Disk A. Patrushev, "Journey to inner worlds"
Павлум
Павлум
Павлум
то лучше - визуализироват
Павлум
Andrei Patrushev
So, the first result.
The test showed (4 tests during the evening) that the percentage of guessing the color card in my case - 42% (16;13;15;15 out of 36, respectively).
Method of testing - with the deck lift the top card with tightly closed eyes, abruptly turning her to him, trying to see through closed eyelids.
The CD was listened to with a machine, sitting in the half Lotus. Meditation is qualitative - not knocked out not once, but a couple times was in the trance state with a sense of movement, etc. (who knows will understand). Immediately after meditation and water test. Guessing 21 map of 36. Then again - same result, 21 out of 36, i.e. 58% (!).
When the first test guess the first 5 or 7 cards in a row along with a suit. Then got excited and started to make mistakes. But upon further guessing, if guessing the color is usually guessed the suit. Several times (3 times) guess the map entirely.
Павлум
It is necessary to compare with the test up to disk, and then You might be so capable.Павлум wrote:Andrei Patrushev
Павлум
I do not support Your terminology, apparently my CPU is outdated.
Since you printed the tablets of the old Testament, this disc is one of the best drivers to connect the stem field.
This is an adequate answer to Your question.
Seriously:
By using the disc (and my own intention) you can enter the ISS. How do You dispose of them - so be it.
Seriously:
Павлум
Report by guessing the cards. Day 2
Before hearing two times in a row and 15 of 36 (classics!)
While listening after 15 minutes I suddenly interrupted, with the result that I was frightened, then angry. When listening to the re-could not be collected, and then passed out in spite of the Lotus somewhere after 30 minutes.
The result after meditation three tests 19, 22, 21, 36, respectively. But it is much worse than the first time - was not certain. The first day I actually saw the card. I will try next.
Марк Лучин
Super!Андрей Патрушев wrote:Students - perpetual Guinea pigs psychology ("What is psychology? Is the science about the students"...) about 15 People (not all survived until the endМарк Лучин wrote:So I would like the details of most of these. Unless of course it's not a military secret.). Plus Your humble servant and his closest relatives, including children
Test for psychic abilities (cards) showed an increase from 64 to 82%.
What else?
Thank you very much, very definitely and clearly.
This information is enough.
There is an additional question, I don't know where to ask (in a thread - ask here).
As I understand it binaural oscillations can be self-imposed musical sound theme as a coverlet. And if it possible the theme itself to scatter binaural? Let's say, suppose I have records which I personally road or the like. Suppose that prayer (say Orthodox or Jewish or the Qur'an). Or let's say learning language. So can they not imposing anything extra to scatter on channels in binaural rhythm?
It seems to me that the attempt to say something clear and almost smart almost succeeded.
Марк Лучин
Without a disc in the childhood tried, but then again just for fun when I got a card (don't play cards, don't like the best pistol or revolver Billiards - in which exceedingly strong http://russianbulat.narod.ru/pulevoi_biliard.html).Андрей Патрушев wrote:I Wonder who is really with the cards I tried before and after?
Before maps came out about 70% - just feel why the black image they subjectively warmer. Or do You mean that the hands can not touch, can only look on the pile? And in truth I wonder what will happen after the drive?
Павлум
Day # 3
To the disk 19 of 36
The listening in polulotosa. Not passed out, but the first 20 minutes was overcome all kinds of anxiety (the type of telephone like call, and who called?.. etc.). Then managed to tune in the end was fine - a sense of movement through space, the loss of the feeling of weight, etc.)
The result after 2 times for 21 of the 36. All as before.
Марк Лучин
Try to knock off a PM to Jim...Марк Лучин wrote:Super!Андрей Патрушев wrote:Students - perpetual Guinea pigs psychology ("What is psychology? Is the science about the students"...) about 15 People (not all survived until the endМарк Лучин wrote:So I would like the details of most of these. Unless of course it's not a military secret.). Plus Your humble servant and his closest relatives, including children
What else?![]()
