Disk Explorer
- Владимир Никонов 2
- Has thanked: 20 times
- Been thanked: 28 times
- Contact:
By the way, in the course of the play, appeared
How to count the days, if breaks between listening to the Guide was made more than 3 days (well does not work to enable
I mean the first 7 times I listened to "raspisanie", and then gone... a break of more than 3, a couple of times I listened - even a little break, and so on....
![Confused :?](./images/smilies/icon_confused.gif)
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Since my Explorer with a DVD drive, you are faced with this problem, which has already been described on the forum.
The disc was parallel with the third session of the L03 innerpulse. The third session is 51 minutes. "Explorer" - 70 minutes. And about 5 minutes before the end of the "conductor" of innerpulse disconnected, and disabling the flow of sound with CD player. For me it was very annoying. The real way of course to increase the duration of the third session. This is a note.
Andrew said that "Conductor" it is better to listen in the glasses with the blue color, but in parallel, the imposition of a third session of L03 innerpulse. And how about this?
"How to start?
From anticipation!!!
Yeah - it's a good point - balooo Taco seen! "
It's real - how does the process that I don't know, but 3-4 days before listening on the physical level of the event in relation to a person becoming either a bright sign "minus" or "plus"
"How to start?
- Has thanked: 1 time
- Been thanked: 3 times
The dreams during and after the Conductor
Andrew and I have a question long overdue. Once while listening to the Conductor I saw a very clear and vivid dream, feels almost reality. Although the contents surprised me - it can't be real, but the intensity was forced to think about.
Tonight, after the evening listening to the Conductor, he saw a vivid and clear dream, the content is rather unpleasant, I hope that I have not happened and will not happen.
What could it be? Pop some forgotten moments of life? Possible options for the future? Or, as in anectode about Freud - there are just dreams
Thanks in advance!
Thanks in advance!
You know, about how life has changed, it is possible to write the treatise. Everything in the coupe - and a seminar on Lermontov Big Utrish, classes and with different drives. Hard to describe briefly - became a different person. Calmer, know what they want, has opened many new perspectives in life, manage their condition... Heaven and earth!
When listening to "Explorer", a player we get the following situation: when doing a normal volume on the player and acceptable brightness of points on Enerpulse, the flashing occurs only in the left eye to blink and right need to make the light brighter. Or louder sound on the player, but then flashing glasses merge into a simple glow. Question: not married to this disk? How to tune in this case, if I do not want a very bright light, and thus there is impact only on the left eye?
and another question that has been raised but the solution is not found:ШДен wrote:How to count the days, if breaks between listening to the Guide was made more than 3 days (well does not work to enable)?
tried to cross in digital mode for listening sessions Improv. Acted according to instructions
namely, the UP and DOWN buttons to choose the mode PPr, then was written the SELECT button to choose the mode of oPL (or something similar), but alas, the SELECT button like when you turn on the machine, flips through the categories of the sessions, i.e., RELAXATION, MEDITATE, etc.the SELECT Button to choose the PPr, click PLAY; click SELECT to choose oPL, click PLAY; click SELECT to choose oFc, buttons UP, DOWN to choose the odC; press three times the PLAY (to exit from all menus).
At the same time you can make a fun session i2 (and all others improve). To do this, you can not press the PLAY button after the previous settings, and the SELECT button to choose the submenu icS, where the DOWN button to select the value "15". If You decided to do it with "0" then goto oPL as described above.
I have Innerpulse buttons UP, DOWN to choose the PPr, click PLAY; click SELECT to choose oPL, click PLAY;click SELECT to choose oFc, buttons UP, DOWN to choose the odC; press three times the PLAY (to exit from all menus)
By the way, every time you log on to oPL, the program proceeds to standard oFc. And the "press three times the PLAY (to exit from all menus)" sets the function of PPr in the category of favorite (with the inclusion of Innerpulse always starts with it)
Yes: press UP, DOWN, and SELECT not to choose the PPr, click on PLAY - so accurate.
It is possible to go in PPr and put there your favorite session and click twice PLAY. It is possible to exit from oPL, press PLAY once, then turn off and turn on the machine.
Blood subscribe under Your words!!!Василий wrote:Well, about how life has changed, it is possible to write the treatise. Everything in the coupe - and a seminar on Lermontov Big Utrish, classes and with different drives. Hard to describe briefly - became a different person. Calmer, know what they want, has opened many new perspectives in life, manage their condition... Heaven and earth!
![Very Happy :D](./images/smilies/icon_razz.gif)
No, not a marriage.Make the most of the light on the machine,adjusting the volume on the player...Maybe the CD is of low quality,such devices are unable to REPRODUCE high frequency sounds,and audiostrobe signal recorded on a 19200 HZ...Try to listen to the disc on a stationary stereo system...Михаил wrote:When listening to "Explorer", a player we get the following situation: when doing a normal volume on the player and acceptable brightness of points on Enerpulse, the flashing occurs only in the left eye to blink and right need to make the light brighter. Or louder sound on the player, but then flashing glasses merge into a simple glow. Question: not married to this disk? How to tune in this case, if I do not want a very bright light, and thus there is impact only on the left eye?
Start the session improv.As soon as the 10-second OSCE and began directly session,press several times the button to SELECT the appearance of OPL,knop DOWN press several times until the ODC points begin to blink differently.If you want a quick change of stimulation modes-press several times the SELECT button until the icS,then knop down hit I think 3 times until the numeral 15 and enjoy.I have this operation takes 7 seconds...ШДен wrote:and another question that has been raised but the solution is not found:ШДен wrote:How to count the days, if breaks between listening to the Guide was made more than 3 days (well does not work to enable)?
tried to cross in digital mode for listening sessions Improv. Acted according to instructionsnamely, the UP and DOWN buttons to choose the mode PPr, then was written the SELECT button to choose the mode of oPL (or something similar), but alas, the SELECT button like when you turn on the machine, flips through the categories of the sessions, i.e., RELAXATION, MEDITATE, etc.the SELECT Button to choose the PPr, click PLAY; click SELECT to choose oPL, click PLAY; click SELECT to choose oFc, buttons UP, DOWN to choose the odC; press three times the PLAY (to exit from all menus).
Dimas: not the marriage - ie You do the same thing?No, not a marriage.Make the most of the light on the machine,adjusting the volume on the player...Maybe the CD is of low quality,such devices are unable to REPRODUCE high frequency sounds,and audiostrobe signal recorded on a 19200 HZ...Try to listen to the disc on a stationary stereo system...
Media - Sony D-NE 330 was good. I'll try at the center.
There are many of this "disease" I Have, too - I used to just make the volume on the player a little more when the difference in brightness between the right and the left eye is not strongly felt, OK!Dimas wrote:Yes!Still such a thing happens when copying CD's...I listen to native-it's all right,as soon as you make a copy (of high quality),stuff like that and appears (on the copy)!Need professional equipment (plant),what would you write these high...
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Fucking called it...ШДен wrote:There are many of this "disease" I Have, too - I used to just make the volume on the player a little more when the difference in brightness between the right and the left eye is not strongly felt, OK!
...yesterday turned on the guide, and blinking only the left eye and the right even at maximum volume just flashes
What could it be, who-NT knows? Can a disk re-recording or DVD-drive is clogged?
...well I had to listen without glasses
![Sad :(](./images/smilies/icon_sad.gif)
by the way, I understand that if without glasses it is possible the machine, to DVD not connected, only headphones and all? I correctly think?
>Damn nakarkat...
You do as I described here.
If you have a file Explorer with a DVD drive, then it has no audiostrobe :!: :!: :!: :!: :!: The fact that there is flashing is part of the entry "Explorer".
Plug L03 of innerpulse in parallel with the "Guide" effect is very strong. If your SAUCE is in the increased state, in a trance in 5 minutes - and out of his trance at the end "Explorer" - and no sleep :!: :!: :!: :!: :!:
For example, not even including SD disc, but only if you enable audiostrobe on innerpulse - on glasses already blinking diodes: the left, the right.
