Bracelet Gene/Reanimator 1.0
Re: Bracelet Gene/Reanimator 1.0
Post by Михаил_ » Mon Jan 09, 2017 7:20
Андрей Ермаков wrote:And a bunch of strange feelings that were not there before.
In fact, I wish someone with a commercial "product recovery" compared to this version and a serial bracelet :) well, respectively, who feelies this good.
He, like all homemade, tougher turned. This is mainly due to the fact that for the sake of simplicity, it would not have been made "home-made" have to abandon the "translational" processing which you can gently push a large amount of data and have to do a hard link. Hard not hard of course, but really is more tough.
The General theme is associated not with golimy charging "thoughtforms" or "my energy" or "mental tuning" which "suffer" the majority of those who are doing something ostensibly energy-active or otherwise-for something that impacts in detail chewed if I remember correctly on the 2nd Seminary and all who listened to it ( in the chronology of the first historical cycle, which was given for free that was 4th in the queue thread) is aware of this issue. In short - there are at least two different ways to specify properties of the object. Popular now "to opacity" his energy (it's blurred over time, rinse with running cold water and so on. The one we use gives indelibly to the product. No matter how it is made process - the consciousness of the operator/computer/projector, etc.
If you are using serialization process, to create the object with a large list of properties used stack linkpush files, which, although designed as a file, but really have a second component that is associated as the two strands so that in the form of zeros and ones (files).
Moreover, the number of files that only thanks to coincidence of circumstances became applicable 2 gigs (if more accurately - a little less), can be very different, despite the type of the object.
For example, the Arbiter uses a 5 translational model files. On genome-Reanimator - 4, and the map masculine/feminine about a hundred, that doesn't mean they're "cooler". It's just different things. Obviously there are easier, plus which in effects and aspects (such as the executor), and there are more complex plus which megamodules (such as breast start).
In this workshop, we have shown that instead of quantum-optical sensor, which we use to record the signal of the consciousness (well actually steam is used in Tae whole group of them worked, many remember), you can JUST record the noise. Well, nearly any random sequence. This is the second version of the approach, a little more difficult for consciousness than the work with the sensor, but also possible. H/e if you take for example in the form of adob-audishn earlier versions of the generator of pink noise as it is generated (medany process even on the fastest processors) to weave by a UNIQUE sequence of numbers necessary resonances with the world (and for those who knows with out-of-the-world, one might almost say with the "corridor"), you also get the digital half of the "rope" in two parts, where one is on the "media" and the other is outside thereof.
But in any case if the object of the work is complex and intelligent (not the hammer and Microcom relatively speaking), how is not generated to the data, their volume must be large. It's just all who worked and works with technology many times on personal experience checked, and works not so few people (I mean those he writes broadcast, etc.).
I it to what? if we SIMPLIFY the description of what happens to the object, it partially shifted from the creation of an object with certain properties in the creation of the resonator to these properties. However if the standard is taken correctly made all the same data, the second half of which are located "not here", it will not be (and very important) clue for something specific here and especially not be egregorial binding.
And then in addition to soiling the energies there are still fans just make the objects with the link. Something. Or with the entity that sews bearing somewhere.
What I detailed ?
Genome-Reanimator conventionally, a simple product, it is in contrast to the m/f not started hundreds of gig, and only 8 gig in the base used for batch production records. Although the work is not really Gigi, and that they filed as if on the other hand, as the second linked thread.
8гиг could be put, it is not a problem technically, the problem is that then it won't generate home-made. Since most of the information roughly speaking "nothing". Is it woven/tangled with her process/object And to create on the material object, the same properties need to create a link including mental as enabling broadcasts. And it's not that the Creator of the homemade no quanto-optical sensor with a bad paper from Switzerland that it (the sensor) is a random number generator (it's funny that squares above the published they also made a very random video :) :) :) :) even to look at.... ) sensor, like I said, it would be possible simple to replace, although the load on the brain and what is behind it the man thus brutally is growing. Who wrote his audio special explanation of the 2nd seminar topics, those in the know. But the problem is that without experience bundles of objects, and specific code and the server on which this code is to drive a couple of days, the process did not spawn. Can it be replaced by something ? yeah. A very powerful mental. Although the difference in the output no. But the mental has to be trained.
In view of this problem is impossible, some products homemade products to make. A link to the rescue I did (see above) but on the same breast started - there are so many modules that it's just not going to work.
BJ-the projects where modules are used another principle of forming the modules is that we should not do "modules" anywhere to record (the word record here is conditional).
Thus, conventionally, simple things can be in a simplified form described by link and it creates a more aggressive version because the link twitch info-object and its "entry" occurs here, as it more harshly. On the one hand it is more sensitive to the uses: gives a more vivid effects. On the other, from the point of view of long-term action, this stiffness is usually not desirable. Therefore, I recommend homemade rescuer to wear around the clock.
About something like that (in short).<
Post by Михаил_ » Mon Jan 09, 2017 20:27
bobogan1 wrote:Noticed today at work that quickly turns on the second breath . Kind of tired and suddenly once again all right. Did two genomes in the recovery on the notebook in the box and in his pockets.
Post by Михаил_ » Tue Jan 10, 2017 22:25
to eliminate confusion, once again, the correct explanation:
Verus wrote:As I understand it,the figures are only taken from the coils,as described above(picture for easy filling) and are placed sequentially(one or more lines, depends on the size of the object to which you apply),one after another took out a red spiral 30,then out of the blue 14,red 37,blue 13, etc. 37,16,51,37,32,23,...
rel
Has thanked: 222 times
Been thanked: 84 times
Post by rel » Wed Jan 11, 2017 3:52
here was now a topical issue :)
Алега
Been thanked: 3 times
Post by Алега » Wed Jan 11, 2017 17:10
If you still to fill in the spiral,then on different sides of the paper or on one"investment" one helix to another?
АлексейН
Has thanked: 20 times
Post by АлексейН » Wed Jan 11, 2017 20:21
bc Why invent your own version of the filling?... :shock:
Are there instructions. Michael time to write it just so spent, nothing to do... :roll:
Post by Михаил_ » Wed Jan 11, 2017 20:28
Алега wrote:If still to fill in the spiral,then on different sides of the paper or on one"investment" one helix to another?
It is not necessary to fill in the spiral. Like clear instructions.
Post by Михаил_ » Wed Jan 11, 2017 20:29
rel wrote:Michael, can you still to simplify (myself and others) 'Assembly', so?
(there is zip with images and a txt with the idea that however clear)
or is it a need to fill was in this special mode (brains Surudi)?
Well, why do you think I did spiral pictures ????? :) to complicate specially life? I would do the stitching immediately if the spiral is not needed.
Post by Михаил_ » Wed Jan 11, 2017 20:31
People, please do not reinvent the wheel. Filled (mentally or physically) in place. The figures are taken from the spiral. Turns out one from the other. On the other is not necessary.
rel
Post by rel » Wed Jan 11, 2017 20:34
Understand, clean files.
Post by Михаил_ » Thu Jan 12, 2017 0:17
MaxSk wrote:Just tried to write this, a little brain is not exploded, climbing by numbers, like the Corwin in the maze of ember. Let's see how this bill will affect. Judging by the arrangement of the numbers is hardly random number generator sdelano
Quantum random number generator, imeshi as much as the Swiss certificate that he was "a true random number generator" and it is mathematically verified. Recommended for use in the online casino and systems of cryptographic protection. Based on the quantum effect - the photon either passes through a semitransparent mirror, or reflected from it. The probability of one or the other phenomena are approximately equal. Captured different parts of the sensor. Contains avtomalinovka judging by the description (if the average flow on one of the sensors begins to dominate, he's something in there turns again to restore in the average plan balance).
And Yes, the squares made of these DIFFERENT sensors simultaneously.
rel
Post by rel » Fri Jan 13, 2017 1:46
When I finally figured out how to properly comodality,]the next morning, joined me as elektrovenik, starting with the fact that his morning to the main complex recently came up with the buildup, but I rarely did it, and not the whole sometimes short (boring, long, and tired) - and then, whack-whack, did, and standing in the hallway, arms akimbo, and.. seriously ask myself, "so.. while charging then I did or just going?.. fatigue-where?) at least strained muscle?.."
and then, all day "flying" and juggled chores, a bunch of cases, so much so that even unconsciously the evening was "grounded" - as it usually took and defiled with family, wine, "one for company", and thought will generally take somewhere over the horizon..
Dreams (charge) is significantly shorter Wake up fully working condition much faster.
And today recently, in a dream were encyclopedias, which I also seem to be a reflection of the Genome. Starting with the fact that some time past I do not remember details of my dreams at all.. and then for the first time after the break I remembered a bunch of detail images.
And there, returned me in my sleep t-shirt, I went somewhere, the scenario of the dream, met the people or guests look, and I suddenly, they wasserthal t-shirt, just returned 3 pieces and one of the returned himself said that he is also 3 t-shirts today back)
And.. not just t-shirts.. and from the series "now these do not" - such a tight, tight, almost burlap in half with armor, heavy, such, nice, everything I like and everything I remembered, "Oh, I thought she already don't come back.." such as the return of resources to some, while "those" is correct, "ancient".. why Gene thought.
Another striking case of "forgotten" - we are standing at the bus station, pass the brook soldiery in "lumps" and ... "our company commander cap" from the FSB.. I yelled, grabbed seruku and shook and thanked for drill and treny (meaning in a dream like martial arts, although in the real fight I was trained by another person, but with a similar bearing, in the end, I realized that in the dream it was a fusion of the two) - he was "moved" (as far as can be moved by brutal fighting machine))) more precisely grateful in the style of "that would be so long" so we stood there for a little chat. Metaphorically, kind of like another resource, or rather some kind of old connection rectivirgula.
Was still closed then open the door (something big like a warehouse or Hyper), in which we, in the course of events that took place, then there is no security there, all sorts of keys, alarms, etc. In General, interesting shifts) and in dreams and reality)<
Post by Михаил_ » Fri Jan 13, 2017 14:39
Thanks for the vivid review :)
Post by Михаил_ » Sun Jan 15, 2017 22:32
romario wrote:in-In auger I broke the hearts of not one piece of paper with the translation in one line 288 numbers, the Roof refuses to work, all the floats solved the problem by copying the numbers from the right of the spiral in the spaces between the numbers in the left, and then one a number of Very strong influence, see further Michael, kudos to You!
Алекс С
Has thanked: 2 times
Been thanked: 7 times
Post by Алекс С » Thu Mar 09, 2017 16:30
Michael, Thank you for developing that effects including and health!
(well, I like this vector :) )
If I may, three questions about scratch:
1. Epoxy makes sense to reinforce? (weight makes sense?)
2. Clothing can be so "loaded"? (sorry for the term)
3. The bracelet links can also be loaded, if it is to write number of writing or Nephishesim pencil, all 288 of the number one on top of another?
Summer, wear a bracelet made of tubes of twisted "teletype tape" is not very convenient :)
Been thanked: 10 times
Post by Мастер 108 » Sun Mar 12, 2017 20:19
1. No
2. Maybe if you can write on it the number
3. "One over another" will not go number you have to write in the line, the line can be transferred.
Алекс С
Post by Алекс С » Sun Mar 12, 2017 20:59
Thank you!
Post by Михаил_ » Mon Mar 13, 2017 5:53
Exactly. Well, only I would add that even me a piece of paper seems relevant and tangible thing. It may not be a link, and clothes then ? And enough judges a piece of paper somewhere in the pocket to put ?:)
Алекс С
Post by Алекс С » Mon Mar 13, 2017 19:03
Michael, Thanks for the confirmation.
I was sure that if there is mental work on drawing number (consciousness, not for example a printer or a laser engraver to burn), then any previous applied numbers are not important, and as a result, writing into the line - too unimportant and link bracelet, you can still... wrong.
Paper felt, but not always, and I'm with sheff OM, I need "brighter", "more powerful".
I think to paint Terry sheets, and "to her cover to cover".
But annoying me one moment - the possibility of error when writing.
When doing the paper version, to be honest, sometimes confused (or rather lost), burned and new.
Well, ie can you write the numbers already prepared order on a piece of paper - a crib, put the paper on fabric, and since she accurately redraw?
Do I have to merge the two spirals alternately in one line?
This is necessary for proper mental work?
Post by Михаил_ » Thu Mar 16, 2017 3:14
Need it. And that is explained already (this question was asked).
Рома З
Post by Рома З » Sat Apr 15, 2017 20:34
Hello, everyone. From the commercial band with week joints hurt in my elbows and triceps of the left hand where you wear a BJ. After two weeks of wearing there is a sense of a bracelet and on his right hand, he's not there. A possible effect of the broadcasts.
The first time I woke up from the powerful tides of energy and in the morning the abdomen was tense.
Feeling the energy on his hands, mostly to brush.
On the first day of wearing twice clutched at the bracelet and wonder that is not broke.
I am very glad that have access to the work of Michael
Post by Михаил_ » Mon Apr 24, 2017 2:17
Thank you :)
Эдуард
Has thanked: 4 times
Post by Эдуард » Fri Apr 28, 2017 10:34
[quote="rel"]so as not to stray:
so is a genome? or something else?
Бисо
Has thanked: 49 times
Been thanked: 38 times
Post by Бисо » Fri Apr 28, 2017 11:39
Эдуард wrote: is a genome? or something else?
Yes, this is gene.
Гуфест
Has thanked: 125 times
Been thanked: 120 times
Post by Гуфест » Wed May 03, 2017 18:53
Hello Michael.
Free samples of paper work,but inconvenient in terms of wear and strength,for example, put his hand in his pocket and all torn.
Offer to do samples of yarn of wool,cotton,flax,for which you can borrow money,to charge babineaux 5000метров,price per piece in 20cm ,themselves appoint,but I think it will not be as expensive bracelet, and the range of consumers will be wider, wear much longer,remember how there the thread breaks our plans implemented.Magic with threads and knots on the wrist there is a very long time,practicing,Buddhists,Kabbalists,Christians,Wiccans,witches,and ordinary people who want a miracle in my childhood.You can apply the old to the node in the thread(arname of the nodes), or the whole thread.I would give preference to the Genome of the Reanimator.Modern technology will cross somewhere out there with a very ancient tradition and magic.
