Tree.Ванька-встанька wrote:Power regarding 2000 program
missed
stsylku Mona?
I have no chuystva meet these numbers.Шалтай Балтай wrote:So
table ACC. the scale and frequency:
Code:
| Rate| Hz |
| 0 | 0,60 |
| 2 | 0,65 |
| 4 | 0,71 |
| 6 | 0,78 |
| 8 | 0,85 |
VVVVVVVVVVV
If I am not mistaken this is called the "rate book"Ванька-встанька wrote:Found table in the Net? I have not yet found
Some Radionic books will tell you to record any rates you take into a special
rate book so you can easily use them again later without having to recheck the
rates again. I completely disagree with this concept for 2 main reasons.
The first reason is that its very good practice for you to tune the machine each
and every time instead of relying on a previously obtained rate. This will
greatly improve your ability and confidence in using the machine.
The second reason is that I have found most of the rates do not always stay
exactly the same. This is because everything changes with time and therefore
The Magick Power of regarding, Psionics and Orgone
its rate also changes. Because of this it is necessary to check the rate each
and every time you use your machine. In healing work it's even a good idea
to recheck the rate every few days because as the healing begins, the healing
rate usually changes slightly throughout the process.
http://www.mindmachine.ru/viewtopic.php?p=41410#41410Ванька-встанька wrote:Maybe the administration will go to meet You as 1st buyer and will give the time (or more like something - don't know) to use for reviews (or something - I don't know). And though we'll see: a THING or a "thing in itself" this radionic
Yes, it's possible...Курт wrote:keep in Mind this. Output energy dependence on external technical device. Internal mechanisms gradually atrophied, and there is complete dependence on batteries, which can break... then What?
