Solar wind
Россомаха
Been thanked: 11 times
Re: solar wind
Post by Россомаха » Wed Feb 26, 2014 15:11
After Healing from solar wind to move, bypassing the Explorer?
Re: solar wind
Post by Андрей Патрушев » Wed Feb 26, 2014 16:58
Wolverine
Can. :)
ААААА
Re: solar wind
Post by ААААА » Wed May 21, 2014 14:21
Probably missed the answer? Track 11 song of Chakramov very similar to a brain Massage ! As it should be ? This is an alpha? And was aisles more powerful version of Healing, rather than the intensity or something?
Re: solar wind
Post by Андрей Патрушев » Wed May 21, 2014 14:38
ААААА wrote:and what intensity, or something else?
The intensity is high.
This is an alpha.
ААААА
Re: solar wind
Post by ААААА » Thu May 22, 2014 0:36
Thank you very clear! Teaching methods the standard? Or need training first, with other drives?
Re: solar wind
Post by Андрей Патрушев » Thu May 22, 2014 0:44
AHHH
Better to do it in the morning. Headphones are needed.
No other peculiarities. :)
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Re: solar wind
Post by Владимир Ш. » Sat Jun 14, 2014 16:31
Dear Andrew, after cycles of a Guide and a Healing (cycles had a lot of - since 2008, the breaks were doing as expected, but apparently, the brain already 'allergic' to them has evolved-it's hard to force myself to listen to them, but if through the power-positive effects are seen) - is it possible to replace 'the song of chakramov'? If so, how? A single listen of the track or it can 'wrap' to the total duration of 45-50 minutes by analogy with the conductor? Sorry for Megabucks and thanks in advance for the answer.
Re: solar wind
Post by Андрей Патрушев » Sat Jun 14, 2014 16:34
Vladimir S.
Try it - it's not fatal. :)
Nothing better to kalavati. More is not better.
Владимир Ш.
Re: solar wind
Post by Владимир Ш. » Sun Jun 15, 2014 3:48
OK, got it, thanks for the quick reply. I will try without the loopback.
дара
Re: solar wind
Post by дара » Wed Jun 25, 2014 18:53
Sorry, reread the instructions to the disk SV, there are no recommendations of what to listen to in the morning that night, lying written on the forum suggest sitting separately, that would not effect the dust bag, and how then to write all of this in the instructions, if it's important, it is impossible to read the whole forum, unfortunately so many choices that we have to guess, and write it seriously, or am I wrong instruction read when buying a drive? Then where to find clear recommendations. Thank you.
Re: solar wind
Post by Андрей Патрушев » Thu Jun 26, 2014 19:12
gift
You are right. :?
All essential points was moved from forum instructions.
Аленабар
Re: solar wind
Post by Аленабар » Mon Jul 07, 2014 20:47
Listening to "solar wind" for weeks after listening to "Song of chakramov". Appeared bursting, pressure in the chest a strong pain, presumably in both the chakras and gives the rear in the projection of the spine, and sometimes in the throat appears the same. been sick for two weeks with varying degrees of intensity. Drive to listen longer. Can there be excess in these chakras, from the disk? If not, what it looks like and maybe somebody knows what to do.
Re: solar wind
Post by Андрей Патрушев » Mon Jul 07, 2014 20:50
Elenabar
First of all read manual.
Аленабар
Re: solar wind
Post by Аленабар » Tue Jul 08, 2014 12:26
If You're talking about "Song of chakramov" I listened to her 2 weeks, no change, so I decided to ask here in the forum. Unpleasant feelings while listening it was not, they appeared immediately after listening and it's like a severe spasm, spreading, squeezing, as if swallowed a large piece and it is stuck. And now for 2 days as there was still itching in tailbone (don't know related or not).
Thank you in advance for the answer!
Re: solar wind
Post by Андрей Патрушев » Tue Jul 08, 2014 12:30
Elenabar
See above.
Аленабар
Re: solar wind
Post by Аленабар » Tue Jul 08, 2014 18:53
Thanks for the detailed reply and help Andrew! The instructions I read yesterday and today. But can You still find the ability to specify what line in the instructions have to do with my relationship and eludes my attention and can take away the pain. Well if not then maybe someone of the experienced users will give their opinion, tell me how to do in this case.
Re: solar wind
Post by Андрей Патрушев » Tue Jul 08, 2014 18:55
As already mentioned, the sounds of the chakras have diagnostic properties: while listening in the location of any chakra (or the former site of the injury with the remaining energy unit) may have the unpleasant "pulling" sensations, until painful. Often these feelings arise in the area of the "third eye" (the overuse of modern video technology block the development of "internal video"). In these cases, is very good (relieves pain) following exercise: Imagine any glowing (preferably white, but not very significantly), elastic substance (thread) that you send from painful places forward in infinity (trying to throw it as far as possible). Substance flies there (send your inner volitional impulse), progressively elastically expanding and refining (to infinity, about the expense of 1,2,3) then comes back (almost instantly, and then you relax), due to the forces of elasticity and inertia flies ago (also at the expense of 1,2,3), customize your volitional impulse, then forward... And so on until you get tired. Do not forget to breathe. You can synchronize your breathing (as you prefer) the flight of the substance. After a short rest you can repeat (but not more than 15 minutes).
Аленабар
Re: solar wind
Post by Аленабар » Thu Jul 10, 2014 12:05
Thanks again! This exercise I've seen before on the forum and do it 2 times a day for 5 minutes as "song of chakramov". But it seemed to me, did not help and I stopped to do it. I'll try a little longer this time. No injuries did not exist before. I assumed that just clamped a strong emotional energy in the chakra and release can not and she motylyaetsya in 3 chakras. Thank you! Will look for.
Re: solar wind
Post by Андрей Патрушев » Thu Jul 10, 2014 12:16
Elenabar
The forum had a specific question about the ajna. Pump "flow" should be in a specific (problem) chakra.
Виталька
Re: solar wind
Post by Виталька » Wed Sep 17, 2014 1:31
SV is something.... today I listened for the first time. No bad feelings as they write on the forum I have not found myself. And no movements of native and alien existence in the body is also felt. But the clear color, it was of course :wiz :D ... listening to the evening when it was already dark outside the window. Like the light colored are eyes. Open your eyes dark. Close very bright and most likely all. SUPER. I liked it. I will continue to listen... see what happens.
Алексей Федотов
Re: solar wind
Post by Алексей Федотов » Wed Sep 17, 2014 12:24
Question. Bought the electronic version. If re-coding work to another format how will this affect the work?
Re: solar wind
Post by Андрей Патрушев » Wed Sep 17, 2014 12:26
Alexei Fedotov
Will lose effectiveness.
Акела
Has thanked: 28 times
Been thanked: 64 times
Re: solar wind
Post by Акела » Sun Sep 28, 2014 14:01
Amazing results occur if you use this product as БРМ2, connect and konzentrierte the sensations, the effect is much brighter than through the speakers, fans are advised to try. However, use caution and that chip in my head and can burn.
viewtopic.php?f=50&t=5586
Unusual effects appear with other drives Andrew...
:ay
Андрей Борисович
Re: solar wind
Post by Андрей Борисович » Sun Oct 26, 2014 20:46
Andrew Hello! Morning work drive the solar wind, and before going to sleep with a disc in lucid dreams. Is this acceptable?
Re: solar wind
Post by Андрей Патрушев » Sun Oct 26, 2014 21:24
Andrey Borisovich
Hello.
Yes, it is.
