We tried a new screening technology as part of U2, has received something of unimaginable power. Maybe someone has experienced the complete physical isolation including break podkluchit top/bottom/middle (in sujok called external chakras). That is the state.... when the slip force in 1/35 from high to flatten stopped, and can be used just as a powerful external screen. Conducted modulation of Pandora.
Then there was the use of the screen in hypnological practice for the protection of designated master/slave at the time of immersion/regression/cleaning.
Conclusion. A new EP will do with this technology as consoles to I2 (I see no reason to make a separate device despite the fact that I2 is pretty affordable if you are exercising installments). The maximum mode is not recommended to anyone - even my physics badly withstand long.
EP 5.1 - 6.4
Re: EP 5.1 - 6.4
Well, not quite so.... the new EP will be one of the additional (optional but simple and cheap) blocks I2. In extreme mode, it really shielding
just as a fur animal.
Re: EP 5.1 - 6.4
Yes, it is true, with some features.Анатолик wrote:Most probably it will be - interchangeable external emitter?!
I, as always, personal so to speak, a necessity of life forced ( not for myself but for important process ) to make
