Navigator. Experience.
Post by Логик » Thu Aug 11, 2011 19:41
Ростислав wrote:I'm not even sure what we are in real life!!!!
I do in real life. Where are the others, that's their business.
Post by Маг.нет » Thu Aug 11, 2011 19:45
So no one interferes with check your realitybecause I specifically buttons and wheels have....
Okay You Rostislav while on pause, but... no, better is to question, to argue, and to take a check? How much real my reality???
Sincerely, MAG.no :o
Ростислав
Post by Ростислав » Thu Aug 11, 2011 19:52
Friends, tell me how much time charging the batteries? and how can I get charged?
Post by Маг.нет » Thu Aug 11, 2011 19:55
Okay, I'll go better with the Deconcentration decoder "50" drove, happy for the uniqueness of their Navigatorа.
:wink: Or its reality.......
Sincerely, MAG.no
Post by Логик » Thu Aug 11, 2011 19:55
Маг.нет wrote:So no one bothers to check his reality, because I specifically buttons and wheels have....
Well checked. Detector audiostrobe zero. This means that audiostrobe in the record does not contain. Flashing glasses reminiscent of the light and not audiostrobe. Sound above 40 naturally is not put...in my reality :? .
Post by Логик » Thu Aug 11, 2011 19:57
Ростислав wrote:Friends, tell me how much time charging the batteries? and how can I get charged?
I have not tried to charge in the Navigator. Charged on a separate charger. The charger recharges in 4.5 hours.
Post by Маг.нет » Thu Aug 11, 2011 20:00
*9 hours;
*extinguishes red light charging.
Sincerely, MAG.no
Post by Логик » Thu Aug 11, 2011 20:32
Fly in the plane Petka and Vasily Ivanovich
-Petka, instruments!
-120!
Cho 120?!?
-...and Cho devices?
Post by Маг.нет » Thu Aug 11, 2011 20:35
Photo from another reality:
Track: 1 of Travels in the inner worlds (in the set).
Sincerely, MAG.no
Post by Логик » Thu Aug 11, 2011 21:06
I figured out how you do it. I sound adjust the top buttons which are drawn speakers and sound above 40 is not raised. But if you start to push on the arrow buttons "up" and "down" the sound, too, is changing, and changing to 50, And x is changing not only sound volume but also audiostrobe! If the arrows to adjust the sound too quiet, audiostrobe is lost, although it should not.
Post by Маг.нет » Thu Aug 11, 2011 21:15
:) Here You another reality became available....
Success in learning! There is so much entertaining.......
Sincerely, MAG.no
Post by Андрей Патрушев » Thu Aug 11, 2011 21:24
In principle, the working edge of the matrix of frequencies almost captures my drives (besides the Endorphins) frequency audiostrobe, so it can operate on analogous decoder, and the digital, as in Pathfinder, do not have to like...
Logic,
Once again, I listened and watched the session R02Nb. Indeed, there is quite a sharp transition to sound, however, it is the same on Nova Pro. Session called Relax-and-Back - "relaxed and back." Apparently, back You do not want... :) I'll try to soften this transition into the next firmware.
Post by Логик » Thu Aug 11, 2011 21:41
Андрей Патрушев wrote:Logik,
Once again, I listened and watched the session R02Nb. Indeed, there is quite a sharp transition to sound, however, it is the same on Nova Pro. Session called Relax-and-Back - "relaxed and back." Apparently, back You do not want... I will try to soften this transition into the next firmware.
I actually complained about the surge around the world in session r02n without specifying which of the 4. I listened to the session with square - wave index "r"
I'm about the same effect and R05r found. Starts a surge in the light my eyes are watering, and the brightness of points on the minimum.
By the way, for some reason the brightness can not be removed to zero. That is on the dial the brightness value 0. and glasses still Shine.
Post by Логик » Thu Aug 11, 2011 21:59
Alexey Kryachko__ I think a dual volume control when playing files should be removed. Because when you change the volume arrow keys "up" "down" changes the work of audioscrobbler. This has already led and will lead to neponyatki. Here I repeat the message from the topic
"reports of problems with the Navigator".
Алеся wrote:please Tell us why in the Navigator are not included glasses with disks(A. Patrushev), in addition to Healing, glasses work, the detector 1, level 01. On other disks, for example, the Northern lights, illuminates the Detector 1 first 2 seconds and then goes back to 0 although I have tried to change the level, still the drive is not switched on the glasses, also I checked other discs, same problem. Ales
And just that simply she did not notice that pressed the button "up" "down" by changing the operation of audioscrobbler.
It is for this same reason I wrote about the different levels of audiostrobe on disks of A. Patrushev.
With value 40, all of the drives works fine, as soon as the level reaches 50 it is necessary to adjust the level of audiostrobe for each disk.
Else. Buttons often have to push without looking, by touch or in the dark. It is easy to click not the wrong button and change during playback in player mode, audiostrobe. And when the trance state does not want to make unnecessary movements and to find out why the change in mode of operation points.
Post by Андрей Патрушев » Sun Aug 14, 2011 12:41
There in both sessions included green.
Sensitivity to the color of the eyes is different (besides individual). For the alignment was provided setting: "Exercise" - "extra modes" - "Test signal". Koncami the brightness is set to the maximum acceptable brightness for each color and shape, but for some reason it is not working exactly as intended, rather, sets forth only a General brightness...
When testing I didn't notice it, because for me the difference is small. :cry:
Same setup I wanted to do for minimal signal, but Alex said it was technically impossible.
Thus, when You install the top (comfort) border brightness, be sure to check with different colors. Set a maximum for the color which You have maximum sensitivity, then during any session will avoid unpleasant surprises. A slight decrease in brightness for other colors does not affect the performance.
Re: Navigator. Experience.
Post by Логик » Wed Aug 17, 2011 10:08
Андрей Патрушев wrote:For alignment were provided configuration: "Exercise" - "extra modes" - "Test signal". Koncami the brightness is set to the maximum acceptable brightness for each colour and shape
Limited to 15, now not so bright.
Post by Логик » Wed Aug 17, 2011 10:13
Interestingly, sometimes after the sessions, the Navigator will turn off itself and sometimes not. Today I set the session before I go to sleep. Night woke up from a thin squeak that crackled through the headphones and the battery of the Navigator was discharged nearly to 0. The batteries were fresh, just before it charged.
Post by Андрей Патрушев » Wed Aug 17, 2011 10:19
Either the degree of charging is displayed incorrectly, or some other factors, but at the same nine holes in an open condition (without pressing any buttons) Navigator can be from one day to three, and then he turns on the signal...
Post by Логик » Wed Aug 17, 2011 10:25
The indicator showed the correct full charge, the batteries were charged on the external charger.
I have it already the second case. Just, for the first time did not write.
Post by Андрей Патрушев » Wed Aug 17, 2011 10:45
Логик wrote:the Indicator showed a full charge right
Why, then, in one case, this day, and in (ceteris paribus), all three?
Post by Логик » Wed Aug 17, 2011 10:55
How do I know? Before charging the batteries on the same charger, the GPS was a week and a half. On old, poorly holding a charge, rechargeable batteries worked 5 days.
Post by Андрей Патрушев » Wed Aug 17, 2011 10:59
And I'm not talking about work, and about "standby". :?
Post by Логик » Wed Aug 17, 2011 11:55
If the current consumption after playing sessions, will remain, for any reason, at the same level as during playback, the battery discharge is possible in a few hours. This is the only thing that can explain this problem.
Post by ЛИЛИЯ-Р » Wed Aug 17, 2011 13:15
Logik wrote(a):
Yes I know you have another Navigator. My not allows you to set the volume above 40. How are you worthy?
MAG.no wrote(a):Arrows.... Probably still another Navigator (individual) or:
Logician and Magician.no. If you listen to the recording of the Navigator, where it says Player ,Strobe recording,choose settings or leave that is ,then choose session, ie Explorer or ...on a sound up to 40 if button K2 to add and if you arrow up you and up to 50. This little trick. But on the basic sessions and the library only 40 arrows and no options above 40
Post by Логик » Wed Aug 17, 2011 13:57
ЛИЛИЯ-Р wrote:t e conduit or ...more sound to 40 if button K2 to add and if you arrow up you and up to 50. Tha little trick.
Actually, this guide is written. This dual regulation of the desired sound mode "synchrostart". The idea is that in the play mode strathpine, such regulation is not necessary and inconvenient.
ЛИЛИЯ-Р wrote:But the basic seseki in the library only up to 40 strelkami no options above 40
And the glory of God.
