The Program Of Andrey Patrushev Raduga
Post by Андрей Патрушев » Thu Sep 02, 2010 17:11
Sergey Gurin
In my opinion, this kind of technique in principle can not have ready-made solutions for each. In Pogramme implemented, IMHO, all the necessary conditions for successful work, from the point of view of psychophysiology. Everything else depends only on polzovatelya. :?
Cержио
Post by Cержио » Thu Sep 02, 2010 17:13
Andrei Patrushev
Thank you! We will "experiment" :) az
ВерБер
Post by ВерБер » Fri Sep 10, 2010 0:09
Trying to install and any how. Names written, and can not save when clicking save and load POPs up to open. dots put down, Adobe reset with 9.0 or 9.1. pressed the start appeared the starry sky and with speed and sounds started to take off the names with the characters in different colors and labeled some. barely stopped. Well I am defective, nothing is going right. Help Council please! In the programs I know nothing about, a simple user of the word.
Post by Андрей Патрушев » Fri Sep 10, 2010 12:32
ВерБер wrote:Trying to install and any how. Names written, and can not save when clicking save and load POPs up to open. dots put down, Adobe reset with 9.0 or 9.1. pressed the start appeared the starry sky and with speed and sounds started to take off the names with the characters in different colors and labeled some. barely stopped. Well I am defective, nothing is going right. Help Council please! In the programs I know nothing about, a simple user of the word.
Judging by the description You have done everything, only texts You in another encoding. Put in the settings, frequency 1 Hz and see what You have there, where and how is popping up. :)
Adobe generally nothing to do with...
Вербер
Post by Вербер » Fri Sep 10, 2010 23:30
Thank You, Andrew! The texts had to scramble, set, go! Beautiful! At a frequency of 1 Hz mesmerizing movement, but trying to read, And at the recommended frequency 6Гц as it is hard to watch. I have astigmatism, maybe because of this. All the same, the frequency 6Гц to put?
ВерБер
Post by ВерБер » Fri Sep 10, 2010 23:39
Sorry, found Your recommendations frequency
Алина А.
Post by Алина А. » Sat Sep 11, 2010 8:54
Good afternoon, Andrey!
I have collected a bunch of phrases in Sedona, came out very much, so I have divided into four blocks. I plan for each unit to spend five days (twice a day for 15 min). For this reason two questions for you:
1. Enough 5 days on the assimilation of information? Or more efficient for each unit to be given 21 days?
2. Do you need a break in 21 one to after Sedona, for example, proceed to the affirmations?..
Post by Андрей Патрушев » Sat Sep 11, 2010 9:18
Вербер wrote:Thanks, Andrew! The texts had to scramble, set, go! Beautiful! At a frequency of 1 Hz mesmerizing movement, but trying to read, And at the recommended frequency 6Гц as it is hard to watch. I have astigmatism, maybe because of this. All the same, the frequency 6Гц to put?
Look relaxed gaze through the screen.
Post by Андрей Патрушев » Sat Sep 11, 2010 9:20
Алина А. wrote:Good afternoon, Andrey!
1. At least 15 days
2. Not needed.
Алина А.
Post by Алина А. » Sat Sep 11, 2010 13:34
Thank you :)
Алина А.
Post by Алина А. » Mon Sep 13, 2010 5:02
Andrew, tell me more, please, the optimal number of phrases, well, at least roughly. I'm afraid a lot of drive in the list.
Post by Андрей Патрушев » Mon Sep 13, 2010 9:12
Алина А. wrote:Andrew, tell me more, please, the optimal number of phrases, well, at least roughly. I'm afraid a lot of drive in the list.
If the phrase on one subject, without limitation, if different, then not more than 12.
Алина А.
Post by Алина А. » Mon Sep 13, 2010 19:11
Do not consider for dullness, Andrew, but I work in Sedona... different feelings are trying to let go: jealousy, resentment, frustration and other negative ... well feelings! It's all one topic, right? Or ... I divided into groups of senses from different region or something..
Post by Андрей Патрушев » Mon Sep 13, 2010 19:14
Алина А. wrote:do Not consider for dullness, Andrew, but I work in Sedona... different feelings are trying to let go: jealousy, resentment, frustration and other negative ... well feelings! It's all one topic, right? Or ... I divided into groups of senses from different region or something..
The methodology underlying each sense is studied independently.
Алина А.
Post by Алина А. » Tue Sep 14, 2010 8:17
Andrew, did not understand :) At me to you last question then, please explain to me as particularly talented :)
That's what I can put in a single file:
I let my jealousy
I deserve to let go of jealousy
I see that I let my jealousy
I know I let my jealousy
I hear that I let my jealousy
I remember that I let my jealousy
I'm sure I let my jealousy
I understand that I let my jealousy
I am happy that I let my jealousy
I feel like I let my jealousy
everyone knows that I let my jealousy
I would argue that I let my jealousy
I tell myself that I let my jealousy
I can afford to let go of jealousy
I appreciate the fact that I let my jealousy
I'm grateful that I let my jealousy
I let my self-doubt
I deserve to let go of self-doubt
I see that I let my self-doubt
I know that I let my self-doubt
I hear that I let my self-doubt
I remember that I let my self-doubt
I'm sure I let my self-doubt
I understand that I let my self-doubt
I am happy that I let my self-doubt
I feel like I let my self-doubt
everyone knows that I let my self-doubt
I would argue that I let my self-doubt
I tell myself that I let my self-doubt
I can afford to let go of self-doubt
I appreciate the fact that I let my self-doubt
I'm grateful that I let my insecurities and stuff...
Or me 21 days to pay of uncertainty, then a 21 - jealousy? And so on..<
Post by Андрей Патрушев » Tue Sep 14, 2010 11:29
Alina A.
Can. Even better, if You connect, type "your confidence helps me to let go of jealousy, liberty helps to gain confidence"...
Алина А.
Post by Алина А. » Tue Sep 14, 2010 11:59
Thank You, Andrew! Wow, you combine! Will work! Thanks for the program, she inspires and.. works! :o
Post by Guest » Sun Sep 19, 2010 0:58
Sorry...and no, depending on the program?
Post by Андрей Патрушев » Sun Sep 19, 2010 11:08
Anonymous wrote:I'm Sorry...and no, depending on the program?
And their thoughts? :wink:
Валериус
Post by Валериус » Thu Oct 14, 2010 8:54
Hello, Andrey Patrushevand here's an interesting observation.
Yesterday I felt the real frequency of occurrence of the labels on the screen. With a set of 6 Hz per minute appears ~240V label, which corresponds to 4 Hertz. It's not ice? I put 9 Hertz, tired to count at this speed, but turned out to be a real 6.
I have 8-percent nuclear, the frequency just can't remember today, the house will look. Is not this the case?
Maybe someone else will think to their computers and report the results and the performance characteristics of the processor? It is better to put 3 Hz, considered easier, in a moment you should receive the 180 labels.
Малина
Post by Малина » Sat Oct 30, 2010 9:52
Hello, Andrey!
Rainbow - in the morning and at night. The conductor of the evening. Acceptable?
Post by Андрей Патрушев » Sat Oct 30, 2010 12:46
Малина wrote:hi Andrea!
Hello!
Completely.
Малина
Post by Малина » Sat Oct 30, 2010 14:03
Thank you :)
Наташка
Post by Наташка » Mon Nov 08, 2010 10:01
Good day! I just joined the forum, all pages are not read, it might have pointed out these errors in the instructions to the subconscious (the text of which is shown in the center )
1. "and now our consciousness does not know which of them will pick YOUR brain" , you have probably OUR brains
2."PREPARING the SUBCONSCIOUS, WITH the INDISPENSABLE OBSERVANCE of the BALANCED needs of ALL of YOUR BEING as a WHOLE", should be-of our being
The program is interesting. The truth is a little easier on the eyes. And it's so great. Thank you!
Post by Андрей Патрушев » Thu Nov 18, 2010 22:12
Наташка wrote:the Programme is interesting. The truth is a little easier on the eyes.
Then You see wrong. If you look properly (see instructions) eyes opposite rest. :?
