The danger of using SP.
Post by Dimas » Sat Oct 02, 2010 15:07
K-13
What,really??? :shock:
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Sat Oct 02, 2010 15:34
Dimas wrote:K-13
Yeah :cry: Can share the secret of making "harmful" SP, will be enemies to give :evil: ... Or potential customers to plant, to demonstration of normal devices heighten interest and more benefit brought :wiz . Although not the most harmful device of those that I collected - the same generator Schulze I do on almost a week down brought - still not fully recovered :roll:
Now working on "immunity" to torsional stress... anyone have the idea about this?? az
Post by Dimas » Sat Oct 02, 2010 16:30
K-13
No, better a secret right :)
Post by к-13 » Sat Oct 02, 2010 16:56
The right of the cake a secret - straight hands growing not from one place with his legs, and careful examination of the materials(at least in the next branch 54 pages). I the first time something of this was not enough... :oops: :?
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Sat Oct 02, 2010 17:51
K-13
did not understand what was the technical defect :?
Post by к-13 » Sat Oct 02, 2010 18:19
Incorrectly I wound the coil was not cleaned the crystal, which in combination with a few other small things gave the opposite effect of the entire device. If you want to repeat it - understood for a very long time and thoroughly.
МерКаБа
Post by МерКаБа » Sat Oct 02, 2010 18:24
Ie if you take for example soup Humpty, then you have a coil wound opposite?
Post by к-13 » Sat Oct 02, 2010 18:50
You decided to learn how to do a harmful cake? :oops: Not quite the opposite - I twisted and four wire, and the "toroid" clockwise, and the direction here is different(the wire is twisted clockwise, and the bagel against the wound, as it should be)
МерКаБа
Post by МерКаБа » Sat Oct 02, 2010 19:03
I think the trick is in the bagel. The Humpty wound counterclockwise - energy radiation. If wound clockwise, pruim the absorption of energy that is likely to lead to negative consequences.
And the wire Mobius, I think pofik how to twist, at least at Logan and other avtorjev said so.
Post by к-13 » Sat Oct 02, 2010 19:18
I may be there is something misunderstood(except that the toroid or the Tesla coil, the cake doesn't suck, or emits itself - its purpose is to distribute the duty signal in a uniform field with a peak value at the center of the toroid, that is, on the crystal, that is, modulation of the duty signal of the whole device in General), but in this figure, a mark. Humpty is also doing so.
See next to the drill mark rotation for ClockWatch ContrClockWatch of a donut and Vice versa. So it's not so no matter how to shake that bagel... With opposite winding touches the wires parallel to the crystal, and at collinear and perpendicular(now wound quick,take a picture, post). Now, these coils on the crystal in a completely different influence.
Post by к-13 » Sat Oct 02, 2010 19:34
Under normal(wound in opposite directions), upper(I the first time such a wound) behaves on the crystal generally unpredictable. Add custom components(vectors with themselves) and will get a harmful cake.
Сергей Битков
Post by Сергей Битков » Sat Oct 02, 2010 20:32
K-13
Here is the link, tested works.
http://www.matri-x.ru/forum/index.php?a ... h_id=13801
МерКаБа
Post by МерКаБа » Sun Oct 03, 2010 0:23
K-13
:ay
МерКаБа
Post by МерКаБа » Sun Oct 03, 2010 1:50
it turns out Humpty, an example of the correct winding can be a coil with amethyst: wire - clockwise coil - against?
Post by к-13 » Sun Oct 03, 2010 10:48
Not really(sleepy wrote yesterday, a little confused, now all fixed). Harmful turned out it was the coil, which touches perpendicular to the crystal, and as effective as possible - in parallel, that is, a mandatory requirement is close to the 45 degree angle of the strokes in a smooth plait. Poorly twisted wiring in the doughnut shows no harmful properties at all(in a smaller cake had the same incorrect toroidal coil - all clockwise, but the wiring subscreen, and he is somehow not working in General). Besides, it becomes harmful after getting the crystal(others did not try) and powering...
As I understand it, the reason is that the parallel strokes to create a dense twisted transversely(relative to the growth axis and the polarization of the crystal) field, which somehow spoils the crystal - it in time loses its properties, so apilco-weight epoxy starts to throw excess collected orgone without conversion, that is, as the camera of Reich in man-made conditions, it becomes harmful.
МерКаБа
Post by МерКаБа » Sun Oct 03, 2010 13:12
к-13 wrote:Harmful turned out it was the coil, which touches perpendicular to the crystal, and as effective as possible - in parallel, that is, a mandatory requirement is close to the 45 degree angle of the strokes in a smooth plait.
к-13 wrote: As I understand it, the reason is that parallel strokes create a dense twisted transversely(relative to the growth axis and the polarization of the crystal) field, which somehow spoils the crystal
Probably you mean are perpendicular.
МерКаБа
Post by МерКаБа » Sun Oct 03, 2010 13:20
Coil Logan. Indeed, the maximum strokes parallel to the sides of the crystal.
Post by к-13 » Sun Oct 03, 2010 14:05
Well, it's Sunday :oops: The brain probably took a day off :? Thank you
Свами Доупаду
Post by Свами Доупаду » Sun Oct 03, 2010 19:06
к-13 wrote:You decided to learn how to do a harmful cake? :oops: Not quite the opposite - I twisted and four wire, and the "toroid" clockwise, and the direction here is different(the wire is twisted clockwise, and the bagel against the wound, as it should be)
-But after all, Logan clearly shows how to wind the spool clockwise, and the harness-V.. :?
Post by к-13 » Sun Oct 03, 2010 20:29
Свами Доупаду wrote:-But Logan clearly shows how to wind the spool clockwise, and the harness-against.. Confused
Or Vice versa... And many do not adhere to any methodology))) like think so:
МерКаБа wrote:And the wire Mobius, I think pofik how to twist, at least at Logan and other avtorjev said so.
I've been experimenting with "bagels" until only one option is really harmful, it's amazing as I first time managed to make for themselves...
_Алекс_
Post by _Алекс_ » Mon Oct 04, 2010 5:42
к-13 wrote:didn't clean the crystal
I have a question about cleaning the crystal! Tell me how to do and what to do to clear the crystal, for example by pollution or just a routine cleaning of the crystal?
Thanks for the reply.
Post by к-13 » Mon Oct 04, 2010 8:54
If there is a well or borehole, it is possible to bind it to snorna and lower back for a few days, if there is clean running water(from land, not from water), it is possible with 11 to 12 at night it to put under her(I don't know why this time is the most advised way of working), others have not tried...
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Oct 04, 2010 11:10
...and why Moebius-Koil? Maybe because I do not have self-inductance, this means that it can resist the flow of electricity, at the same time without causing magnetic interference.
The efficiency of the direction of winding may be noticeable, but the damage???
Sincerely, MAG.no
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Mon Oct 04, 2010 11:29
к-13 wrote:under normal(wound in opposite directions), upper(I the first time such a wound) behaves on the crystal generally unpredictable. Add custom components(vectors with themselves) and will get a harmful cake.
Hmm... coils look the mirror.
Ie You want to say that the direction of the Moebius effect on DOR/POR...
Interesting PTS...
Don't even know
and where You have put the thought on the "bad" device?
He survived?
And if his "flip"?
PS
I was thinking about device with dorom, but those who know, those silent :?
I don't think there is one coil everything is solved.....
МерКаБа
Post by МерКаБа » Mon Oct 04, 2010 12:47
Now trying to remember how it was my decision. Accurately determined that the coil was wound counter-clockwise, but the wire Mobius't remember, but it may be that, in the same direction.
Humpty Baltay
Mobius can clockwise and against to be wound, but the wire should then be twisted in the opposite direction.
And as I had not seen these inscriptions: spin drill for CW CCW coil
