The cylinders and unimodularity... does It work?
Фипыч
Post by Фипыч » Mon Apr 07, 2008 12:19
Carilo
Most likely the ferrite here is meant in the context of:
Ferrites,
chemical compounds of iron oxide Fe2O3 with the oxides of other metals. Many F. combine high magnetization and semiconducting or dielectric properties, making them widely used as magnetic materials in radio engineering, radio electronics, computer engineering.
Part F. include oxygen anions O2-, forming the skeleton of the crystal lattice between oxygen ions are the cations Fe3+ having a smaller radius than the anions O2-and the cations Mek+ metals, which can have radii of different sizes and of different valency k. Existing between cations and anions of the Coulomb (electrostatic) interaction leads to the formation of a specific crystalline lattice and to the exact location of cations. The result is an ordered arrangement of cations Fe3+ and Mek+ F. have ferrimagnetism and they are characterized by quite high values of magnetization and Curie points. Distinguish F.-spinel, FR-grenades, orthoferrite and hexa ferrites.
Ferrites-spinel and have the structure of the mineral spinel with the General formula MeFe2O4, where Me is Ni2+, Co2+, Fe2+, Mn2+, Mg2+, Li1+, Cu2+. F. a unit cell of the spinel is a cube formed by 8 molecules MeOFe2O3 and consists of 32 anions O2-, between which there are 64 tetrahedral (A) and 32 octahedral (b)interstices, partially populated with cations Fe3+ and Me2+ (Fig. 1). Depending on what ions and in what order to take the gaps and distinguish between direct spinel (non-magnetic) and reversed spinel (ferrimagnetic). In the reversed spinel a half of Fe3+ ions located in the tetrahedral gaps and in the octahedral gaps – 2nd half of Fe3+ ions and ions Me2+. The MA magnetization of the octahedral sublattice of the tetrahedral more MB that causes ferrimagnetism.
Ferrites-garnets of rare-earth elements R3+ (Gd3+, Tb3+, Dy3+, Ho3+, Er3+, Sm3+, Eu3+) and yttrium Y3+ have a cubic garnet structure with the General formula R3Fe5O12. F. a unit cell of garnet contains 8 molecules R3Fe5O12; it includes 96 ions O2-, 24 ion R3+, and 40 Fe3+ ions. In F.-grenades there are three types of intervals, in which are located cations: most of the Fe3+ ions occupies tetrahedral (d), the lower part of the Fe3+ ions octahedral (I) ions and R3+ – dodecahedral sites (C). The ratio of the magnitudes and directions of namagnichennosti cations occupying the spaces d, a, C, shown in Fig. 2.
Orthoferrite F. is a group with orthorhombic crystal structure. They are composed of rare earth elements or yttrium by the General formula RFeO3-. Orthoferrite is isomorphic to the mineral perovskite (see Isomorphism). Compared to F.-grenades, they have a small magnetization, because they have a non-collinear antiferromagnetism (weak ferromagnetism) and only at very low temperatures (of the order of several K and below) ferrimagnetism.
The hexagonal ferrite structure (hexaferrite) have the General formula MeO (Fe2O3), where Me – ions of Ba, Sr or Pb. The unit cell of the crystal lattice of hexaferrite consists of 38 anions O2-, 24 cations Fe3+ and 2 cations Me2+ (Ba2+, Sr2+ or Pb2+). The cell is constructed of two spinel blocks separated ions Pb2+ (Ba2+ or Sr2+), O2 - and Fe3+. If iron oxide and barium sintering together with the relevant amounts of the following metals: Mn, Cr, co, Ni, Zn, it is possible to obtain a number of new of oxide ferrimagnetcs.
Some hexaferrite have high coercivity and are used for the manufacture of permanent magnets. Most F. with a spinel structure, the ferrite-garnet of yttrium and some hexaferrite are used as soft magnetic materials.
With the introduction of impurities and the creation of nestekhiometricheskikh composition (variability of the composition of both cations and oxygen) F. the electrical resistance varies widely. F. in the semiconductor technique is not applicable due to the low mobility of the carriers. The synthesis of polycrystalline F. under the technology of producing ceramics. From the mixture of initial oxides pressed product of the desired shape that are then sintered at temperatures from 900 °C to 1500 °C in air or in special atmospheres.
F. grown monocrystalline Czochralski methods, Vernale etc. (see crystal).
Lit.: Rabkin Li, Soskin, S. A., Epstein B. S., Ferrites. Structure, properties, production technology, Leningrad, 1968; J. Smith, Wayne H. Ferrites, TRANS. from English., M., 1962; A. G. Gurevich, Magnetic resonance in ferrites and antiferromagnets, Moscow, 1973.
K. P. Belov.<
Фипыч
Post by Фипыч » Mon Apr 07, 2008 12:28
Карил wrote:I am Sure that the iron is assembled in the factory and tefal iron made uncle Bob out of the foil in the garage – will work both.
We can and will, but how? In addition to the principle, there is also technology, which usually is not less valuable than the principle of action of the product.
Post by Dimas » Mon Apr 07, 2008 14:49
OK,what happened to me and my family in working with CF since my last post.
1.With me.Sensations of itching and tingling throughout the body usilivaetsya,sometimes lost,once more there is hot spots all over the body,especially on the outside of the wrists and on the feet.Colorful images before my eyes became more stable,images are changing every day,starting from fractal images zakanchivaja enchanting natural scenery,it sometimes seems that I'm smelling with this karinka.The changed sleep and dreams.However periodically there are pains in the liver and other (apparently) problem areas...Quiet and smooth mood,positive.
2.My girlfriend.Yesterday was the first time I engaged with the cylinders for the night.Almost not slept all night,woke up from a VERY severe itching in tailbone and the soles of the feet,despite this dream,he says he feels fine,not sleepy,in a great mood.
3.My mom.Categorically refused to engage with the cylinders,explaining he did not believe in all this (there is a syndrome of resistance to treatment).More than 20 years can't sleep without pills,but also taking a strong enough drugs,it is still very long time can not sleep,constantly wakes up in the night,goes hard to persuade her to go back.The father took the decision despite the protest,when she goes to sleep,put the fit on the headboard,the other at the feet (on the floor).Two days mom is in her words and the words of the household (I live alone) slept much better,almost did not get up.Yesterday, he told her everything,she agreed it seems so far only to sleep that way.I think to talk to her about the full classroom with the fits.
4.My grandmother.Severe pain in lumbar and knees.78.Engaged in somewhere 3 weeks.Says the fit well help to relieve the pain,but it is necessary to bend wrong or do something physically difficult,as the pain still returned.When the classroom feels warm in the lower back.In a good mood.Performs a full range,as recommended in the training manual.
5.Water.Really changes the taste after the glass sit overnight between cylinde.Tried this morning and the usual "cylindrical".Now I want to experiment with blends.Say structured water good self-cleaning.Need to think of something to pour in that water...
6.A buddy of mine.After a severe psychological trauma,he has disturbed sleep.Is a light sleeper,wakes at the slightest sound.Bought a pair the fits.The same puts on the night at the head,the other at the feet ( on the floor).Sleep according to him has greatly improved.Stopped the night waking.
Carilo
Fit is certified and approved by the Ministry of health as a physiotherapy device.All rooms are at the end of the manuals,so that you can easily check.If you wish,you can write it all,take a look.<
Post by Guest » Mon Apr 07, 2008 17:04
demAs
About the rooms I believe her. You can of course continue to harp on the fact that everything can be bought, including the certificate. But in light of the rest of what you wrote I'm completely lost.
About your relatives, especially mom. The fact that CF has affected her, in spite of the absence of faith - demonstration. That's how it should work real thing or drug, to give a result, regardless of desire or not desire.
Post by Dimas » Mon Apr 07, 2008 17:13
Karil,I understand that you wrote the last post?Here I specifically for the identity in the "raped" dad today on ICQ!The continuation of the experiment:Put the fit near the bed for 30 minutes before sleep,want to achieve that my mother's sleep was not disrupted during the night,we'll see...Although I was with my grandmother the result I was not very happy,the pain is removed,but then it still comes back,maybe it's time?...
Карил
Post by Карил » Mon Apr 07, 2008 20:11
And who, I am there so mean and not believing. As you still tolerate me wondering. :)
Grandma, not a few years...
Tell me about the water. What is the taste. Have you compared it with the usual? Notice the difference in your girlfriend?
If the action fits through a weak current of ions of metals I can somehow believe. The water changes properties in my head does not fit at all. Maybe it's the magnetic filler zinc cylinder? Can try to put one cylinder at night near the water?
Post by Андрей Патрушев » Tue Apr 08, 2008 11:03
And then Americana sell http://www.rodsofra.com/what_are.htm and the theory of their winged...
By the way, there are different inserts in the bundle - and as for "our" cylinders and in jelah. They write that the pharaohs were also different (depending on purpose), as these cylinders are found and explored. In the picture you can see that the original cylinder wall is very thick, which probably is essential for efficiency...
Post by Dimas » Tue Apr 08, 2008 11:59
Carilo
Taste like would be easier,I don't know,but the site says that it is NOT necessary to drink every day...the Girl doesn't notice the difference as have not tried it yet)))Yes,it says magnetized water...
Карил
Post by Карил » Tue Apr 08, 2008 15:58
I replied to V. P. Kovtun. In General, his answers are on the site, except for one. Vladimir offers to return the money in case of doubt. Despite the fact that the cylinders are oxidized and lose their marketable appearance, you need to be very confident in their properties to talk about the return.
I somehow forgot about Zadornov :( Whichever way you look, and this man won't talk about fit just. The idea that it could make or buy I think is complete nonsense.
Still... I don't think people that sell a fake would insist on verification. It is to insist, and not just write something like- "you can check".
In General, I'm almost ready to purchase.
Карил
Post by Карил » Tue Apr 08, 2008 16:02
Андрей Патрушев wrote:if someone to trust, all specialists in their field. Some authorities are beginning to show off and make "authoritative" opinions on different areas in which they know nothing about.
We in the Department of physiology UGMA for example, there are studies of water and designed an approach to structuring (biological value). Researched quite a few different instances, obtained interesting results. We also learned how to structure water using pulsed electromagnetic fields. But except for us and the past people were doing, and was published a whole monograph on this subject...
You can read more about the research? What were the results? How much time keeps the structure of water?
Are there any articles online?
Post by Андрей Патрушев » Tue Apr 08, 2008 16:06
The material will appear on the website http://www.nmbt.web.ur.ru/index.html
Карил
Post by Карил » Tue Apr 08, 2008 17:34
I got another incomprehensible response from V. P. Kovtun.
As for toppings, my tentative explanation is as follows: coal contains more than fifty kinds of various minerals, in addition to wood residues and organic matter,apparently, stores all of the information richness of the Earth (especially that lay in its depths millions of years!) The technology of its processing makes me think that the ancient creators of the fit meant this information exchange user with the components of the fits.
Post by Dimas » Tue Apr 08, 2008 17:42
Carilo
I do not understand anything... :D
Post by Dimas » Tue Apr 08, 2008 18:43
What he noticed in the preparation of the coal filling, I wonder...??? :wiz :wiz
Карил
Post by Карил » Tue Apr 08, 2008 20:16
Андрей Патрушев wrote: The material will appear on the website http://www.nmbt.web.ur.ru/index.html
Can write popular language? I'm on the site do not understand. :oops:
Карил
Post by Карил » Tue Apr 08, 2008 20:30
Dimas wrote:What he noticed in the preparation of the coal filling, I wonder...??? :wiz :wiz
Explanation class of auras and aura. To touch, see or in any other way can not register it. Have to accept as is.
Карил
Post by Карил » Wed Apr 09, 2008 11:01
Андрей Патрушев wrote:And then Americana sell http://www.rodsofra.com/what_are.htm and the theory of their winged...
The only theory I can understand. It well explains why a couple of the gold-silver gives a more pronounced effect. I do not remember unfortunately specific figures, but the difference of potentials there significantly higher than in the copper-zinc couple.
Post by Dimas » Wed Apr 09, 2008 12:31
Sleep like the dead these days,except one time when I did just before bedtime.After performing the pose of the Pharaoh in motion 15 minutes) feel a slight dizziness and nausea,after about 15-20 minutes it goes away.The hot spots disappeared,the less I feel tingling on the left wrist 2 days often reduced muscle as a mild cramp,as if there's someone crawling.
Валдем
Post by Валдем » Thu Apr 10, 2008 1:05
and have you ever tried to combine MM and fit I wonder what will be the effect and that he is waiting nedozhdus when send az :aa
Валдем
Post by Валдем » Thu Apr 10, 2008 1:06
there is a view at the same time with meditation :o
Post by Dimas » Thu Apr 10, 2008 11:55
Walden
MM I gave it to my parents for temporary use,so while sitting with some cylinders... :cry: That's what happened last night.Turned off all the sounds in the apartment..time 00.30,night...picked up a fit,got up to the window,closed my eyes...after about 5 minutes - there are colorful images,another 2 minutes had a strong polisiya pain left lower abdomen,I will not think in any way that there pancreas or spleen?!After five minutes the pain is gone,very well in this state to concentrate on anything-distract-deep..Began to chase the energy to turn over the ball head counter clockwise.After 20 minutes of training has delayed the cylinders and went to bed.Rest inside,you feel very strong pressure at the crown,like push the top with your finger,the feeling that the bones of the skull apart,it seemed to me that sales from the :wiz but it is a pleasant sensation,not painful.Dreamed, strange,colorful dreams.Mom began to sleep much better,it is necessary to come-to conduct an educational program to fully engaged and therapeutic poses.
Карил
Post by Карил » Thu Apr 10, 2008 19:54
Dimas wrote:Began to chase the energy to turn over the ball head counter clockwise.
It is also one of the exercises the running included with the fit?
Post by Dimas » Fri Apr 11, 2008 11:54
Carilo
No,this energetic practice to fit is irrelevant...So to speak eksperimentiruesh :)
If anyone is interested,post your correspondence with V. P. Kovtun.This will help those who may start similar problems and appear similar questions:
Hello,Dear Vladimir Pavlovich!Here at once have not noticed,those two parts You sent me...solar cylinder few scratches and knocked out some rooms and the Germany inscription in Latin,and on the lunar end,the opposite end of the hologram with the same sticker,but without labels,I ripped it down,and there small scratches and pits.These defecti has no adverse effect on the full effect of the Cylinders?And yet,I vypolnila the position of the Pharaoh in motion 15 minutes,then postponed when pochuvstvoval mild nausea and weakness that went through 20 minutes,is this normal?It's been 3 days.
Dear Dmitry! Pharaoh pose, judging by the reaction, very strong for You. This position is the most powerful energy flow. These reactions have been many that have not yet developed a therapeutic methodology. Measure your blood pressure - it can be with normal or low blood pressure. This often occurs in hypotensive. You are recommended to do during the month position "hand-foot" and "coccyx-hand" three minutes in each position without using the other provisions, and especially not to use for this month's Pose of the Pharaoh.
> > As for marking Solar Cylinder for its manufacture we use high quality copper pipe of German manufacture, satisfactory composition of the alloy. The lunar Cylinder cast in St. Petersburg. This alloy is very capricious. Up to 20 percent of the casting is in the marriage because of breach of the design - the metal is bubbling and the formed cavity. Sometimes a large. Almost impossible to avoid small irregularities on the bottom of the Cylinder, whereby to preserve the design we are closing the bottom betasunny hologram. I must say that all of these disorders in the slightest degree do not affect the fit. And, in General, TSF - no jewelry object also due to the fact that after using for 2-3 days they oxidize and darken,and this is their normal operating state. However, we are trying to sustain their appearance for the purchase. Sincerely, V. K.
Thank you very much,Vladimir Pavlovich!Another question I forgot to ask yesterday,was in a hurry...In the classroom,morning,evening-doesn't matter,I then very sleepy and the state of complete tranquility,even a reluctance to work,some irritability is also present.There is a desire to leave it alone,I want to be alone.When classes appear in different places throbbing pain,which then takes place.That is, I do not feel the vital forces for a day of action and just wants to get home and lay down,though sleep was much better for some reason (pardon my frankness) chair improved and became more common ))This is a normal reaction?I now am concerned that you do not want to do anything(((Can when doing to worsen the disease,including previously unnoticed?LEFT SEXUAL DESIRE!!!!Even do not want to think about it!
It will be held?
Dear Dmitry! You have gone deep relaxation of the body. Apparently tired. In any case, do not work with TSF in the morning. Just for the night. It is also one of the features of the fit they give to man what he needs at the moment. Some feel the strongest lift forces - they have to work with fits in the morning. All reactions are normal. Relax. Give the body to rest and recover. Sex reaction psle will be released on a new level. Undetected diseases can also manifest themselves. This means that the impact of the fit went on these problem areas. Before the chair, it is likely that the fit took some spasms, preventing the purification. Trust the fit - they do what You need now. Good luck and good Health! V. K.<
Post by Dimas » Fri Apr 18, 2008 16:57
Something going on...something strange,but good,and I noticed my girl too...everything changes...
Валдем
Post by Валдем » Sat Apr 19, 2008 0:27
I have a week live in the arms of the fit and I felt absolutely don't care what anyone says about fit and thinks, the last 10 years I have had strong lower back pain type of sciatica one who saw that will understand me, sometimes the pain had to chop - so after 2 days of nancena cilindrov the pain just disappeared = I freaked out I just forgot that it happens. There were some interesting sensations when used together, M machines and cylindro - in General untilled field for self-improvement, and became clearer and brighter dreams, although after MM and disc Andrew, I thought that there's nowhere but probably this is just the beginning az By the way is not seen as advertising as toldDimasI have the pocket do not have
:o az
