the idea is, mirror-like techniques of the Reich. I.e., the dielectric - electric.
ACC. this should increase passionately the magnetic energy of the poles through the plane of the pyramid.
who thinks that ?
http://samlib.ru/l/lemeshko_a_w/ap.shtmlhe Unscrewed the lid, verify the batteries and they were in place just by itself... stranded Here and came up with the idea to put them in a pyramid on a pedestal. Put made an entry in the log and went to dig a vegetable garden. Came through half an hour to smoke, went into the Studio sat down in the chair, inhaled a cigarette, and realized something was wrong. In the mouth has constantly been the taste of battery in my childhood when I tried it on the language. A scratchy throat and cut in the eyes of the feeling that was what the "volatile evaporation" out on the street caught his breath, finished his cigarette. Went again, same thing. Well, I guess call and put someone in the workshop. The effect was like a stinging in my throat started to twitch a nerve in my right eye but the taste in my mouth as I was not Short I was poking around until dark and when he was about to go home I decided to pull out the batteries. I think nothing will happen, so there is nothing for them there lying to spoil the climate in the Studio. Pulled out, said the magazine time of 1:35 hours, after he had invested and put it in a pointer.
On MS-l-l button and-and-and STUPID is a bright BEAM. Joy was the chapel.
naoborot, not the current height and volume object should not exceed 5% of the total volume of the pyramidновый Искатель wrote:2. about 5% did not understand. ie if I am 182 cm tall, pyramid not more than 10 cm or what to do ?
1. well, with the copper already there's a disconnect, and my feelings and the book Silva strictly does not recommend copper for bio. If the current of electricity, outside of human presenceXUPOH wrote:naoborot, not the current height and volume object should not exceed 5% of the total volume of the pyramidновый Искатель wrote:2. about 5% did not understand. ie if I am 182 cm tall, pyramid not more than 10 cm or what to do ?
the author reports that sleeping under six-foot-tall pyramid and plans to build a seven-foot.
Archimedes was pushing myself the same question))новый Искатель wrote:2. and as the amount of take it ? my weight is 70, height 182.
in any case, that 5% of the copper, a very controversialXUPOH wrote:Archimedes was pushing myself the same question))новый Искатель wrote:2. and as the amount of take it ? my weight is 70, height 182.
the type of aluminium will enhance the passage of air ?XUPOH wrote:Frame IMHO it is desirable to wrap a metallic foil, foam foil, tape aluminum cooking foil.
And fractals - Yes, they rule!
and you can link to the book ? where to download where to read ? Google this text is silentронин wrote:Internal CE configuration was a complicated design resembling the structure of beehives. "Honeycomb" was welded from the thinnest glass tubes and are oriented in such a way to focus the power coming from the outside, in one place – at the bottom of the pyramid, where the maximum density of "AIR-field". There we imposed was lival "orgone battery-battery." On top of the pyramid was installed energyhouse – confusedly "plate", the distance of the vitel.
then why, after some, is poisoning ?still schaab that the book may not be food.
I said when I read after SOMEONE, and not at all old, there is a trace of the astral of the reader remainsand when you read poterjannye old books, don't feel that it's Ableton.
