СК1М
Michael_ some improvised material in Your opinion effectively fix infoupdate structure with "baptismal water", realized with the help of SK+HF and control program "infoperevod"? What is the possible period of storage and use (for the subsequent charging of water) of the structural footprint?
Sincerely, MAG.no
Sincerely, MAG.no
Option1.
do not take yourself, me and the water head = make an entry in psyleron his head. then it will spin in the UK and get the desired result.
option 2. capture the water from below the stiffening material at the top, then use the sample under SK as a source of information or just in the water.... shelf life are potentially unlimited (well, depending what to take for material)
option 3. same as 2, but on top of SK put ware glass, which then will charge the water.
next, choose from 1-3 at the personal request, or implement all three and compare the effectiveness.
success.
success.
the tin can approach.... for metal of the desired shape where to pour that again, usually gypsum or quartz sand or clay.... the question is how much and how pours.
and Mel is very good, but dry for a long time.... try epoxy to add, if you find it more difficult to modulate, but a very large energy consumption.
Interesting observations in the implementation of infopresse structure "Epiphany water":Маг.нет wrote:thank you very much!
Will try...
the source of the structure - "Epiphany water" in the glass container under "SC+RF". Process time about 2 days (the time of crystallization of the material "infoupdate"). Simultaneously with the "source" of the 2nd sample in the same container with the same water, placed in the same room at a distance of 1 meter from the "process". After comparison at the end of the process observed difference between samples. 2 - changes were not observed, 1-m, which is the source of a significant increase in the number of "air bubbles", increasing their size by approximately 2 times and slightly different location - in the 2nd isolated bubbles only along the walls, in the 1st along the walls, but dense foam and uneven isolated bubbles and small clusters of 5-10 PCs in different parts of the volume of water.
Such are the observations for today...
Sincerely, MAG.no
In General, it is natural and understandable, but don't ask me to explain why... there is no appropriate terminology and clear definitions. In shortest form - the place where SK+RF is more natural, and Epiphany water manifests certain qualities that can lead to such bubbles. In other words the water stimulated.
By the way I also wrote, not only on the subject and without a sample (well, they took a sample of water remotely from me in the community itself).
Later I post the picture and the sound.
There is no time.
There is no time.
Very interesting about the Holy water!)Михаил_ wrote:overall it is natural and understandable, but don't ask me to explain why... there is no appropriate terminology and clear definitions. In shortest form - the place where SK+RF is more natural, and Epiphany water manifests certain qualities that can lead to such bubbles. In other words the water stimulated.
There is no time.
It will be interesting, very!)
I have a SK recently, the experience is still not enough
In such I have some questions:
1) is it Possible for a table to put two pieces of paper? For example, I have one goal short and primitive, and the second multi-dimensional and long on performance...
2) Here is a piece of paper on the table, and it took me to put the audio track on Energocapital operator, cleaning of the room or a standard or anything else... to me this piece of paper to remove from the table or, I'm sorry if I sound stupid, can be left on the table?
Can you here to bring your procurement tasks text?Василий wrote:Continue the test device. As you remember I got it on Friday, on Sunday, recorded on mp3 player the problem, it's Thursday, 4 days it plays without interruption so the first observation.
The task I have set for success in business and an early closure of trades I have going (I'm an investment banker). It seems like everything is ordered correctly, including the fact that I lead a relaxed lifestyle. However, all week I have a feeling some of the most powerful bulldozer that just pushes me from behind and rushing me forward some deals on the way fell off, the part of me doing so, I can barely handle it. Vplod to the fact that coming to the lunch meet investor, which I just did requires that an investment opportunity that I once suggested to him (although usually the investors have to run long to convince them that your project is good). In General, the most powerful thing in the coming days I will think how to rewrite the same task, or with such a pace I can handle.
In short - the thing does not work in destkom, be careful when setting objectives
Frankly, the wording on the achievement of this goal is a little bit buggy... so for example last night ran it again and now 22:30 and I'm at work
. You don't want to expose on a General review, can throw You a PM.
Here is the lead formulation for safety, which my well-honed and glitches not seen, and working effectively:
My family and I, including ... and ... and all my close and beloved friends and relatives are absolutely safe and have perfect protection under all tangible and intangible interactions. This protection function is a priority, at the same time, in the absence of immediate danger or threats, this program has a minimal security impact on the event thread while acting in an optimal way. If necessary, the subconscious and the allies of the people mentioned above, can use all possible and impossible resources this device for protection and security"
further, the additive is potentially dangerous - see for yourself:
"my subconscious and allies can use all the resources this device at their discretion if it is in the interests of my current personality"
here's how it turned out experimentally
turned out to be a very important clause about the minimum effect in the absence of a direct threat. Yet this reservation was not I could not normally drive - I either fall into the tube or something else forced me to go slowly. Apparently the program is traveling at high speed was perceived as a threat
and not allowed to accelerate.
At the same time, this program has already shown its effectiveness, in particular an important phrase was that it works "optimally". Mike right there in the heat when he had spare time made to sort out the water system in the house, thus apparently negating the need to do it in the cold winter
