Neurofen
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Sat Jan 08, 2011 11:32
Экко wrote:maybe just neurophone there are different.
neurofen - the common name of a group of devices, and the approach to obtain the result might be different...
In the net read about new developments for the IPhone that allows you to "mentally manage" notebook etc. and options to "feedback signals" on the same channels. But so far as I understand this is only a development (with available results), we will see after the "coming out" - what it really is...
Sincerely, MAG.no
Николай3003
Post by Николай3003 » Sat Jan 08, 2011 16:31
Yes, but there would at least some of those data would be where to start especially about echofon write that about a week you need to listen with closed ears in order to teach the brain to perceive more or less clear the signal. So without those data there is little that would make!
Экко
Has thanked: 2 times
Been thanked: 4 times
Post by Экко » Sat Jan 08, 2011 16:57
what is it actually...
certainly not neurophon in the original sense of the word. The patent is actually for real neurofen is, and as if pretty good so far don't have the right to make their device under the same name.
Николай3003
Post by Николай3003 » Sat Jan 08, 2011 17:07
and your as promotion in picking up the scheme ???
something somehow or is a lull?
Post by Маг.нет » Sat Jan 08, 2011 17:30
Экко wrote:certainly not neurophon in the original sense of the word. The patent is actually for real neurofen is, and as if pretty good so far don't have the right to make their device under the same name.
an Amazing system created by computer scientists from Dartmouth College (Dartmouth College). Called the new "Neurofen" (NeuroPhone). It reads brain activity to control applications of your phone.
As a provider of information about the activity of neurons, the authors of the project used the latest generation of brain-wave reader EPOC headset from the American company Emotiv Systems, a pioneer in commercial computer-brain interfaces (BCI).
All the same, they call it "Neurofen"...
Sincerely, MAG.no
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 7:31
With the come you Old N.G.!! How about the overall theme?
I gave you to look at your echofon and scheme sites two local physicists from the Institute of applied physics, was dismantled into small parts echofon. Of special delight was not
echofon to improve the quality and volume and to remove the percentage of distortion can add another pair of preobrazovatelei is also possible. But in order to stick these preobrazovateli to the heel or the ass, and the sound was in my head heard you say 2 methods can be used. 1) or it is the effect of a jackhammer or hammer and power will have approximately the same pose as this audio signal has to pass through the entire skeleton and to reach the brain and signal poteralsa so it would be in the handset at best, but that's what eventually will become the skeleton from the constant y.z.and. have podumat. And another trick is that in the net write what people can perceive about 100 kHz there in a leather conductivity but where to get such a signal at the input in addition to dolphins and bats?? SD produces 24 output !!! 2) the method is fantastic if you pass through the electrical impulses in the neurons but it should be the processor that encodes the audio signal into an electrical impulse and to learn how to code so then his brain was rasskazival back to sound !! Like this !!! If you have something new to share opinions or accomplishments
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 7:41
Now, if he ask for Andrew P. just take a picture of the inside of neurophone but so could the numbers of schemes to read or else he would have known that and how because echofone by ultrasound and does not smell like that!!! Ie echofon is 5 minutes ' to gather there meaning two pairs of headphones only preobrazovateli give strictly higher frequencies and all. Some with creeping tracewatch. And the ultrasound stuff. Or I have left echofon!!! But like with S. sh.And.
Николай3003
Really need vnutrennost of neurophone
Post by Маг.нет » Fri Jan 14, 2011 10:05
Николай3003 wrote:2) the method is fantastic if you pass through the electrical impulses in the neurons but it should be the processor that encodes the audio signal into an electrical impulse and to learn how to code so then his brain was rasskazival back to sound !! Like this !!! If you have something new to share opinions or accomplishments
http://www.emotiv.com/store/hardware/299/ -this device can help to explore causal interactions part of Your gadget with the human brain, i.e., a decoder of the effects of different kinds of impulses to the brain, because reader feedback... developers NeuroPhone used it...
Sincerely, MAG.no
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 13:26
can't properly link to write
well, enter the sound through the skin into google and the first link http://www.skif.biz look I don't really think that the device was in ' 69 even
Post by Маг.нет » Fri Jan 14, 2011 13:31
The topic is relevant. The study conducted many years...
Sincerely, MAG.no
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 13:34
skif.biz
Николай3003
how to write a reference for this nonsense emoticons don't pop up
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 13:35
Николай3003
in Google the first link to the topic of our cute dialogue
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 13:37
the fact that learning for many years but not 14 year old boy at home all these tricks now can believe but not then there must be something easier I think
How would Andrew even photo neurophone to change your mind ???
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 14:40
Electro hearing aid emulator
don't know if this is the place to be but the idea is fun
Post by Андрей Патрушев » Fri Jan 14, 2011 22:02
When writing a message to set the check box to "disable smileys" :?
Post by Андрей Патрушев » Fri Jan 14, 2011 22:06
Николай3003 wrote:Really necessary vnutrennost of neurophone
Yes, easily, you as soon as I figure out how to take it apart and get a picture...
Николай3003
Post by Николай3003 » Fri Jan 14, 2011 22:50
Andrew so even so does your neurophon from the bones of the skull, or through leather, the conductivity and if it's a few words about Radnice in the perception of the signal by the brain through echofon and neurofen I understand you have one or the other is
Экко
Post by Экко » Sat Jan 15, 2011 9:51
but the sense "take a picture", not to be seen at least half of the marking elements to the circuit Board to make the concept necessary to keep it in his hands, and it is very time consuming and tedious process
Экко
Post by Экко » Sat Jan 15, 2011 10:00
AM modulation at 100 KHz
Экко
Post by Экко » Sat Jan 15, 2011 10:04
And ultrasound stuff. Or I have left echofon!!! But like with S. sh.And.
and then what is written here? http://www.mindmachine.ru/echofone/technicalinfo.htm
Николай3003
Post by Николай3003 » Sat Jan 15, 2011 12:46
I know that napisano but there is no outlet, no tricks 20 KTS
and all we need is a limiter at 20 kHz is could though 35 supply to distortion was less. As I understand echofon is vostanovitel lost over time of low frequencies through preobrazovateli others did not hear, and addition to regular headphones
Николай3003
Post by Николай3003 » Sat Jan 15, 2011 12:47
well, about the pics at least get
in echofone us 5 seem schemes and what is AM modulation at 100 kHz??
