Club
Идущая вперед
- Been thanked: 6 times
Новик
Don't know how to take the initiative, but noted the last time such a coincidence, as if the rain turns to negotiate, although only at home...Новик wrote:rain in Moscow and Moscow region
The cottagers need watering - here keep...
In city rain, only to go out from the car or office - he's on time, sometimes in a confined place - dry see the border of the rain... Noting this property, make humorous predictions in a circle of friends and colleagues, while the probability of 100%, fails, and discouraged...
Ready to participate in the promise of rain tuch Moscow.
Sincerely, MAG.no
Although Roshydromet says:
"MOSCOW, 12 Feb — RIA Novosti. The whole next week, from 13 to 17 July in the centre of Russia will be a heat wave, the temperature will be above normal by seven degrees or more, according to the press service of Roshydromet.
"From 13 to 17 July on the territory of Central Federal district is expected to abnormally hot weather, the values of daily average temperature of air will exceed climatic norm by seven degrees or more," — said in the message.
Maximum daytime temperatures in this period will amount to 30-35 degrees, say meteorologists."
Sincerely, MAG.no♆
Sincerely, MAG.no♆
Новик
Device (radionic in particular) does not own the algorithms and experience, it is the task of man. Weather is much outside of normal human activities, so just the desire or the wording is not enough.
A number of people possess the necessary experience subconsciously use it, others can get it, but in any case you need more than desire.
In this case, the problem is that we have a rather global process, with the presence of the past and the future and probably have some other interested parties.
Ie to change the position you need the intervention of more than one city, the perception of weather processes as a whole, as the impact in one place, immediately alters the balance everywhere. If it's dot, it will not last long.
PS a colleague of mine on Saturday, really wanted rain and it has always been and probably hooked the edge of Moscow (watered piece of the Yaroslavl region). Along with this for some time became much cooler. However, the wind, which was before that .......... reminiscent of the little mini whirlwind.
Devices, such as amplifiers intentions... Yes, another "powerful amplifier" hooked up, so without a little mini whirlwind not doМихаил_ wrote:Device (radionic in particular) does not own the algorithms and experience, it is the task of man.
Sincerely, MAG☂no ♆
14.07.2010, 13:14|IA "of Meteonovosti"
On the duration of the July heat in Moscow
July is the warmest month of the summer. Today such a definition is justified. Even the weather is abnormally hot. Over the past 13 days of temperatures above 30 degrees is marked 4 times.
What was the heat of July in Moscow in 130 years of meteorological observations? In 1882 and in 1897 the number of days with temperatures above 30 degrees was 10 , 1885 - 13 , 1936 - 16 , in 1938 - 17 , 2002 - 8 days.
Continuing in the coming days, the heat in Moscow, of course greatly adding to the Treasury of days with temperatures above 30 degrees. And maybe this year will be close to 193_ or 193_ years.
Sincerely, MAG☂no ♆
Sincerely, MAG☂no ♆
Идущая вперед
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
In one hypothesis about the destruction of Atlantis says that Atlanta has reached the highest level of technical progress. Then they swung to the reorganization of space and started to create some huge Merkaba. As a result, the curvature of space and as a consequence, the disappearance of the continent. This is just a hypothesis, but if in it there is some truth, then this knowledge may well be a warning for people with capabilities that exceed the capabilities of the average person.
This is just my assumption, but who knows? The pull on the experiment, but I stop myself. Michael's right when he says that what is happening now with the weather, the outcome of deeper processes. But if these processes do not like Your intervention?
- Шалтай Балтай
