МерКаБа wrote:Михаил_ wrote:"the third weekend go to the country, and each full moon, how can this be?".
not bad!
Michael why, the same Melchizedek says about the fourth dimension, where we will rise 4m. like all highly developed beings who possess the Christ consciousness and to communicate with their extraterrestrial maternal and paternal aspects? Besides, he often mentions about the materialization of thoughts and that in the fourth dimension, this materialization is instant. Plus teaches the Merkaba meditation, which, essentially, may cause the occurrence of the sidhe, including the realization of any desire.
What is the meaning of such pledged program???
1. You never know what someone said? He was there and saw him? And I've seen a lot of people we have extremely good your perception (possibly correct) to a different litter and that they instilled in the head other sources. Melchisedec by the way, I'm told its readers, himself wrote that among his sources close to hundred.
Cool batch of course....
2. Show me practicing this meditation, which is something that can. I'm gonna compete we'll see.
I've seen a lot of mighty people who can do many things. And none of them were followers of Melchisedek and not about what the Merkabah they say. Said the opposite - that everything is in man and man has just need to start using.
The way a person gaining experience, complicates its structure of the cocoon and this determines how well it can use a primary quality, which has everything (well, relatively speaking genetically inherent). The truth determines not only that....
So, this Merkabah looks like on the one hand as a kind of natural figure, but its action may be due to the simplification of the structures of consciousness. Type-thick and tough combs. Ie from merging experience of any kind, that facilitates the manipulation.
3.Just say - I think the author believes what he writes, he is only a translator.
4. Let's think, in which case the world is plastic to the extent promised M?
It's either a chip person left in the world that does not exist in the material and it will be plastic. Or status of postsmile in the first stage until the astral body of a person and builds imaginary worlds. Both has the same problem - not enough energy.
Possible another possibility is a splitting at a key point where the whole world is not stable, such as branching occurs in several variants, a small group of people in some very thin thread of reality. Separate to this group of people. Such a world would be terribly plastic (magic), but extremely unstable. Usually thin branches, short. It's like on a normal tree that you see in nature. The growth will be like imagine and all the rest without further measurements, only the physical properties of thin branches of probabilities.
In the first two cases the situation is generally problematic....since it deals with the death of followers. The third extended to her.
In all variants from the scene removed a lot of people not involved in the management system on the planet, but with the awakening abilities. Well, as I noticed on a nearby branch - it used to be easier, were burned at the stake...
Is the objective process of change in our world, but not associated with a dimension, rather, with some return of mogucnosti the world, contrary to the accepted artificially stabilizing factors.
When is there a artificially high population and population density, it threatens to conflict models in the world, which already increases the number of accidents and technical failures in the cities. But it doesn't shift dimensions, only the return is artificially stalled .
In addition different people may describe the same terms in a totally different phenomenon (something, again, reading) and Vice versa is one of the phenomena to describe in different words. So that one it would be a disaster, another may not.
For example I saw a version from a well known person on which these trite changes of dimensions is described as the awakening of human abilities (without direct changes to the physical layout), due to which people will be able to better manage the reality of the mental. These dimensions vosprijatija that were always there,but many drowned or degradable or not developed he calls the "great transition into a new dimension". Well, this is a peaceful option, not including terminology, normally coinciding with what I see really happening in the world.. But I wouldn't call it a transition and especially a great, but beautiful labels do not prohibit, the more they began to hang before.
It should be understood that an unstable world is not holding thought forms in physical objects, and therefore can not constitute an energy cycle, i.e. to maintain harmony and to turn inward man, so to speak "food" energy.
In other words, if the world loses its stability until it stops, it not only breaks up completely myself (i.e., degraded, and not progressing), but ceases to be a source of energy for people living in it.
All of the above is of course only my personal perception. Although I've been on the road especially listened to lectures on the topic of BM 10большой Arkan, is devoted to branchings of the world, it was interesting to not miss anything out of focus. It's funny, but even though I operate another model (however, in many areas partially overlapping with it) on the practical part, he described the processes around the same words, although the subjects of the lectures were related to the transitions between worlds, and not issue new dimensions. Just there, too, of the topic of narrow branches, manipulating reality and the reasons for the formation of forks, change the measure of mogucnosti the world and so on.
Contentedly said cover point by point the similarities of perception.
I this material had not listened.
Yeah, one thing I especially like is the handling of concepts, which no one has any idea and experience. Experience is accumulated gradually, so "we will deal with the aspects and have the consciousness of someone" is the field of questions - "and what he is Smoking???".<
