New session for the Navigator
Вопрошайка
Thanks for the useful tips. Still trying to figure out how to put the frequency in the Navigator. As I understand it, there can only range to choose from. Is that so? Let me ask you this, is it possible for the Navigator to put e.g. the frequency of 1.05? If Yes, then how to do it?
Вопрошайка
Re: New session for the Navigator
I really liked how user Navigator. Almost immediately "takes". My mom had seizures, similar to allergic shock. After the first time she fell asleep immediately, after the second has left "wiggle", anxiety. My friend in his feelings, and he's a horror testy, before the next flash of something inside is locked, and he begins "to think".
First of all, to finally read the manual.Вопрошайка wrote:let me Ask you this, is it possible for the Navigator to put e.g. the frequency of 1.05? If Yes, then how to do it?
The frequency of 1.05 Hz in the Navigator can not be put, because the accuracy of setting frequency of 0.1 Hz.
Вопрошайка
So quietly you talk.
From 3 things. 1) On page comparison of mind-machines in the line indicates the frequency range 0.02—165 Hz, in the Navigator you can set the range 1-99 Hz. In the first case - it was a commercial move or I just don't understand something, then explain 2) You say that the setting accuracy is 0.1 Hz (see the example I was unsuccessful from 1.05 Hz, but immediately figured it out), I understand that. But how to set for example of 0.9 Hz? And facilities and sutorito sets the frequency range, not a specific frequency. 3) I Have something with batteries. All the time necessary to connect from the network. Should charging be enough for 8-10 hours. At the beginning of the work with the Navigator it was, and now, a little work and throws from the session (although before the work burns nearly full charged battery).
In Pathfinder there is an additional slow modulation, which is superimposed over the fast.Вопрошайка wrote:1) On page comparison of mind-machines in the line indicates the frequency range 0.02—165 Hz, in the Navigator you can set the range 1-99 Hz. In the first case - it was a commercial move or I just don't understand something, then explain
In the slow modulation period is set in seconds. To put the frequency in seconds, have a unit divided by frequency.Вопрошайка wrote:2) You say that the setting accuracy is 0.1 Hz (see the example I was unsuccessful from 1.05 Hz, but immediately figured it out), I understand that. But how to set for example of 0.9 Hz? And facilities and sutorito sets the frequency range, not a specific frequency.
This is to Alex (preferably in the PM to knock).Вопрошайка wrote:3) I Have something with batteries. All the time necessary to connect from the network. Should charging be enough for 8-10 hours. At the beginning of the work with the Navigator it was, and now, a little work and throws from the session (although before the work burns nearly full charged battery).
With new batteries it happens. I can advise to spend 3-4 kontrolno-training cycle, then the battery capacity needs to reach the declared indicators. Need to find:Вопрошайка wrote:3) I Have something with batteries. All the time necessary to connect from the network. Should charging be enough for 8-10 hours. At the beginning of the work with the Navigator it was, and now, a little work and throws from the session (although before the work burns nearly full charged battery).
- normal charger for 4 batteries, where provided, what capacity battery how long charge (by the way, the longer the charger are instructed to charge the battery, the less charge current, so battery will last longer) - it's possible that will do the job and the Navigator (recently do not follow the ROMs that do not know how it is now charging is implemented), and
- energy intensive user working from the same 4 batteries (e.g. lantern is the best option). You need to simply 3-4 times to FULLY discharge the battery and then charge as necessary (no nedoskazki or overcharging) it will swing characteristics to the optimum and partially remove the memory effect (loss of capacity due to violations of the rules of charging for different battery types, it appears an incomplete discharge before charging (Nickel-cadmium) or undercharge (Li-ion) - next time, he simply wasn't fully charged, there is a trivial chemistry).
Charging and discharging batteries is necessary all together, if one of the batteries will have excellent characteristics due to the difference of the resistances of the energy the rest is lost through it (and if you permanently leave the device with these batteries, you can contacts to oxidize).
I usually use my DSLR (she loves to eat) - put vegetarienne batteries to record video (3-4 hours, not longer, usually much less), and when the camera dies from low battery, I put a slideshow of pictures and put deeper (another hour). The flashlight can put them to zero, though it is not desirable - faded 2-3 times, and enough (it is better to take with bulb - led a few days can burn).<
The new session section Fun. Descriptions conform to the descriptions of the chakras in the Solar Wind.
Frankly, the session was not for entertainment - and not just listen sometimes (depends on personal problems) and the residual effect too, sometimes, "naglalakbay". But I don't know where to put, though a separate folder backwaters. In General, as with the CD "solar Wind", only stronger...
For "withdrawal" effects recommend Healing (Hlng).
Here I think - and they may not record at all into the GPS for use. Let yourself lie there quietly. Who should he find...
Hello!Андрей Патрушев wrote:New session section Fun. Descriptions conform to the descriptions of the chakras in the Solar Wind.
It was said that for Solar wind, you need a healthy spine. To these sessions is also critical?
Listen in alphabetical order?
Voffka
Yes, of course. On the other hand, is a medicine, although very bitter.
And how - "alphabetical order"?
Best of all (for therapeutic purposes): orange, blue, красная2, green, красная1, gold, purple, blue.
Andrew , what principle exactly this sequence? and that means red 2 and red 1. Something got confused))Андрей Патрушев wrote:best (for therapeutic purposes): orange, blue, красная2, green, красная1, gold, purple, blue.
LILY-P
Meditation for harmonizing the charkas of energy on Kastrubin.
red2 and red1.ЛИЛИЯ-Р wrote:what means red 2 and red 1
LILY-P
Well, Kastrubin, in turn, refers to yogis, but the source I could not find, although for me personally it works.
Pardon me , but I still do not understand why all the colors are written and then red 2 and red 1(ред2, ред1) ..what does it mean? Kundalini red and more red chakra there. Or I...or skis do not goАндрей Патрушев wrote: Best of all (for therapeutic purposes): orange, blue, красная2, green, красная1gold, purple, blue.
LILY-P
Yeah, so people are not confused.
Most, as You're too lazy to watch statement to the Solar Wind and match with purple red1 and red2 with the scarlet.
On the corresponding.Воффка wrote:Andrei Patrushev
While listening it is necessary to concentrate on the lowest chakras?
Дмитрий Никитин
- Has thanked: 10 times
- Been thanked: 10 times
Hello! Thanks for the new session! How many chakras you can work for one lesson? ( Session for 20 minutes ) that is how many of the sessions at the time it is better to use in one lesson?
Dmitry Nikitin
One.
One.
Andrew , and please tell me where should I paste yellowЛИЛИЯ-Р wrote:Андрей Патрушев wrote:best (for therapeutic purposes): orange, blue, красная2, green, красная1, gold, purple, blue.
Voffka
Checked - all normal. Perhaps You RAR not of the system.
