Suggestions for improving.
Кона
Re: Suggestions for improving.
Post by Кона » Sun Jan 08, 2012 0:38
How simple brightness!
Thanks!!
Кукловод
Post by Кукловод » Sun Jan 08, 2012 0:57
Димас wrote:about off indicator - sure to bring to the attention of the developer, this feature is easy to add in firmware
And yet, this lamp lights up continuously or goes out when you increase or decrease the brightness during a session. It seems to me that there is no need. And with the voice recorder like?
Post by ЛИЛИЯ-Р » Sun Jan 08, 2012 2:09
It would be nice to adjust the recording time of the recorder. 10 minutes is not enough. Is the idea something to try ,but ...
Post by Андрей Патрушев » Sun Jan 08, 2012 10:54
Actually the recorder was originally supposed to record personal affirmations, and travel writing. More or less sereznye things with the recorder difficult to do... simply take a regular headset and do on the computer...
Кона
Post by Кона » Sun Jan 08, 2012 14:00
About the flashing lights when turned off.
What I propose:
Even when you turn off the device light was blinking 2 times, to distinguish from the inclusion when it is flashing 1 time.
I.e. two times blinked - all the apparatus is turned off.
Кукловод
Post by Кукловод » Sun Jan 08, 2012 23:55
Андрей Патрушев wrote:actually, the recorder was originally supposed to record personal affirmations, and travel writing. More or less sereznye things with the recorder difficult to do... simply take a regular headset and do on the computer...
Andera, but in the same there is not any difficulties, make the ability to record voice recording on all available memory. Who needs less time will always be limited to the desired number of minutes. Moreover I'm not alone with this wish. az
And I have another question what is the maximum allowable size of the Flash memory can be installed in a Navigator?
КАА1970
Post by КАА1970 » Sat Feb 04, 2012 16:34
КАА1970 wrote:Exist or are planned counterparts of sessions i01-i04 of Photosonics?
By and large, all sessions of Pathfinder have elements of randomness, as in the sessions i.
Maybe it's overkill, but I would in this case would like to have the ability to record the playing session for re-listening. In the future it would be possible to organize the Bank of such sessions to share.
Post by Андрей Патрушев » Sat Feb 04, 2012 16:47
КАА1970
Please explain what You mean. Because this session is not going anywhere. :?
КАА1970
Post by КАА1970 » Sat Feb 04, 2012 17:30
Андрей Патрушев wrote:КАА1970
Try to formulate how I understand it. Here is a quote from the description of the improv sessions
8. Technology (improv). The instrument has 4 built-in (improv) session. The technology that each segment of the session when you run starts with a randomly selected frequency (in the frame specified for the session range) and has a randomly selectable by the processor the duration. Carrier frequency and phase are also selected randomly.
Ie is it always a new session. The result is a high probability that one day you will get a session perfect for you. There are of course a lot depends on the Sauce, but I think from the physiology of a particular person too. Once happened to me. Experienced a sensation similar to riding a roller coaster. And when it was over, one of the first thoughts was, sorry that it can not be repeated.
So, my question You replied that "in principle, all sessions of Pathfinder have elements of randomness, as in the sessions i". Therefore although the session is not going anywhere, but each time it will be a different session. And then again to listen to it will fail, even if they want to.
Post by Андрей Патрушев » Sat Feb 04, 2012 18:09
КАА1970
Clear. But within that range, as I understand it, the determining factor is the SAUCE... :?
КАА1970
Post by КАА1970 » Sat Feb 04, 2012 18:31
Maybe so. But life is often quite monotonous thing, so the SAUCE is standard.
СтАвР
Post by СтАвР » Sun Feb 12, 2012 20:52
use the day well, yet I still understand the complaints there, but the question is, and always prevents dushku of points?
just have your didziausia headphones, video monitor type that looks similar to those in the kit, well, darling way, and more points and with elastic band to do, I would have bought them :)
moreover I'm not alone, somewhere in the topic, I saw the message about the fact that hinder
and what are the headphones in the bundle? seen Logik wrote that Sven CD 830, and these are not similar
and what is the maximum supported memory card size?
and support only SD or SDHC and SDXC cards? well, in the case of micro random
СтАвР
Post by СтАвР » Mon Feb 13, 2012 23:32
and if you take the batteries 2700 on much longer it will work?
СтАвР
Post by СтАвР » Tue Feb 14, 2012 19:03
but no one thought of the idea to the points the Navigator to stick stickers obviously?
they are the same and with open eyes work :)
Post by Андрей Патрушев » Tue Feb 14, 2012 20:22
Stavr
Several people here (including me) are glued. :) Honestly, not much difference noticed. :?
СтАвР
Post by СтАвР » Tue Feb 14, 2012 20:40
Андрей Патрушев wrote:Stavr
ask ASD, and then I have two idle somewhere :)
СтАвР
Post by СтАвР » Tue Feb 14, 2012 20:44
Andrew can be to create a theme where we will be placing only the files for the Navigator(session, flash) can do to get it all
while the topic is not expanded, and that then newly would be difficult to find, and everything is in one place and will all messages to delete in addition to describing what a particular file :)
Post by Андрей Патрушев » Tue Feb 14, 2012 20:52
Stavr
Not far to seek. :)
viewtopic.php?f=38&t=4311
Topic is closed for comments.
СтАвР
Post by СтАвР » Tue Feb 14, 2012 21:24
then there is to move the session from the topic viewtopic.php?f=38&t=4695
Post by Андрей Патрушев » Tue Feb 14, 2012 22:29
Stavr
They will be there, when will the next firmware.
СтАвР
Post by СтАвР » Tue Feb 14, 2012 23:15
when you plan to exit?
Post by Андрей Патрушев » Wed Feb 15, 2012 1:35
Stavr
When you have any significant changes.
And while there is a folder library, where simply copying the new session load and as simple as basic, are used.
Кукловод
Post by Кукловод » Sun Feb 26, 2012 1:29
All welcome. Guys, so who-thread can answer the question what is the maximum size memory card you can insert into the Navigator and Expand the possibilities of the recorder?
СтАвР
Post by СтАвР » Sun Feb 26, 2012 23:57
and why when the battery gauge shows just under half the session played 5 minutes and goes to the main menu?
Практик
Post by Практик » Tue Feb 28, 2012 21:58
That's the type that PTS lacks the Navigator:
http://www.chi-card.ru/ekspress-kurs-english.html
