I'M BUILDING A PYRAMID
George,a closer interpretation of Vadym Perelygin (this is what about the pyramids).Your calculations suffer from a certain one-sidedness,chuvstvuetsa some theoretical knowledge,not more.So what you are trying to teach specialists?... Or to mislead the gullible?!There is some idleness in the flow(of information.)
Re: I'm building a PYRAMID
Aim?Because as you know who with a sword to us will come...
Андрей Птаха
by me too, please, I would be gratefulГеоргий Щербина wrote:by your attention slipped in a reference to the Russian matrix
- Георгий Щербина
Vadim, I go to the forum, you go on referring to http://subscribe.ru/group/slavyano-arij ... a/5587481/. There is interesting information on the angle of the faces, and not only...
Harmful hell didn't come here infoy shares and show off. Decent people don't do that
At the moment, from the use of medical pyramids among my friends and acquaintances have clinical death (pyramid Perepelkinoy) and sharp deterioration with fatal outcome (Golden pyramid). I have the same tendency to potoyanno high blood pressure.
Vadym Perelygin, laying in your topic information about the Golden healing pyramid revealed is not only premature, but also deadly. Remove from their posts all the quotes from messages Shcherbina, not, God forbid, can become an unwitting accomplice to murder. If you will still need additional information, then contact me in PM.
According to the heritage of our ancestors regular four-sided pyramid (pointed) a projection of the devil. Look carefully around the pointed pyramids are visible distress and destruction around the truncated - life blooming. Towards the study of truncated pyramids should be followed. The ratio of the size of the pyramid and the pyramidion is chosen from a range 1:16, 1:32, 1:64... the larger the denominator, the closer the characteristics of the truncated pyramid to the pointed.
And the Golden healing pyramid requires the development of methods for control of patient status in real-time. Without this, it is potentially deadly.
Valery Kondratov http://www.paleotehnolog.ru on the forum, but this thread kind of was not mentioned.
His film about the pyramids
Here I have been reading about the healing properties of pyramids and made the house a pyramid of height 20 cm (with the dimensions of the Golden section). Material: silver 3M self-adhesive polyester. She has a shiny surface, which I did inside. Set it on a shelf at a height of 1.5 meters. The result noticed that every night began to dream vivid dreams that I remember. I do not remember that I had a dream and if that dream is immediately forgotten. Link these events with the pyramid....
The pyramid is certainly interesting ...
Did I not really large .
Aluminum foil , thick like this ...
Did the three sided, and four sided , ravnomernye .
What can I say ... when you orientation them do with her angles emit certain energy , orgone presumably this is because the presentation indicator is "Burnt branch" , this branch starts from the pyramid ...
Does Orgon .
Maybe even some other energy ...not named ...but behave on the indicator as well as orgone ...
In General, the pyramid is a good thing ...
There is only one, BUT we must build it outdoors and in an open area and preferably higher off the ground
But in General ...all these esoteric figures there is one simple but very strong competitor - the usual paraboloid satellite television
You just have to make watching the sun system .
Well, the very Cup to stick on small mirror tiles .
But irradiate is a simple brick . He is not lit
Does Orgon .
Yeah ... all this nonsense ...
ALL this is not so much pronounced , which is easily taken for granted ... especially because the reason may be another ...
Actually , to go into the pyramid , at one third height from the ground , comes to mind only an idiot ...(.
WHY ?
250 POUR a glass of vodka .
It will be a little more booze
WHY ?
ДмитрийОмск
Dear friends! Hello!
I'm on your forum the beginner and yet have only a slight relation to its subject.
I want to ask experienced professionals about me gathered the pyramid.
Collected it from the PCB 1cm thick. Base 92,4 cm rib 87,5 sought to the proportions of the pyramid of Cheops.
Placed it on a stand with a height of 40cm, what would it has been comfortably seated. Use within a few months of meditation. Can't say crazy or have any strong feelings, but the effect is definitely there.
The question is essentially the following. before NG I aimed to strengthen the pyramid with an additional layer of stainless steel on the inside... had the idea after reading some literature about orgone generators Reich. where he ispolzovanpokoleniya metal\dielectric. Along with this came the idea to use mirror stainless steel...
Now I have a two-layer pyramid. inside mirror-metallic....
Obvious strengthening effect I do not watch, but he's still there...
Perhaps there is understanding, capable, experienced point of view to assess whether first use of the PCB. secondly, adding a layer of metal inside and the third mirror inside...
PS I do Not know how to add a photo....
Good afternoon everyone
New to the site. Can anyone answer. Interested in this question that I have not found anywhere answer.Live in your house,the roof, whether the pyramid.Found mention that a concrete ceiling with the fittings affect the pyramid. And metal?
Викторович
- Has thanked: 1 time
- Been thanked: 6 times
новый Искатель
Lord. there is access to a nice sheet of copper.
question - what is the harmful make of copper ? why aluminium can and copper is not ?
justification is only in one place.
manufactured anyone the copper pyramid in practice ?
It was the case...
Material glass fiber, or, as they call it, fiberglass sided (maybe that's why not working).
новый Искатель
well, what was the result ? not pearls from her it had no effect ?
In the expressed impact on others has not been noticed))
But then recently noticed a Gray-haired, feel not given to everyone.
новый Искатель
so it to the ceiling should hang, the main thread goes UNDER the pyramid, proven repeatedly.XUPOH wrote:IN the expressed impact on others has not been noticed))
my month stood on the table, nothing oozed. Then I realized that the downstairs neighbors shake when I saw the neighbor below all this shining.
1. you hung it on the ceiling ?
2. why the tip is not circumcised ? it otherwise accumulates the charge at the top, and never goes anywhere. it is no coincidence that of Cheops, the top srezana.
and again. how cool to make a pyramid of quartz glass ? any idea what its crystal lattice is similar to the pyramid.
+ Uvarov that builds a pyramid of concrete mixed with silica fume. it was a video.
Hello! I once had a chance to work on the restoration of existing churches in the Vladimir region. The specifics of the work could be defined as "the artist-climber")). Ie the point is that-be not to build a temple inside the forest, a long, expensive and not aesthetically pleasing, had to restore the mural, hanging on slings and ropes. Actually had to get quite interesting bodily experience in relation to the study of the geometry of the temple premises, being directly under the arches at a decent height. And of course the most interesting thing happening under the dome and inside the dome, especially inside. There are domes, where the energy density is so high that there are more than ten minutes is very difficult. In the second minute ears pop like in an airplane, and at the fifth minute might start seeing things, And after the tenth minute, there comes such apathy and unwillingness to move physically, something to raise his hand, have to make strong-willed efforts.( almost loss of consciousness) is of Course interested in the phenomenon after which about thirty of the domes tested in various churches and monasteries. I must say that not all the domes work the same way. But it is noticed that the very important role played by the outer coating of the dome and building materials. In serious domes to the focal axis it is better not to approach. And I note that the cone of the pyramid (round base) are significantly stronger than the "pyramid of Cheops" pyramid.. And only the marked angles do not work at all.
The Cheops at the top was crystal. How to find a decent quartz (amethyst) pyramid - cut under it to size. It is not excluded that we may have to cut and hem to fit into the multiplicity of Fi.новый Искатель wrote:1. you hung it on the ceiling ?
While there is only schungite, but they are the couple "do not excite" ))
And about to hang, the idea is interesting, but then the difficult orientation along the Meridian.
PS. A neighbor apparently someone normal shakes without pyramid)), need to test))
- Максимильян
Ahoy!
Read the thread from cover to cover. So much confusion in the minds of people from not knowing their roots. Of course it's not our fault, but "Wake up" is necessary. I apologize for the tone, don't want to offend.
I compared some data from public sources and I did something interesting. I was "interested" large discrepancies in the interpretation of the image pyramids. Smacks of mysticism. Offer their views on them, but rather the pyramid of Cheops.
Once a reservation - based material taken from courses Asgardian spiritual school. (materials for lectures 1-3 of the course in the public domain, for example in the search of YouTube). We are interested in three lectures, father of Diya for 1 year Hughes Aryan arithmetic number 1, 2 and 4).
First we learn about the "Signs and Systems" Slavic arithmetic, based on the images from the second - acquainted with the Measures and Distances of Our Ancestors (we are interested in the Span, the Cubit, Arshin and Vershok), and lecture 4 on the Prismatic multiplication and what is most interesting at the end of lecture the Lord's prayer introduces us to one of the sacred purposes which was performed in the Cheops pyramid - namely, it served as the basis of the calendar number of the people of Egypt and people of Egypt. Why is it believable? Yes, at least from the article by V. A. Chudinov Russian inscription over the door of the pyramid of Cheops. Ibid. 4 the lecture can be found on the "System Pyramidal multiplication".
So the hypothesis is that the great Pyramid of Cheops was built by our Ancestors - the Slavs.
Two indirect evidence already evident (see absetzen above).
Go ahead. Look The theory of masonry using already existing blocks. Here we are interested in the size of the outer block of the pyramid, which is 127х127х71 see
Remember the steps of Our Ancestors and by simple substitutions we obtain:
127 = 7 Inches + 1 and 3/4 Inches = 7 * 4 Inches + 1 3/4 Inches = 29 3/4 Inches (Digits - period day treatment of our companion - Month-moon)
71 = 1 yard = 4 Inch = 4*4 Inches = 16 Inches (Our Ancestors were 16 hex system images).
Further, I look Vicky the pyramid, the category of "Angle". There we see the line in the brackets (height = 280 cubits and the base = 2×220 cubits; 280/220 = 14/11 and there about the "Golden number" and the number PI. It seems to me that it was the Royal Egyptian cubit, is very similar to the Slavic Elbow.
So, if we assume that under the elbow is the measures of those who built, you have the true length of base and height:
Base = 2*220 Cubits * 53,34 cm /100= 234,696 meters
Height = 280 Cubits * 53,34 cm / 100 = meters 149,352.
The base to height = 1,571429 ( difference in 6 ten-thousandths!), The pyramid of the third order coefficient 1,57215.
Apofema to half the Base = 1,61859 (deviation from the Wiki (1,61803) - 6 ten-thousandths).
Left are related to the number of blocks length and height and check on the system of Pyramidal multiplication of the Slavs.
So it turns out that the pyramid of Cheops with very high accuracy (ten-thousandths 6) correspond to the Golden section.
новый Искатель
a competent website:
http://piramidki.com/chasto-zadavaemye-voprosy
what is the difference in action in the "extended" up the pyramids, and common, in the proportions of the Egyptian pyramids?
The pyramid is a kind of "pump", absorbing negative energy and radiating harmonious for living organisms. In the great pyramid "fence" energy corresponds to the "kickback". By reducing the angle of inclination of the facets (pointed pyramids) this balance is disturbed and the pyramid becomes a "vampire", sucking energy from the outside and giving almost nothing back. Developed they are ignorant crooks, or purposefully to those pyramids worked to the detriment of others. As an example, such a pointed wooden pyramid was built by the Chairman of the collective farm in Maslovka in Voronezh region for seed treatment. Working in it I felt very bad after the death of the President burned down the pyramid.
there and ready for sale.
interestno what I to the same conclusions for capacity increase of radius, i.e., fractality-dolls of the pyramid in the pyramid
новый Искатель
over 360 000 pyramid do not want ?
http://wands-of-horus.com/store/mini-pyramids.html
about mirror glass-like material (Hickey for the Reich) by the way I to the same conclusions. but the fact that he builds the pyramid, the vampire, is quite wrong.
only of Cheops.
only of Cheops.
новый Искатель
groped under energy domes. The truth is that the dome gives a narrow beam strictly to the temple, and just outside of the temple. And the pyramid works on the area. More globally.нева wrote:Hello! I once had a chance to work on the restoration of existing churches in the Vladimir region. The specifics of the work could be defined as "the artist-climber")). Ie the point is that-be not to build a temple inside the forest, a long, expensive and not aesthetically pleasing, had to restore the mural, hanging on slings and ropes. Actually had to get quite interesting bodily experience in relation to the study of the geometry of the temple premises, being directly under the arches at a decent height. And of course the most interesting thing happening under the dome and inside the dome, especially inside. There are domes, where the energy density is so high that there are more than ten minutes is very difficult. In the second minute ears pop like in an airplane, and at the fifth minute might start seeing things, And after the tenth minute, there comes such apathy and unwillingness to move physically, something to raise his hand, have to make strong-willed efforts.( almost loss of consciousness) is of Course interested in the phenomenon after which about thirty of the domes tested in various churches and monasteries. I must say that not all the domes work the same way. But it is noticed that the very important role played by the outer coating of the dome and building materials. In serious domes to the focal axis it is better not to approach. And I note that the cone of the pyramid (round base) are significantly stronger than the "pyramid of Cheops" pyramid.. And only the marked angles do not work at all.
The dome as parabolicheskie antenna, there task is to take the flow of aggregor and his flock. Ie it is simply a two-way communication the congregation-the priest - the egregor. Outside the Temple, well, there is not a very large radius.
So if the goal is to clean the area, not narrowly only on yourself, the better the pyramid. In addition, the plane of the pyramid better suck the energy of the magnetic poles (that's why they strictly need to direct planes on poles so passionately was). The cones-domes due to concavity, this energy is dissipated.<
