Structured water
- Дмитрий_999
Dimas wrote:no,seriously, someone aware of what the device says Mila? I would have taken myself if it's not a divorce.
http://www.activewater.ru/_shop/categ/a ... nByZW1pdW0
Here are a few options – do Zeland in my view over water, all well painted.
- Дмитрий_999
- Дмитрий_999
Well, give a link, as it even called? Although I think Zeland's not "slick".....МерКаБа wrote:This Japanese, not everywhere you can buy, in Belarus, for example, is unrealistic, and in Russia it is already possible, required the representative. ORP -1200 to he can raise, if a very small trickle of water to gain, so that even Zeland with his living water rests.
And what do you mean by that? The brand of the instrument is the same principle. There are, of course, the novoroty, but if you want, can be done with novoroty, no problem, schema is.nominal recipe "how to cook a hippopotamus". Take the Hippo, put in a pan and cook. As you can see, everything is simple. Confused
Here you go http://www.rlocman.ru/shem/schematics.html?di=41177
If you carefully read, then the base there is the pulse generator, as I said, comrade Logik. Everything else, there are all sorts of different kinds of protection, and so on. Realizing the principle, the scheme is greatly simplified by using chips.
Or here's another, much simpler: http://shemki.ru/readarticle.php?article_id=347
http://kornilov-s-a.ru/arc/voda.zipЛогик wrote:nominal recipe "how to cook a hippopotamus". Take the Hippo, put in a pan and cook. As you can see, everything is simple.Экко wrote:Take two plates of silver, is supplied current, or DC, or pulsed and all, and no expensive machinery is not necessary
Yes, there is, I see the keen interest showed up.
I believe that our man and he can make something similar. However, I do not know how and will not.
So I paid 4000 bucks!
The model is called SD-501 the Japanese company Enagic.
Someone will twist a finger at a temple, someone will feel sorry for me "such a fool". But I personally have not regretted a single day of your purchase.
The machine produces 4 kinds of water:
a) Pitaway.
- 3 types of alkaline (8.5 ph and 9.5 ph 9ph)
- neutral (7ph). For taking medication.
b) Strongly acidic (2.5 ph). Disinfection.
C) Strongly alkaline (11.5 ph). For washing vegetables/fruits. This is a must see!!!
d) Slightly acidic (6ph). Water for washing face (of hair).
I personally enjoy drinking alkaline, slightly sour face and strongly alkaline to wash fruits.
With regard to Russia. I have a friend who use this car in Russia. They put double filtration. The only way. The water is too hard.
I have pre-filters are not. We in the SF soft water.
P's` to Buy and those in Belarus, there are just nuances. Who cares, questions in PM.
a) Pitaway.
BSL-Med - it's all relativeDimas wrote:Mila
Yes, not cheap Agregat. I wonder if there's full analogue, but is much cheaper?
By the way, one lady from one of the secret Moscow enterprises dealing with water, screw in the 90-ies of Germany and opened there 4 medical center. Now, she claims that water with ORP -400mV treated (2nd type-permanent
) diabetes. Currently, the European Union has allocated to them a grant to open similar centres throughout Europe for diabetics (there are 3.5 million)...
