Маг.нет wrote:of the Program P-flash drive that can consist and what ways of implementation mean, how they differ from active work with BJ Panacea?
whatever. The hologram is very easily programmed. In General, the bracelet is a panacea too. But for example we did the following for a colleague. Had I made the bracelet a panacea, off the panacea, which was recorded two other signal for one remote method of pulling out desired information from the known to us the existence of the artifact (of course with such jokes should be cautious
He asked such not-pakazany pakazany BJ.
I told him, demonstrating the efficiency and speed of the labels, made of two plastic circles portable super=fast copier. 5 stickers on one, 5 on another (could be less, I just the entire area of circles closed to increase speed and efficiency) and asked the algorithm to take info, and then several times to replicate. Put the source has already been modified by earlier bracelet, then switched BJ is not the panacea, it is recorded. To read and write (easy to see when the process is complete, you can even ask to report about that), went for about 2-3 minutes. The result - recorded BJ was a more powerful bearer of qualities than the original
ie testing was more detailed (relatively speaking).
Where efficient location of labels after programming?
in principle - necessary. Effective on glass and other transparent or partially transparent object (for example on the mirrors from the front side, then the beam passes twice, to OTR. layer and the back). But you can simply place the desired application.
is it Possible for them to program "mandala Stabilizer", both software and configuration?
Can.
But then it is better to combine with "hard" application. (laser printer, etc.), well, at least stick them on the printed paper. I.e. the stabilizer and the charging system BZ is still not quite standard objects of the surrounding world and with them all the more... difficult...
What are the parameters embodied in the program "House," as this program interacts with the Operator, if I consciously wish to create a "bias" in the space of the program, will it interfere? Or contribute? Will adjust one way or the other instruments structuring the space "alien signal"?
Sincerely, MAG.no
The system founded the house in the first place harmonious energy saturation space. To distort or to make friends with various other devices easily mentally. If you do not and if these devices distort the application of the program house, she can fix it - i.e. plug the device therein.
In General, the main advantage of holographic stickers that programmed it easier, a lot more powerful and clearer. Because, relatively speaking, with a powerful grip the ancestral system of physical reality on a very detailed level. There is not run over distortion and it increases the work efficiency.<
