Visualization, or how to develop it!!?
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Wed Oct 13, 2010 18:00
Михаил_ wrote:anchor link is the previously obtained deformation.
The same person can from a single event simply changing your setup to a different experience.
That is, any negative emotion is a deformation of the cocoon? And how to evaluate negative/positive emotions, according to the General belief? they are sometimes wrong. Experience? Experience can also one and the same emotion can be interpreted differently, depending on the context. A pleasant feeling of anxiety in anticipation of the Exciting... a stressor... Pleasure is sadness... Joy of deliverance, etc. When I remember "the distant past" often ahead "pop up" memory files "is labeled" negative emotions, and only then, in the process of movement along a time line, a situation with a positive rating. Therefore, it is difficult to say that something is removed, but the "shaded" (that the soul did not stirs) it's like, but to actually "went out", as it does not fit. Just don't remember because not remember, it is not necessary, why, and the experience has...
Although there are situations... nipped.
Sincerely, MAG.no
Post by Михаил_ » Wed Oct 13, 2010 18:59
So I say about the change of context, to change the status entry in database.
Of course everything is relative, but it was more about a particularly vivid negative experiences, often called trauma, as they are, even if not visible on the body.
Post by Маг.нет » Wed Oct 13, 2010 19:24
Here on this bright wonder of the experience was partially "removed" (or deeply buried) description current time of life, ie not the entire file, and the description of one of the images of the "mental picture", the image is, but it is "not drawn", and although it was different. Description "this image" did not return? It turns out the line time point. As a "treat"? To change the context?
Sincerely, MAG.no
Post by Михаил_ » Wed Oct 13, 2010 22:47
to work with a certain multi-dimensional cobweb, in the area of this structure (as an object) to restore the structure while having different position of consciousness and will mean a revision of the event and its re-evaluation.
Just don't know how to explain what to do....
Among other things, not my profile, it would be necessary to pull the colleague and ask them to write a few creative words.
just try to work with this place as with a complex structure and being in the zone of consideration, to change what this moment would feel the need to change.
In the left hand take the entire stack V of cartridges, some of them have what we need.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Thu Oct 14, 2010 1:47
negative pattern to try to view from another angle of view to change the attitude towards it and the old unit out.promotion occurs by itself. The consequences are different.It all depends on your own attitude toward it.
Post by Маг.нет » Thu Oct 14, 2010 10:07
Михаил_ wrote:just try to work with this place as with a complex structure and being in the zone of consideration, to change what this moment would feel the need to change.
Have studied, the emotional background is almost zero (the position not involved Observer). The situation is as follows, the picture is, vibrant, stable, but "wearing the mask" on one of the images, you know why. How to remove the mask? Or rather "to cause" this way without a mask (to identify), the experience was "registered" without the mask, but after 7-10 days after the event mask appears and visible consequences - structural changes of the experience, influencing the visualization including.
Sincerely, MAG.no
Post by Dimas » Thu Oct 14, 2010 11:57
MAG.no
Here's what You have described above is described in F. Mikhailovich accessible language with exactly a vision psycholgoy and this exercise, a method of TMO is called :) If necessary, in a personal email address, send.
Post by Маг.нет » Thu Oct 14, 2010 12:15
The address is written in the profile (just above Your post). Thank you. With TMO superficially familiar... the Essence of this example is that want to "remove the mask" - does not work, although he was without a mask... to get to image able, to work through emotional polarity is obtained, but to restore a "broken file" in any way...
Sincerely, MAG.no
Post by Dimas » Thu Oct 14, 2010 12:21
MAG.no
Yes, do not bother to "files". What exactly do You want to change (only in human language)? You want to change your attitude to anything, emotional response, or what?
Post by Маг.нет » Thu Oct 14, 2010 12:53
I want to identify the way of experience (remember the face).
Sincerely, MAG.no
Post by Dimas » Thu Oct 14, 2010 13:03
MAG.no
If you need to remember, it is easier to a good meeting :)
Post by Маг.нет » Thu Oct 14, 2010 13:24
Dimas wrote:easier to a good meeting
alas, not helps... erased... although he is very good "there" (at this moment) come... My opinion by analogy with the PC, corrupted a system file that is "cut off" (shade) a whole branch of experience, deleting "certain" associated with image processing algorithm. I.e., further imaging, images are not copied from the template (experience) and the prescribed details, for a long time, but carefully.
Sincerely, MAG.no
Post by Маг.нет » Fri Oct 15, 2010 9:20
Маг.нет wrote:means that in the future for visualization, images are not copied from the template (experience) and the prescribed details, for a long time, but carefully.
This and see some inconvenience for visualization, design - "no problem," pulling images from memory, here is the question... the way (including momentum) is called normally, but the identification of the image with the man is on some other level (I know exactly who it is, but people do not see grey spot) and to "see" a person have to "pick" the parts, that it takes time. Earlier (prior to event) was different, the problems with the "portraits" were, here and find an "echo system failure" in this event. Back to back is not impossible...
Sincerely, MAG.no
Алекс711
Post by Алекс711 » Sat Oct 16, 2010 16:17
friend, but could it be simpler all this to state? best on konkretnih examples, pliz. and why so abstract? truth should be simple. it is, when understood..
I understand if you have or develop the ability to visualize something just send it in a positive direction, avoiding negativity in life.. that's all.
and then visualization, hallucinations, a real vision of devilry, or even "empty deceit" (AP. Paul, writing to the Colossians) - this is related things? (who-t above threw abstractly intimidating hint...). I don't think.
And how did my questions above? Andrew - where did you go? I also did not understand how to download this forum in a wedge. it is very necessary. pliz give a link / address line, and teleportpro I uploaded without problems. well, not all are notyou can read online...and I like to read very medlenno. S yvazheniem. Alex711
Новик
Post by Новик » Sat Oct 16, 2010 16:22
Алекс711
In in and the same everywhere(i.e. at all esoteric, and others like them the FORUS)
Demagoguery is one :roll:
And any filing practices.... and actually, having a unit(and maybe even less it will not check any how)
Алекс711
Post by Алекс711 » Sat Oct 16, 2010 16:27
... moj rodich' dalekii dopivalsya do takix sostoyanii, chto videl gallyutsinatsii chertikov. ("postychish' im po lby - i zvyk kak ot pystogo vedra")
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Sat Oct 16, 2010 16:38
In my opinion, on the first page of this topic was given some practical advice on how to develop. Another thing is that not one piece of advice or practice miracles can not give, anywhere you need to work. To start with the basics.
Visualization, hallucinations, visions and so forth, Yes, it's all related stuff, since they depend on the visual channel. Here dreams and lucid dreaming.
