U-system.
нева
Has thanked: 21 times
Been thanked: 90 times
Re: U-system.
Post by нева » Fri Dec 04, 2015 12:44
passing
Here too namedetails something about Ohm's law. The voltage between ionosphere and earth's surface 300-350 kV. In this field, man walks as a guide and either skips a lot or a little. The amperage is the work (abdomen)- warrior, Priest is the chest(heart)-resistance head(sage)- respectively the voltage. To adjust the balance between sophistication and work resistance. Resistance is governed by the stiffness of the nervous system in the chest area. Really.. have much offended person( nerves tightened in his chest) to the head in the middle of what is going on, and if strong offend, even to work does not can. (is not current) this is Probably why U not closed at the top.)
People who are too greatly increase the resistance begin chronically cuculiza, or even Brokeback.. And when the current is normal the back straight.
раданов
Has thanked: 76 times
Been thanked: 72 times
Re: U-system.
Post by раданов » Fri Dec 04, 2015 16:15
u-system at first seemed simple, the deeper I meditate on it the more open
раданов
Re: U-system.
Post by раданов » Fri Dec 04, 2015 16:16
Nevainteresting view as the water pressure and flap want was the pressure just get the damper and if the damper is closed is not much strain energy does not flow
Корвин
Has thanked: 2 times
Been thanked: 55 times
Re: U-system.
Post by Корвин » Fri Dec 04, 2015 17:58
нева wrote:Here too namedetails something about Ohm's law
You can also guess why you were namedetails this way ( despite the fact that respectively fact) U immediately conjures up the classic image of the magnet, respectively, blue and red halves and U by itself means the voltage in the SI system this is all as a push in a certain direction + should go beyond the image of the magnet itself carries the attraction, repulsion and their unity , as well U like the two hands and between bioelectricity as a magnet similar feelings ( and to disperse does not converge interferes)
Милая
Has thanked: 257 times
Been thanked: 259 times
Re: U-system.
Post by Милая » Sat Dec 05, 2015 17:33
There is an assumption that the axis is the purpose of the development/movement/process
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Re: U-system.
Post by Иван Славов » Sun Dec 06, 2015 17:08
IDA, Pingala and sushumna. During the day the 'power' of IDA and Pingala changes /in accordance with certain practice based on the breath can be uravnoveshivanie/.
In a similar way /not necessarily associated with circadian rhythms/ the power of the manifestations of the three main archetypes in man is also changing?
Корвин
Re: U-system.
Post by Корвин » Mon Dec 07, 2015 13:51
Here is more from the position of the assemblage point may depend at different times of the day it is displaced from this relationship to what is happening may be different in the morning more fun, better in the evening towards the bottom ( saying - tomorrow is another day just about it) for perceiving a different situation and the relationship type reaction select different
раданов
Re: U-system.
Post by раданов » Tue Dec 08, 2015 16:05
the wife constantly complains that I'm losing every little thing recently the only mailbox key lost .yesterday promised a keychain to hang ,not to lose . look what wearing . first saw ,the evening theme was read ,the keys beside the laptop lay as much as the shock hit :
СтаниФилмТВ
Has thanked: 24 times
Been thanked: 63 times
Re: U-system.
Post by СтаниФилмТВ » Tue Dec 08, 2015 20:02
radanov
If You, Igor or Ilya name, what is the first letter of Your name.)
Aura
Has thanked: 22 times
Been thanked: 1124 times
Re: U-system.
Post by Aura » Wed Dec 09, 2015 17:41
Do not give comments about the "Bang" of information about the u-system character in the volume, because what matters is not how true or accurate the information, what it is, i.e. the brain works.
раданов
Re: U-system.
Post by раданов » Wed Dec 09, 2015 21:26
[qoute="Sterifilt"]If You, Igor or Ilya name[/quote]
no letter And no name nor in the names
ЛакиФокс
Has thanked: 4 times
Been thanked: 4 times
Re: U-system.
Post by ЛакиФокс » Thu Dec 10, 2015 1:32
Stonefelt, you ...must... not romantic.... how is everything at once so...pragmatic....)
Корвин
Re: U-system.
Post by Корвин » Thu Dec 10, 2015 16:43
Probably he just comes from a female pragmaticaly, + possible foresight that the husband in which case his name is not forgotten and this leads remembered everything else. On the other hand we can say that the woman showed properties women as incomprehensible beings thus confirming Radanova membership in the club system
Корвин
Re: U-system.
Post by Корвин » Thu Dec 10, 2015 16:51
U-system is associated from the word universal that it is effective and correct regardless of the level of the agent and the specific relationship of study components the operator moves to the next level with respect to the vertical development
раданов
Re: U-system.
Post by раданов » Thu Dec 10, 2015 22:43
if you long to pull the letter U in the English pronunciation very similar to OOOOM
Корвин
Re: U-system.
Post by Корвин » Thu Dec 10, 2015 23:47
Well, what kind of ritual posture , position, and anthem, greetings, it turns out - folding handle magnet feel the bio-electricity between his palms and chant the mantra Om
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Re: U-system.
Post by мимоходом » Fri Dec 11, 2015 0:31
In General, symbolically the letter U is the beam. For example, the very ancient and secret mantra RA-u-m is the content (m) beam (m) light (RA), although it by itself without the breathing center of the forehead or the crown of the head - almost useless
раданов
Re: U-system.
Post by раданов » Sat Dec 12, 2015 15:28
Корвин wrote:Well something like the ritual of poses , positions and anthem, greetings, it turns out - folding handle magnet feel the bio-electricity between your hands
in this position, by the way active all three priest ,sage ,warrior . in each practice, there is a basic "input" settings on the practice can the position for the u-system to use
Иван Славов
Re: U-system.
Post by Иван Славов » Sat Dec 12, 2015 20:57
I have two questions about U-systems:
- how did these ancient archetypes /Sage, Warrior and Priest/?
- how's going on the reading for each member of the club /the club card preciates/ his /her/ an individual 'settings', then to determine which individual /tailored CHK/ programs going through the map need?
Thank you.
Aura
Re: U-system.
Post by Aura » Sun Dec 13, 2015 16:38
Ахим wrote:- how did these ancient archetypes /Sage, Warrior and Priest/?
Similarly, as with all programs, not written by programmers - in fact it is standing waves in the horizontal space between the surface of the Earth and the physical component of GEIP the ionosphere, resulting from the resonating waves emitted by the brain of all living beings. There is an assumption that these programs began to form even in the human community and the animal, so is the ancient arch-typical programs.
Ахим wrote:how happens the reading for each member of the club /the club card preciates/ his /her/ an individual 'settings', then to determine which individual /tailored CHK/ programs going through the map need?
The map has the same firmware as in neocolony.
Милая
Re: U-system.
Post by Милая » Thu Dec 17, 2015 10:18
Inspired by the night... in order to move on a spiral upwards, to move from level to level, it is necessary to apply force, the force of physical, intellectual, spiritual. If the collection efforts are balanced, the upward movement steadily and consistently. The sequence of effort, however small, gives lasting results and a guaranteed transition, and if the force-time and powerful, then keep the result difficult. Stress is a kind of lever to lift, move up. U-U... violence-violence...
The reason efforts is the motivation, but the awareness of the process may also be a good motivation.
нева
Re: U-system.
Post by нева » Thu Dec 17, 2015 11:51
Милая wrote: in order to move on a spiral upwards, to move from level to level, it is necessary to apply force, the force of physical, intellectual, spiritual. If the collection efforts are balanced, the upward movement steadily and consistently. The sequence of effort, however small, gives lasting results and a guaranteed transition, and if the force-time and powerful, then keep the result difficult. Stress is a kind of lever to lift, move up. U-U... violence-violence...
Apparently, You understood the "Great Principle of Rhythm"..That regular exercises lead to a stable result, and one visit to the gym, or Chinese language courses..only lead to the satisfaction of the curiosity..Probably the ability to match the rhythm of established efforts with the rhythms of society or something(someone) else is the basis of harmony, which is a powerful "energy magnet"..and simply beautiful
нева
Re: U-system.
Post by нева » Thu Dec 17, 2015 13:09
Sweetheart
Built in harmony with the rhythms of the efforts .. can have a real Effect..and even somewhat scare "followers of Chaos"..
And there is no harmony - there is no "magic" and be afraid of nothing.
Probably the same, and in consciousness is happening..or chaos c chaos in the head, or discipline..order))
I mean either every thought itself(Swan, cancer and pike), or in the thoughts of the "total energy"..And "total energy"..this is common.. rhythms and overall efforts.... which provides a General direction..)) Just often happens that thoughts differ from actions, because the rhythms are not consistent.
нева
Re: U-system.
Post by нева » Thu Dec 17, 2015 15:31
Милая wrote: need to make effort, effort, physical, intellectual, spiritual. If the collection efforts are balanced, the upward movement steadily and consistently.
Милая wrote:the Reason efforts is the motivation, but the awareness of the process may also be a good motivation.
It is logical...!
Корвин
Re: U-system.
Post by Корвин » Fri Dec 18, 2015 11:53
нева wrote:the Reason efforts is the motivation, but the awareness of the process may also be a good motivation.
There is another BOREDOM
