Deck Alpha-Vit
Расторгуев
- Has thanked: 6 times
- Been thanked: 6 times
The limit most likely as with all products of Michael depends on the operator,some Lite version more things to do than other commercial.
Re: Deck Alpha-Vit
you are absolutely right. Well by themselves (for one operator), they cast about once in 5-10Расторгуев wrote:Limit most likely as with all products of Michael depends on the operator,some Lite version more things to do than other commercial.
Андрей Ермаков
- Has thanked: 3 times
- Been thanked: 15 times
Re: Deck Alpha-Vit
Yes... the intrigue is off the charts
though those who bought reviews more wrote. The vacuum was filled
Re: Deck Alpha-Vit
Michael, and if the cards with the target mix is not intuitive, but only randomly, or well let's say not my intuition and I put them anyhow. In this case, will realizovivaetsa target trend? Do I understand correctly that in this case can be manifested in excessive randomness and purpose will still be "kicking" but as it is not optimal as if the cards happened more or less correctly?
Re: Deck Alpha-Vit
I do not see any scheming and the reviews are like ....Андрей Ермаков wrote:Yes... the intrigue is off the chartsthough those who bought reviews more wrote. The vacuum was filled
- Has thanked: 1 time
- Been thanked: 182 times
Re: Deck Alpha-Vit
The deck works, and gives the ass-kicking, you might say
Though the purpose I have complicated and long-lasting seem.
Re: Deck Alpha-Vit
I've screwed up with the wording. Yesterday I decided to "get" the intention of the performance tonight and "got on the head"
. It would seem that the very intention, in my understanding, harmless and small, but feasibility is difficult. In a hurry forgot about the harmony and safety, in addition are rigidly ordered. Wish granted, but paid for it burns on the body(not from artifacts). The benefit of blisters is not reached, although there was hot water... were involved in the first place ALFAVIT and dopom SK and 2.6. Blame myself! No one and nothing to blame, I will do otherwise and do not rush! While it may be true that the situation of burns is not connected with my intention. Intuition works not ice. To write that the desire was not able, yet personal. Guys don't forget about the harmony and security everywhere. While the thunder will not burst..
I know many times I write about it, but it came out as came
Re: Deck Alpha-Vit
Well, there was V-cartridges, if I am not mistaken Michael wrote that can produce V-broadcast to 'the club'.НРР wrote:Intuition works not ice.
By the way, many think that the intuition is not working, but really..
Re: Deck Alpha-Vit
bofara wrote:Well, there was V-cartridges, if I am not mistaken Michael wrote that can produce V-broadcast to 'the club'.НРР wrote:Intuition works not ice.
By the way, many think that the intuition is not working, but really..For real, really..
It works, but I can't it don't know how to describe...to test or what to finish. Plus consciousness in this respect, loves to doubt infection
Андрей Ермаков
Re: Deck Alpha-Vit
There is another assumption at the expense of the cards. They are connected with a stabilizer. It is possible that the maps have a sequence of NATO -0 to the LAW - 9. IMHO
Re: Deck Alpha-Vit
Do not need any assumptions - with anything they are not related and it's all nonsense, do not clutter up the thread!Андрей Ермаков wrote:There is another assumption at the expense of the cards. They are connected with a stabilizer. It is possible that the maps have a sequence of NATO -0 to the LAW - 9. IMHO.
Re: Deck Alpha-Vit
The deck is working well, start moving events in the direction of the goal.
intermittently rattles in events, then shuffle the deck.
sometimes you just shuffle the deck, even if there is no bounce, just a desire to do so.
Sometimes everything around you begins to cause irritation and aggressiveness , we have to deactivate the deck and work through their condition . Then again start .
Still one deck a little, and a lot of tasks - you have to turn (1-2 days) to push different trends - for example, if you need to solve a small problem, I've deactivated the deck, after some time start need a small task, working with it 1-2 days, then return to the main relevant purpose.
Re: Deck Alpha-Vit
it seems to me that it is better to work for no fixed purpose as to the result and the goal as a dynamic condition.
or to put their desired goal (which is necessary now) as the next step in the long term big goal (which is to the far future). That is, the goal should be ultimate, final, and intermediate.
Or at the approach to the goal have to let go, to deactivate the pack.
Otherwise, the trend in the approach to the finish line begins to slow down, pritormozite not to go past the desired stop, since the event series has momentum.
Therefore, a small target if let go, they usually are.
Re: Deck Alpha-Vit
Hello Michael. I then noticed that the cards began to delaminate on the edges and in the corners. Can them for laminate or adhesive tape at least 2 sides to glue. And sorry if bad.
Re: Deck Alpha-Vit
Elian and I have they came. I think many do and that's okay, most likely this happens when cutting cards. Wear them in the holder just in case, you never know. And down here http://www.mindmachine.ru/holographic_t ... /index.htm if you look closely, you can see the same bundle on each side. By the way how are You with the deck movement?Элиан wrote:Hello Michael. I then noticed that the cards began to delaminate on the edges and in the corners. Can them for laminate or adhesive tape at least 2 sides to glue. And sorry if bad.
Re: Deck Alpha-Vit
NRR well, just think they will continue to flake. So I ask if them over the laminate will change their performance? Like should not, but you never know... the Movement is so-so. quick results are visible but usually small tasks, and for the best settings with the cards, probably a good small task at first. And then there is how much. There was one... we'll see.
Re: Deck Alpha-Vit
Good day! Have purchased a pack of alpha Vit, activated, (really big goal), when I shuffled, walked into a persistent ISS, a sense of movement both inside and outside. Legs, as a drunk, and most importantly a very happy understanding and feeling somewhere inside Things! And peace of mind. The desire to shuffle the deck appeared the next day, very loud inside, as many hands shook, shuffled to harmony
And the event is quiet. I will write about the changes
Michael, You create such Wonderful things!!! A Huge Thank You!!!
Re: Deck Alpha-Vit
I think that they don't care at least three times to laminate. But it is better to wait for a response from Michael you never know.Элиан wrote:NRR well, just think they will continue to flake. So I ask if them over the laminate will change their performance? Like should not, but you never know... the Movement is so-so. quick results are visible but usually small tasks, and for the best settings with the cards, probably a good small task at first. And then there is how much. There was one... we'll see.
Re: Deck Alpha-Vit
Going still'll laminate the deck. Michael when I bypass the 9th target card managed card to the inside of the handle to strike with mm it's not scary?
Re: Deck Alpha-Vit
Elian. I laminate the deck. In the cabin, scared that they will be broken and I took the risk. All normal. I think the performance including.Элиан wrote:NRR well, just think they will continue to flake. So if I ask them over the laminate will change their performance? Like should not, but you never know... the Movement is so-so. quick results are visible but usually small tasks, and for the best settings with the cards, probably a good small task at first. And then there is how much. There was one... we'll see.
Re: Deck Alpha-Vit
Yes it is certainly possible to laminate again.... well handle stressed it's not scary...
Re: Deck Alpha-Vit
Michael Hello. I. e. the performance after the re-lamination does not change? Scare your points))Михаил_ wrote:Yes it is certainly possible to laminate again.... well handle stressed it's not scary...
Re: Deck Alpha-Vit
what are they afraid of?
there is not going to change, well, I often use point hidden beneath shaped component of the response that lazy or slow or impossible to describe.
I hope the deck the more recent editions do not exfoliate, I have them in separate files laminated (for several reasons first it was not possible to do technically)
Re: Deck Alpha-Vit
Now everything is clear, thank you!Михаил_ wrote:what are they afraid of?there is not going to change, well, I often use point hidden beneath shaped component of the response that lazy or slow or impossible to describe.
Re: Deck Alpha-Vit
All Hello) I Wanted to share the joke - in the penultimate lecture (I think
) bought a deck ALFAVIT. Had not experienced a global financial difficulties, by the way. So here has set a trend, put a pack in the purse. And the strange thing ..... was in complete financial ...operators))) I do Not remember this with "detstva". This is the bounce or I something not so made? Someone tell me how to fix it?
