I'M BUILDING A PYRAMID
Алексей Кузнецов
- Been thanked: 1 time
Bioresonance very interesting and quite professional here http://biorezonans.3bb.ru/. This forum has already been mentioned. Quite a lot of practice, and not just the book examples.
Алексей Кузнецов
By the way on energy and its different impact on different plants is an interesting research http://www.aires.spb.ru/RUS/02/0201.htm
- Вадим Перелыгин
- Been thanked: 7 times
- Вадим Перелыгин
Purchased, reproduction, don't know, don't tend to disassemble
I think not difficult, adjust generator+resonator. Efficiency, only antiparasitic program was held (though not had them ever
about whom you know). The relative for whom I purchased the device, treats varicose veins, says helps seen nodes decreased and the redness has subsided. Bought new at half price, not more expensive than SB.
3 in 1
1. Endogenous bioresonance therapy is conducted with electromagnetic oscillations in the range 0-100 MHz, which are removed from the surface of the skin, are processed (modulated) and transmitted again on the body. In the process of therapy patient and apparatus form a closed circle adaptive management to return to homeostasis.
2. Exogenous bioresonance therapy - therapy with sinusoidal currents of variable frequency 0.1-10000 Hz, is used the frequency spectrum of brain wave frequencies (Voll, Schmidt, rife).
3. Anti-parasitic correction of the environment is a sine wave between 100 and 900 kHz, according to the method of Dr. H. Clark.
Is programmed as a sequence of pauses, and individual settings for scanning and transmission fields (a possibility wave swing).
Specifications:
The signal polarity of electrotherapy: bipolar sinusoidal
Output signal amplitude: 5 volts
Frequency range effects: 0-900000 Hz (by 0.01 Hz)
The frequency range of signals being processed: 0-100000000 Hz
Signal form: sine
Power supply voltage: 4.5 volts
The same manufacturer produces a light version, just COPPER in the form of bulk medallion on his chest, valued at half-price.
Sincerely, MAG.no
3 in 1
Specifications:
Signal form: sine
Sincerely, MAG.no
- Вадим Перелыгин
Алексей Кузнецов
Here I read information that results in a respected MAG .no wonder her. Nikokogo specifics on the results and net book words. Driven me above the forum bioresonance a lot of specific information and so the question arises, is it true that they promised the Magician .no? As in any industry to any idea you need to make at least kake or evidence of its reality. Here we see the results of Vadym Perelygin on the topic "the Pyramid" and see that there are "nuances". Well respected in the MAG .net technical specifications that in addition to "letter and figures"? So do not unseemly. There, on the forum bioresonance indicated how problematic opredeliti the presence nekotoryh "animals" in the human body. Specified the astronomical errors in these tests and here pushed a priori information about the "healing" properties of homicide adaptations. I repeat, so do not unseemly. The facts and measurements in the Studio. So where is the electric field, everything can be measured.
- Свами Доупаду
-Thank You,Vadim .Вадим Перелыгин wrote:The diagram in the bookСвами Доупаду wrote:-And the scheme-that where to take ?![]()
Download the book "there are no Incurable diseases" (PDF)
on the website http://www.neslimo.eu/neboley/zapper.htm
or scheme in England.var.
http://www.ryanmcginty.com/orgone/freqgentutorial.htm
PS - that's interesting infa on topic: (there at the end of the page book )"
http://www.wands.ru/txt/lnk_001r.html
- Вадим Перелыгин
Yes... the idea of Helen Clark and the captivating simplicity of its devices, gathered in a Shoe box is far from obvious. After reading the long thread on the website
http://biorezonans.3bb.ru/viewforum.php?id=4 did sample:
Talented hardware engineers and doctors for 3 years working on the validation and implementation of this idea. Many unscrupulous companies just make money on this idea - the panacea. And the statistics of the positive impact only about 30%. She H. Clark died at 81 from cancer of the blood. I assume that a lot approvals. In the end, I came to the conclusion that her zipper is not a "parasite fighter", but only an activator stimulus of the immune system. The unskilled experimenters immune system is suppressed, and which even then struggle with pathogens. And all of these dynamics can be viewed clearly on blood tests, and just for being.
To the question "How and what to measure physiological changes in the person as a result of exposure to radiation of the pyramids, bio-resonance devices, Radionics, orangenation, chem.drugs, and other things.
Here http://www.mindmachine.ru/posting.php?m ... te&p=44089 and here http://www.neurotek.mpi.ru/index.html
Described budget(10t.R.) a very compact device "of ANAS". Computerized analyzer of the slow electrical activity of the brain registers the so-called level of permanent brain potentials (SCP) - an important indicator of the harmonious working of the human brain. Allows you to find out what factors, procedure and condition harm the body. "What's good for me and what is harmful?".
Too bad that it has no direct interface with a PC. It would be nice if they'd made it as a console to the laptop or PDA!!!<
- Вадим Перелыгин
a lot of information on the use and manufacture here, but the material is sooo much
http://veche.stezya.ru/index.php?showforum=18
- Вадим Перелыгин
Vyacheslav
Thanks for the link. Yes... something very much! I'm afraid to even start. Probably will return to the triad(wormwood, cloves, walnut tincture) once a week.
In any case, you have to get hold of the status monitoring device. Or EEG "of ANAS" or Acupuncture office of su Jok therapy http://www.theramax.ru/razdel/26/ or Acupuncture device "Eastern doctor" http://www.theramax.ru/razdel/72/ since it is not clear what and how it affects you...
Сверхпроводник
- Has thanked: 14 times
The topic is interesting, but the reviews on instruments almost none from real users!
Basically it all comes down to resources similar to the discussion between proponents of BRT (BRT...) and supporters of the official. medicine, and sellers different devices.
Here there is still a little. (recognize IMEDIS, detu, and biomedis)
http://medicinform.ru/index.php?showtopic=9317&st=0
Anyone used similar devices? Interested in their effectiveness.
What are the criteria to evaluate the effectiveness?Сверхпроводник wrote:has Anyone used such devices? Interested in their effectiveness.
1. (-) a long time of treatment - 1-2 times daily for 45 days.
2. (-) lack of intermediate results - the treatment is a "wave train" the body, training the immune system, to further maintain a healthy state by the body.
3. (-) to assess the effectiveness of the necessary diagnostics, preferably the wave, before and after treatment. +The control after 45 days.
Only after you can estimate (+).
The minimum time (antiparasitic program) more than 1 hour. It is only at first sight 7 minutes, in fact, a one-time (full procedure) this is three times 7 and 2 x 20 minutes (mandatory break between sessions) a total of 1 hour, 01 minutes, plus a break of at least 20 minutes (in reality we have more than seconds to measure).Гость wrote:1. (-) long - time treatment with 1-2 times daily use
Conditions treatments: posture (recommended when listening to CDs A. Patrushev), relax, keep movement to a minimum and stress the limbs should not be crossed (the device is signaled when even just nervous or stood up)... by the Way, recommendations of water (Usually 2 glasses) - similar.
To accelerate achievement of effects, the number of procedures can be increased threefold, while the course of treatment - not less than 30 days daily, with "the rest" for more than 2 days, the count of procedures required to start again...
There are programs for the revitalization of the chakras.
Tried 7.83 Hz - works (there is nothing to compare)...
Generally more than 1000 recorded programs (plus an upgrade), this year has a few innovations (user request) added. Nonresident uncomfortable, you need the device to send it to the Manufacturer with payment and return shipment.
Sincerely, MAG.no
- Вадим Перелыгин
Excuse my stupidity, what is the device and who the manufacturer is? Biomedis for 13500руб ?Маг.нет wrote:specifications:
Signal form: sine
The same manufacturer produces the light version
- Вадим Перелыгин
EEG of ANAS immediately shows the red lamp burning - means for the brain such a regime is harmful.Гость wrote:what are the criteria to evaluate the effectiveness?
Bought as a gift for family member for New year party Affiliate programs, like 7500, but for 200-300 I could be wrong. A relative and close the device at hand...Вадим Перелыгин wrote:Biomedis for 13500руб ?
Sure the device is working, but how useful not presume to say, the test only antiparazitarny (recommend first to take this course including attunement), but gelmintov had more specifically to assess, do you first need to be diagnosed for the presence. Although the list of programs is very extensive.
Sincerely, MAG.no
The work is not with the brain signals and wave signals of the cells of the organisms, so that the AMEA little clear...Вадим Перелыгин wrote:EEG of ANAS immediately shows the red lamp burning - means for the brain such a regime is harmful.
It's worth the wave diagnosis (a very long time this service is introduced) and much will become clear, theory, and practice. The essence in my opinion is, each cell of the body has its wave range of radiation. On the wave characteristics possible to judge the presence, health, or the absence of cells and organisms in the body. The disease of the organ or cells distorts the signal. Modulating signal a diseased cell or organ to a signal healthy cells get recovery. Something like that.
Sincerely, MAG.no
Сверхпроводник
Of ANAS and then. For the diagnosis need to undergo Vegetative Resonance test / diagnostic on the equipment IMEDIS or DETA, write about it on the forum biomedis and others.
MAG.no
Bought b/y the previous model or the new model, which on the website is sold for 12тр?
Passing the General antiparasitic program 4000?
Maybe some felt or chalked it up to BJ and so forth
Ie not just working (passes the signal e., flashes, etc.), and treats!
Here and interested in user opinions screened (or at least on personal feelings) that were treated with these devices.
And what I wrote is all there on the manufacturer's website.<
MAG.no
And worming you can not just see, they are small in size and can be digested in the intestine, they may be few, and so forth. And parasites doesn't have worms, and viruses, bacteria, fungi and all sorts of different...Bought as a gift for family member for New year party Affiliate programs, like 7500, but for 200-300 I could be wrong. A relative and close the device at hand...
Sincerely, MAG.no
Suitability for treatment of those diseases which are listed in the appliance manual and on the website!Гость wrote:what are the criteria to evaluate the effectiveness?
