Mask for meditation and ESP "Palantir"
Re: Mask for meditation and ESP "Palantir"
Post by Андрей Патрушев » Wed May 14, 2014 9:27
AHHH
Hello.
Mask is just a booster for your actions. Revise your technique.
The masks are made and checked very carefully.
Владимир Никонов 2
Has thanked: 20 times
Been thanked: 28 times
Post by Владимир Никонов 2 » Sat Jun 14, 2014 15:36
Andrei Patrushev created supraliminal entry for owners masks Palantir II.
Download recording — http://mindmachine.ru/download/supralim ... lantir.zip
A little more info — http://www.b17.ru/blog/test_supraliminal/
Андрей Болконский
Post by Андрей Болконский » Sat Jun 14, 2014 16:27
The Question To Andrey Patrushev.Vladimir Nikonov writes that you can use supraliminally audio program without a mask,then activate it using special.exercises.It's not difficult if You read more describe the algorithm of using audio courses without a mask?thank you.
Post by Андрей Патрушев » Sat Jun 14, 2014 16:41
Andrey Bolkonsky
"Palantir" — mask for meditation
Purpose:
— for deep meditation with open eyes in the dark;
— for rest and sleep in the presence of interfering external light sources;
— to improve vision;
— to work with psychoactive audio programs;
— for the development of alternative visions, clairvoyance, psychometry;
for autopsychological;
— for programming the desired reality.
Any exercise (while wearing a mask or not), in the framework of the indicated tasks will be to activate the information embedded in this audio program. Mask is just a booster for your actions.
Андрей Болконский
Post by Андрей Болконский » Sat Jun 14, 2014 18:06
I'm sorry,but I don't fully understand yet.At the end of the broadcast zvuchat words"the information received must be activated through the exercises".What kind of exercise?I would be very grateful if You, for example(programming of the desired reality for example) will show the algorithm broadcast(listened,he began to visualize a desired reality or.....)thank you.
Дизо
Post by Дизо » Sun Jun 15, 2014 0:57
How often can I use this supraliminal recording without a mask?
Владимир Никонов 2
Post by Владимир Никонов 2 » Sun Jun 15, 2014 15:05
Дизо wrote:How often can I use this supraliminal recording without a mask?
Andrei Patrushev wrote to me:
Special instructions there - just to listen regularly to three weeks. But before going to sleep better not - supraliminal increases anxiety.
Владимир Никонов 2
Post by Владимир Никонов 2 » Sun Jun 15, 2014 15:07
Андрей Болконский wrote:I'm sorry,but I don't fully understand yet.At the end of the broadcast zvuchat words"the information received must be activated through the exercises".What kind of exercise?B
As I understand from a conversation with Andrei Patrushev about this — ANY EXERCISE.
If the programming of the desired reality, the exercises in her visualization.
СДС
Post by СДС » Sat Jun 21, 2014 15:34
In the first message of Andrey Vladimirovich writes that this audio program - the Ultimate goal - the strengthening of intuition. Two questions - 1 From the previous topic - as the strengthening of intuition can help the programming of the desired reality?
2 . how to activate information received from the program when searching for the answer to the question - I do so enter in a meditative trance state try to clear the mind of thoughts highlight the question and then alienate him as if waiting for some images, thoughts and so forth. For the past week, 1-2 times a day to listen to this audio and then do exactly what is written above - is a special difference did not see. Is my entry into the trance state "activation information"? Or what else do you need? Perhaps you need to say "I activate information received......." or "I connect to VZV....." ? Please tell me.
Post by Андрей Патрушев » Sat Jun 21, 2014 15:44
СДС wrote:1 From the previous topic - as the strengthening of intuition can help the programming of the desired reality?
1. And how can it interfere??? Simply, intuition is most clear and pragmatic part of "all this"...
2. Yes, that's right - any exercise. Usually, for the development of any skill is required 21 days...
For fans of fast achievements you can stick your finger in the socket. :wink:
СДС
Post by СДС » Sat Jun 21, 2014 16:09
It is true You advised - if very tight will try. So for now just listen. To apply early. And then it will manifest itself or are these "I activate information received......." or "I connect to VZV....." you need to be mentally sound?
Post by Андрей Патрушев » Sat Jun 21, 2014 16:16
СДС wrote:So it turns out that it is only to listen.
To learn something for real, to do it for real. Just, at some point of the work...
СДС wrote:"I connect to VZV....." you need to be mentally sound?
No, not necessarily.
But goals it is useful to check for compatibility and for "right formulated result".
Also methods there is a great variety, maybe something more effective to pick up....
СДС
Post by СДС » Sat Jun 21, 2014 16:42
I from the point of view of intuition and answers - "do not go there go here............." and so forth.
How about a combination of programs and activities with MM or with discs Sviyash or Yours? How many minutes,hours program can do?
Post by Андрей Патрушев » Sat Jun 21, 2014 16:47
SDS
C MM can be combined safely (can be shared), but with disks (where Sabarmati is) I would not recommend. As a General rule, a break of at least 3 hours.
СДС
Post by СДС » Sat Jun 21, 2014 16:52
Together with MM - in what wavelength range? Sabarmati Sviyash about money can enter a conflict with VZV?
Post by Андрей Патрушев » Sat Jun 21, 2014 16:55
СДС wrote:together WITH MM - in what wavelength range?
The standard program for this, L03, and generally in any.
СДС wrote:Sabarmati Sviyash about money can enter a conflict with VZV?
You have a computer. - What happens to it when running too many programs?
СДС
Post by СДС » Sat Jun 21, 2014 17:21
L03 - 51 minutes for a minute to build?
Post by Андрей Патрушев » Sat Jun 21, 2014 17:34
SDS
On the seventh.
СДС
Post by СДС » Sat Jun 21, 2014 17:43
After the robot about the end of the exercise - what to do - continue baldet under L03 or finish TC 7+12=19 there is still plenty of time before the end of the L03 L03 or cut?
Post by Андрей Патрушев » Sat Jun 21, 2014 17:47
SDS
Any session can be extended or reduced by two times in increments of 1/8 (see instructions). However, you can "get high" - give yourself time to change.
СДС
Post by СДС » Tue Jul 01, 2014 14:23
How to understand the words "listen to the silence." You need to listen carefully to tweets removing other thoughts by focusing on tweets or be in free flight and tweets as the background?
Post by Андрей Патрушев » Tue Jul 01, 2014 14:25
SDS
As You like.
СДС
Post by СДС » Tue Jul 01, 2014 14:29
How to effectively?
Post by Андрей Патрушев » Tue Jul 01, 2014 14:31
SDS
Effective detachment to observe your thoughts as if from outside, nothing not accepting and not rejecting, marking the beginning and end of every thought...
Has thanked: 5 times
Been thanked: 16 times
Post by Вячеслав. » Sat Jul 19, 2014 17:53
Андрей Патрушев wrote:Andrey Bolkonsky
Purpose:
Thanks for the opportunity!... :)
