"It is useless to multiply entities without proper reason" (William of Ockham)
Well, so why did when there is a simple and convenient editor sessions???
I understand even if to do something semi-automatic, type:
- select the drawing session (as in Sutorito), segments are generated automatically;
- select time session;
- choice of upper and lower limits of stimulation frequencies (one frequency for all rows) or ranges, either manually;
- select the color for the series (I would put one color on all the rows, but with the optional ability to automatically change or select separate columns and not in rows);
- select the octave for the carrier of the series (I would put one octave for all ranks. You can automatically post frequency 0.5 Hz) carrier frequency is automatically selected (a multiple of the stimulation frequency). If there is no technical possibility to change smoothly at the same time es and carrier, then make the change of the carrier after transfer of emergency for 10% of the previous;
- select the automatic change of phases of the emergency (I would have left only two - 0 and 180), or without it. It should be noted that the choice of protivogaz virtually doubles emergency, so it should automatically divide by two with this choice. By the way, the choice of different colors for the columns can be automatically bind to a phase of 180;
- select the automatic change of the duty cycle, or without it (I would put the automatic change without choice);
- light with sound in phase or out of phase (I would put just without common mode choice);
pink noise is always 30% from the rest of the volume, and the choice of in phase or in antiphase. It should be noted that the choice of protivogaz virtually doubles emergency, so it should automatically divide by two with this choice (since there period, it's the opposite
- slow modulation in Sutorito, but now for light (as ritmicheskie modulation of the music missing).
That's all.
This can be done, in fact, almost all items via the installation/removal of a tick - that is, very quickly. If you want, you can save...<
