Hello!
I read (rather read) a large enough part of this forum, but I would like that someone has summarized and clearly answered the following questions (again
Please clearly answer the following few questions:
1.I'm going to seriously engage with these machines, which option mindmachine more preferable in the ratio the price/quality/performance/compatibility with other devices (as I understand Innerpulse)
2.The forum does not found reviews about Luma 10, what is the reason? What are the pros and cons of this machine, its capabilities?
3.Could you assess the value (as a collective term) of certain types of glasses? Could you offer two “best” points and the desired sequence of acquisition (if I'm not going to buy more than 2 points voosche and right especially)? Could you describe what points you want to use in the beginning of workouts in mid and advanced levels? (and how long at each stage) (corresponding to the previously selected machine, question 1)
4.What programs and how long you use a mind machine? (for example, with alpha work 2 to 3 weeks, then moving on to...)
5.Strobo what discs do you recommend to listen in the beginning? How long? (for example, Explorer cases, then, morning and evening, so many minutes, then...)
6.Offer specific recommendations regarding the convenience and efficiency of technical use of cars (for example, I use this kind of batteries, they are missing out on so much, I use these headphones because they give a cool sound)
7.Could you write the desired program and the conditions of training with the machine? (for example, to do so much with that before the appearance of such sensations, then move to the next stage)
8.What are the main challenges stalkivayutsya beginners using machines? Describe the main methods of their elimination.
9.Recommendations and links to where you can download software, music, Strabo, and other extra files and when, for what, how to apply and use these files
10.Important additions concerning the training with mind machine?
11.And even so what can I use player (flash) which will definitely be without loss of quality, to read the drives Andrew (after the corresponding copy on the PC)? Player which precisely reads Wav and costs around 2000-3500 rubles.
Sorry for the confusion and for the fact that You will have to repeat
Some of the questions you can not answer, because the answers are not hard to find on the forum.
Two years ago I found a device called Q-jump (here
http://www.tecon.com.ua/info-of-service10) what you can say about him. In this device used the principle of biological feedback on the basis of scanning brain activity, and in my opinion the training of the ability of mind control with the help of this device (or similar) several times on the effectiveness of training mindmachine. If I'm right? Also consider that the use of “open” points (q-jump displays monitor information about brain activity) together mindmachines and q-ump can give a really quick full mastery of the alpha, theta, gamma States. The cost of the instrument about 600 rubles green)
Also interested in your opinion about
http://egoland.ru/product/ this priborchik.
All in advance thanks for answers
