness of this is important, in the sense - in one of the threads you can get some external influence, but it's sort of possible to pass unnoticed by the consciousness. Well, if the card account for such a thing - then everything is OK.
Post by Михаил_ » Wed Jun 01, 2016 14:10
The card should be purely do not care, she censors dreams, regardless of the number/parallelism/nesting and is triggered in any case. Although theoretically the resource is not unlimited of course.
Артем север
Has thanked: 141 times
Been thanked: 29 times
Post by Артем север » Fri Jul 08, 2016 19:01
The card works strictly on the body, under the pillow, put a few nights on the back of the bed (height meter), it had no effect.
Post by Михаил_ » Sat Jul 09, 2016 17:43
The card works even remotely. Although near is stronger, it is a feature of virtually all products. You can even "assign" owners card (relatives etc), for example, I did.
It is highly likely that either at a distance of 1m lacks a little power, or You have set a "switch" - it is quite possible to configure virtually all of my products.
Тимоша
Has thanked: 21 times
Been thanked: 5 times
Post by Тимоша » Tue Jul 26, 2016 1:20
The card will be able to protect from astral killers of the average level of the attackers in sleep, when people maleosan?
Post by Михаил_ » Tue Jul 26, 2016 12:58
There is such a thing - syndrome astral wars (sleep too), when the man pulled up the CDA thinks that he needed someone and go wet/to conjure/to curse and so on. When dwelling on the idea itself, the man begins to inflate the bubble with her due to his own energy and their own fears to feed her (the idea), what reinforces the "symptoms" of apparent activity against him and so on the rise. It is just a philosophical remark. There are different cases.
In fact. The map was described in some detail on the webinar. Its meaning is not so much astral protection, and preventing a much more effective action than punching someone in the forehead - namely modulation to the man himself gets in your forehead :) in dreams and in reality - t/e programming. She's not perfect (like any tool), but quite effective.
I quite funny and interesting to see this example on itself, tracking how the plane roll down the attempts of external-party actions in sleep.
Theoretically it would be possible to try at all to block some of the SSS symptoms, but it was not correct - good training.
T/e card trying to attempt direct manipulation of the dream space for You sewing ideas/experiences/fears, supposedly private incentives and so on - block or on their own or awakening You.
Many have confirmed this is its effectiveness.
It is not super-perfect efficiency - it would be much more complicated and harder to do + it would cost like a chimney, but not like this map.
BUT their work performs well.
In terms of protection from unwanted astral visitors is a good translation:
stop magic
cloud (club)
PC+ (composed of several but in fact works in the right way and allowed to remove existing serious breakouts cocoon with leaks)
bracelets and translation 3.0 (from a homemade version) and executor.
very effective stream NETWORK.
You can use I2 (not yet entered into General circulation) sessional emitter. Through a few people and that Wade may again THEMSELVES if the door will not open.
But usually it is all many people need :) the plan You described. Because see the top of the message.<
Джейсон
Been thanked: 27 times
Post by Джейсон » Tue Jul 26, 2016 14:23
Михаил_ wrote: Theoretically it would be possible to try at all to block some of the SSS symptoms, but it was not correct - good training.
Yes, I clean almost no cards blocked such dreams. Ie, when sleep starts with a prepared script, the subconscious quite correctly this chip flogs and makes me out of it. Then I blocked and blocked and as a result sit for a week without dreams. Need to unlock to start.
As a variant of the problem of connections in humans. In my opinion, all that concerns the dreams, and VTP is the effect of the bindings. For those who work with various Pantheons, such problems do not arise (if not polluted of course), since the binding is enough high frequency work, there is already outputs are not exactly "the Astral", but it's the lyrics. The COP in General in the list you want to add an important tool, little discussion unfortunately in the last time.
Post by Михаил_ » Wed Jul 27, 2016 22:28
Well, the fact of the matter is that full lock is best and best option :)
Conditionally can say that there is the phenomenon of "ecologicheski" what is happening in dreams. It is wide in variety, for most of the population can't control the dream and do not know how OS and so on. So a lot of interested parties who want/can/and trying to use it as a hole in their interests.
But the output from the process does not exit :) better to stay in the niche but to limit the attempts of manipulation.... and other ecologicheski. For which the card was done.
Джейсон
Post by Джейсон » Wed Jul 27, 2016 23:58
Михаил_ wrote: It is wide in variety, for most of the population can't control the dream and do not know how OS and so on.
As I understand the situation, those who have experience Havo even more interesting, they can lure in more "labor-intensive" processes. A farm in my opinion is voluntary, so you need to try to avoid a "suggestion service".
Михаил_ wrote: But the output from the process does not exit :) better to stay in the niche but to limit the attempts of manipulation.... and other ecologicheski. For which the card was done.
Well when the cone was filled by someone else and you took it. By the way there is not developed any more maps with the settings to greener worlds? Demand that it is formed good in my opinion in this direction. Designer of dreams, with different settings and paging.
Владмосква
Been thanked: 7 times
Post by Владмосква » Thu Jul 28, 2016 9:34
Had a dream that near my house there is one noticeable nastroennogo buildings and cell phones haven't been invented yet. Just a thought, you need to contact Misha, "Ahhh! I skidded in parallel, help to get out!"; but if mobile phones there? :) Oh, we got the COP to buy, in order to avoid such "cartoons"...
Post by Михаил_ » Thu Jul 28, 2016 13:07
There are many people who dream like, and it should not be interpreted unambiguously, and usually nothing terrible, everything is last to Wake up :) and it even usually comes :) and the COP seems to have nothing to do with :)
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Thu Jul 28, 2016 15:41
The effectiveness of card to confirm :) Thing powerful. Allows you to form some notion of how freaked out a lot of interested parties :evil: Comes to the ridiculous )))) did Not work one time to another, the scheme of the changes, but as far as I've noticed the same stupid. Sometimes I don't, so like sleep, but sleep does not fail, fully aware of myself lying in bed.
Артем север
Post by Артем север » Thu Jul 28, 2016 22:24
Vigor after sleep ,a lot more with this card.
Post by Михаил_ » Thu Jul 28, 2016 22:36
To You, by the way got two Исн2 and two position W2?, the office seems to have been transferred with the recipient in your direction, as requested.
Post by Михаил_ » Thu Jul 28, 2016 22:37
Воффка wrote:Effectiveness of card to confirm :) Thing powerful. Allows you to form some notion of how freaked out a lot of interested parties :evil: Comes to the ridiculous )))) did Not work one time to another, the scheme of the changes, but as far as I've noticed the same stupid. Sometimes I don't, so like sleep, but sleep does not fail, fully aware of myself lying in bed.
As I understand it (this is also partially explained in the 7-8-9 topics on practical examples of mechanisms), often it is at the programme level, wide capture, and the program tries to "lies" to certain images/scenarios/situation, t/e/ hollowed fairly primitive in all the cracks. Individual work often looks different, although often also quite funny.
Post by Воффка » Fri Jul 29, 2016 11:08
Михаил_ wrote:Individual work often looks different
Well, there was the case of negotiations talking. The type that come on now on a mutually beneficial basis, etc. etc.. nevertheless, the transparency of conditions and did not smell.
Post by Михаил_ » Fri Jul 29, 2016 14:19
Yeah, we saw such "negotiations" :)
Post by Воффка » Fri Jul 29, 2016 23:52
Yes. I immediately realized that this is nonsense.
Грифон
Has thanked: 41 times
Been thanked: 3 times
Post by Грифон » Fri Sep 09, 2016 18:53
In the month of June gained map Control sleep. In the evening before bed put it under your pillow. Woke up at 7 am. I don't remember when my head was so clear,clean and easy.Dreams are bad,but a few days had remembered.
Some hangar,I and a couple of people(faces are blurred). I was contacted by a man, and throws me in the cellophane bag with marijuana. Tells you to sling. At first I was taken aback :shock: after all the nonsense push is BAD :evil: And I said no. The man is very didn't ponrvilos, came up to me and said I was to even ask no one is going.supposedly going to sell and that's it. I said nothing ,but mentally thought that still won't do it.The dream immediately stopped and I woke up.
Just remember a webinar where Michael talked about the sleep Monitoring.Where it was told about the red blinking light above the exit bi
Post by Михаил_ » Fri Sep 09, 2016 20:24
It's funny what people will come up to your hands and increase "theragnostic"...
Грифон
Post by Грифон » Fri Sep 09, 2016 20:39
Dreams as I rarely remember,and remember :oops: But if you remember that very purpose(essence) of sleep.
Грифон
Post by Грифон » Fri Sep 09, 2016 20:42
But the map is not true :)
