1. I'd asked to put a human nickname that is associated with You as a person, otherwise I will not continue to answer your questions (these are my personal rules). Chosen nickname resonates with anything, except for You, hang on, beautiful in your opinion labels is to the point, when they have a real objective resonance and not the desire thereof.
2. бж2.0 other versions are not artifacts in the understanding of the theory known to You, they are manifestations of the world, not strain it. For this reason, the artifact, for example You mentioned 15ба You can easily wipe water or he "runs down" over time, and even BJ 1.0 - no.
3. from PP2. should be that Yes, you can, and with any. But because BJ all versions of slightly intelligent, and the axis of this intelligence - the wisdom of your subconscious mind, they can block inharmonious for You and the world of manifestation of the artifacts of any origin.
4. Overall, BJ can be used as an amplifier for anything, including arkanova artifact 15Ба. Your personal on desire. Many did so and, as far as I know, satisfied.
5. I do not know what severoceska practice (if only from the word syphilis
sorry for the banter), and in severocesky - Yes you can, although they are in some way a direct deviation from the harmonizing features of the BJ, but BJ first booster potential of the operator wearing it, and if the operator wants 15 BA or something else - it's his will, BJ has no effect, it is the directory-Podlaska and power station.
That's causing some conflict with his own subconscious may, if it believes such practices are unnatural for You.
Sorry for some sternest message, could not resist
Yes, You can try for example free matrix a panacea.
well, if You do practices, that of not free I would recommend the 2.2 not the 2.0, the difference is small, and the power is great.
PS BJ has links to sources of natural channels, it's late, artificial system wrapped in the tree of Sephiroth. Ie You can any of the BJ take the quality 15Ба serving it without bots (limiting the use of energy) in any quantity without tension, as you can upgrade (limit on the physics of the body) for the intended use(restriction to the set task).
In other words, the ability to use, in the presence of BJ You nafig not surrendered Arcania artifacts. Another thing, if You are very tight in the egregor of the school and the model of the tightly sewn into your consciousness, that is asistencialista and the method maybe You have simply will not work.<
