Designer ties
Гроздев
Re: Designer ties
Post by Гроздев » Thu Nov 05, 2015 19:19
Please tell me about the free version:
Does it make sense to use the card masculine/feminine, in the sense of the presence of Pandora, or is it better to generate code N0.5?
Petr99
Has thanked: 3 times
Been thanked: 15 times
Re: Designer ties
Post by Petr99 » Thu Nov 05, 2015 19:34
Pandora sewn into any product in manufacturing, does not manifest itself as Pandora for the operator products, as it is part of an integrated product. In your case you can only claim to 0.5, if no commercial Pandora.
Спящая Кошка
Been thanked: 5 times
Re: Designer ties
Post by Спящая Кошка » Fri Nov 06, 2015 9:51
Michael, another huge thank You!!! However, all of Your product version "Lite" I would have called the products "trash".. :lol:
After the application designer the next day I had a headache and fever (which I for several years did not happen). Then, like aspects, with whom I have worked has only worsened. But after about a week I had the same understanding of why I so sausage. There was a full awareness, there were forces for the adoption of the situation and the circle is broken! :D Now I know that the problem is not coming back, because it's not a problem. :)
Again a thousand thanks! :o
Re: Designer ties
Post by Михаил_ » Fri Nov 06, 2015 23:05
:) Huge please...
Yes, trash, t/e layt :) not to make light such as soft as a paid product, because to maintain efficiency it is necessary to apply more hard algorithms.
Glad that helped, and sometimes it is not obvious somewhere...
Thanks for the feedback :)
Re: Designer ties
Post by Михаил_ » Fri Nov 06, 2015 23:06
Yes, Peter's response about Pandora is absolutely correct.
Дивергент
Has thanked: 16 times
Been thanked: 2 times
Re: Designer ties
Post by Дивергент » Sat Nov 07, 2015 23:28
:ay
арте:м
Been thanked: 8 times
Re: Designer ties
Post by арте:м » Sun Nov 08, 2015 1:05
Irene, "relationship designer" - an Autonomous unit, separate "Pandora" for it to work is not required.
Has thanked: 112 times
Been thanked: 71 times
Re: Designer ties
Post by АндрейКо » Tue Nov 10, 2015 12:52
Printed self-made Designer ties on the flipchart.
Wife has asked something similar.
Before sending the printout to explain and show how to activate :)
and of course on the map... fire (activation)
Like I had 5 seconds on the activator(digital), but it was enough... all this dressing staged (which of course does not excuse me).
In General it is better to observe some caution.
Feel, printed on Whatman paper/cardboard more than a thin sheet of paper.
Gelios
Been thanked: 7 times
Re: Designer ties
Post by Gelios » Tue Nov 10, 2015 15:45
Better quality thick photo paper I guess. On Whatman paper and cardboard paint can potreskatsya.
Re: Designer ties
Post by АндрейКо » Tue Nov 10, 2015 16:11
Gelios wrote:Better high quality thick photo paper I guess. On Whatman paper and cardboard paint can potreskatsya.
Used smooth paper. Printer color led (almost laser Xerox 6000)
Re: Designer ties
Post by Михаил_ » Thu Nov 12, 2015 14:45
Yes.... (about the spacing), so I said, when told about the designer that you can use parts of it, as a completely independent item of wide profile. Plenty of applications can be. In this case, I don't know the place was the dressing or not, but sometimes it happens just need.... exactly like empty :)
In General there are lots of options for creativity.
Besides, it is very powerful even in the light version.
However it should be noted that the Masculine/Feminine is the same "fire" component, the handle where you can tuck into max when needed. Although the card Constructor it is slightly modified activator and an activation method for greater efficiency.
Gelios
Re: Designer ties
Post by Gelios » Thu Nov 12, 2015 23:13
Михаил_ wrote:Yes.... (about the spacing), so I said, when told about the designer that you can use parts of it, as a completely independent item of wide profile. Plenty of applications can be. In this case, I don't know the place was the dressing or not, but sometimes it happens just need.... exactly like empty :)
I have this stupid tendency is to fall into a state of near Empty, and spontaneously arrange sleepy. Just as comfortable and natural to be in that condition, but the consequences of "fun". If converted into "portable kurilnyu with opium narcotic". And when I became stronger as a consequence somnolent veil began to cover long distances and more rapidly and tough to operate. In a few small word, with my coming the activity is first stopped, and then the us fell apart at all.
And is it worth trying to straighten out my features socks, a Flare from a constructor in the pocket permanent ? I suddenly uncomfortable, even for 5 minutes I want to throw the card away, but so to say to wait until the mind adapts, 21 days like spit and roar. :) Prishpandorit elastic map fire to the activator in his pocket.
Like the masculine needs the same things myself to work ? Yet a little time has passed since its acquisition.
I understand that a few stupid questions, but adapt your technology to address this issue would be nice. :)
Даррья
Been thanked: 3 times
Re: Designer ties
Post by Даррья » Fri Nov 13, 2015 2:15
Hello! And at the time the "record" example to include the Conductor and ask the purpose of "my connections, my broadcast outside image and my personal egregore in all plans of my life are set up the most optimal and harmonious way to me in accordance with the current needs and requirements"? And then after zeroing my head is such a void ring, the really thought of not going together, and to do creative and meaningful work. Really tried briefly beforehand in a notebook and need to throw, but spheres of life very much, and everything should be a little bit different (optimal), and very much overlooked.
Gelios
Re: Designer ties
Post by Gelios » Fri Nov 13, 2015 9:41
Даррья wrote:Hello! And at the time the "record" example to include the Conductor and ask the purpose of "my connections, my broadcast outside image and my personal egregore in all plans of my life are set up the most optimal and harmonious way to me in accordance with the current needs and requirements"? And then after zeroing my head is such a void ring, the really thought of not going together, and to do creative and meaningful work. Really tried briefly beforehand in a notebook and need to throw, but spheres of life very much, and everything should be a little bit different (optimal), and very much overlooked.
And when I worked as a Designer, though the specifics prescribed where it is necessary, I strongly see that the natural track is the process to start is to record yourself first and foremost, though with a possibility to embellish in different aspects.
Well, maybe Michael's set up initially :) In General, the difference between "I'm real" and "I in the eyes of others" using the designer to shrink. No matter what there drawn by the operator. Because people are multifaceted inside, and the identity invariant. From the natural formation of the different that on the basis of itself, and from itself, the constructor extracts a new image. Or rather pulls the operator, under the designer. This enhances the harmony of process and creative component. The Foundation so to speak is on record with the deeper level which is not distorted by negative experiences with society and has many possible manifestations, it is less "deep" and the levels themselves are fixed. And this level itself in grigorauca not reflected in people usually. And it's changing interaction with society. The tension between itself and cleans, which Michael said. As a minimum if such a thing successfully must leave the fixing of person in a particular fixed static role egregore.
I may podglyuchili understanding of the operation of the product, but it is after the test impressions are.<
Has thanked: 5 times
Re: Designer ties
Post by Воффка » Fri Nov 13, 2015 21:50
Michael_
Tell me, involvement in podagricomela communication need every time you work with a map reset to re-register?
.Ксения.
Been thanked: 91 times
Re: Designer ties
Post by .Ксения. » Fri Nov 13, 2015 22:03
Voffka, why do you podagricomela of when to prescribe? :)
The designer seems in order and is made to reset the "left" of communication, which podagricomela and are in the majority, and build a harmonious connection with the world and others, for example, the horizontal co-creative artistic.
Даррья
Re: Designer ties
Post by Даррья » Sat Nov 14, 2015 1:50
I tried, kind of interesting happened with a better understanding of something. And Yes, it's "I'm real", but some traits that I would like to develop and strengthen the (already available), and introduced a more manifest, and internally it is perceived correctly and harmoniously. By the way, if in the normal state at the stage of recording before and got lost and confused (noticed it just in time for the session), then in alpha under a conductor like that themselves easily saw the images/situation/category for adjustments, and the simultaneous understanding/knowledge of how to "correctly" do it. IMHO, it is very convenient and can say, expressive. Let's see how it will manifest
Re: Designer ties
Post by Воффка » Sat Nov 14, 2015 21:26
.Xenia.
The process goes on, but immediately turns to pull out old relationships and at the same time to develop new
.Ксения.
Re: Designer ties
Post by .Ксения. » Sat Nov 14, 2015 21:38
Воффка wrote:.Xenia.
Voffka, it is clear, just your question was - is it necessary to prescribe these links again, so you and I asked - what to prescribe? To reset, I can understand, but to register, then why and then what's the point in muting if you then back the same prescribed? It will not change ever. It makes sense that you get rid of inharmonious interactions and prescribed harmonious and natural. Each time it is all the more manifest will be :)
Re: Designer ties
Post by Воффка » Sat Nov 14, 2015 22:56
Zero-I, including those which do not suspect, and prescribe just the right, plus a "tap" handle. And as I understood from the seminar, after the reset, when activated manually yourself papagrigoriou structure, process interaction takes place with the flow of energy to the connected, not the drain. Correct me if I'm wrong.
.Ксения.
Re: Designer ties
Post by .Ксения. » Sat Nov 14, 2015 23:10
Well, in General Yes, if you become an active operator and look at it conventionally from the state 3.0 as on a laboratory table :) which is fun to play, then Yes, you do not "milk" or sometimes give even more energy, but on certain conditions (still end up milked, and that in itself is not a creative state, a dependent and a slave), then you can mess with it, not falling under inharmonious influence these relations. But is it necessary... Just work out and purchase this experience possible. And there are plenty of other harmonious and natural ways to get energy, for example, to generate it yourself as you grow and strengthen your own creative potential :)
Re: Designer ties
Post by Воффка » Sat Nov 14, 2015 23:41
.Xenia.
Thank you for the clarification! :)
Been thanked: 16 times
Re: Designer ties
Post by Вячеслав. » Sun Nov 15, 2015 22:14
Hi! :) The last few dmey rebuild their connection.Something to optimize,something seeming to fall off over time unnecessary.Michael,thank you for helping to keep up with the times
Re: Designer ties
Post by Михаил_ » Sun Nov 15, 2015 22:52
Gelios wrote: And when I worked as a Designer, though the specifics prescribed where it is necessary, I strongly see that the natural track is the process to start is to record yourself first and foremost, though with a possibility to embellish in different aspects.
.....(quote by pokazana see full description above)....
Actually a multifaceted process... for some types of interactions I do not write anything from yourself this is actually because inside a subway somewhere doesn't like....
Understanding right - you can reduce the possible potential of the simple fact of the conscious construction of relationships. This is a very useful method.
BUT due to the fact that "against the scrap no reception" for a number of relationships useful to prescribe something else. And here is it's not "embellish".
The fact that some communications don't need to be dragged somewhere we don't need direction at all. So you can close them on those aspects where we have resonances and internal problems will not be so "stretched" rubber band external. And there in those aspects where resonances dumb :)
I will give a simple illustration, think quite easy to understand.
Imagine that in the ship/yacht/boat has a hole and through it the water flows. (this characteristic of yours she's calalca from the outside world through egregorial communication).
So the question is, how the hole is easier to patch ? while the boat in the water and through the water gushes or vytachiv to the shipyard ?
After working with the designer, we remove the stream with the pain points and can work with them, not to mention the fact that the work of the designer is working with pressure points and their reconstruction and this is the shipyard for repair, but what is left can grow/shrink effect on us when taking potential.
So I use a very versatile designer. "I am real" there circle of friends, where I was able to perceive in those fancy aspects, which for ordinary people is not very clear. For example, for a question about work, I answer the very programmer (this is true for many reasons). Inside I know the truth and speak it openly, but the Association occurs in people of course not the ones that I have :)
Based on the theory and practice of sealing the gaps in the boat, I think you can make adjustments on approach.....<
ОлегЕ
Re: Designer ties
Post by ОлегЕ » Sun Nov 15, 2015 23:30
Question - in the free version what cards mean what?
