Thank you!Андрей Патрушев wrote:HealingВасилий_V wrote:And which drive is better to use after shake?
I wish You happy holidays!
Hello._Алекс_ wrote:Andrew greet)
Wanted to ask you. Disc Healing you can listen to together your CDs?
I have now appeared: the Endorphins, the Journey through the inner worlds, Conditioner and Massage of the brain.
Or listen to them with a break of 15 days after the completion of disc Healing?
mmm, how's that?)Андрей Патрушев wrote:Hello._Алекс_ wrote:Andrew greet)
Through the day.
Morning Healing .In The Evening The Conductor. And so 15 or 21 days. Then a break with these wheels 15 or 21 days And then you can and following the same pattern.The break between the discs 3 hours._Алекс_ wrote:Right after I finish listening to this CD, the Healing, through the day to start listening to the selection of one of the disks?
And so, if we have time...ЛИЛИЯ-Р wrote:the Morning can be Healing .In The Evening The Conductor. And so 15 or 21 days. Then a break with these wheels 15 or 21 days And then you can and following the same pattern.The break between the discs 3 hours.
In the FAQ section are all described in detail.
Oh if I had the time to read all)ЛИЛИЯ-Р wrote:Morning Healing .In The Evening The Conductor. And so 15 or 21 days. Then a break with these wheels 15 or 21 days And then you can and following the same pattern.The break between the discs 3 hours._Алекс_ wrote:Right after I finish listening to this CD, the Healing, through the day to start listening to the selection of one of the disks?
Thanks To Andrew)Андрей Патрушев wrote:And so, if we have time...ЛИЛИЯ-Р wrote:the Morning can be Healing .In The Evening The Conductor. And so 15 or 21 days. Then a break with these wheels 15 or 21 days And then you can and following the same pattern.The break between the discs 3 hours.
I mean, one day drive the next day or two, etc.
Increase the day and normal at night - is this some kind of "chronicle" - it is better to see a doctor and take the picture (God forbid, a chronic pneumonitis - can and "flippers stick together"Пианистка wrote:Andrei Patrushev
and the cough passes)))
I think that the increase in temperature is the body begins to connect their resources to fight the disease, and really I don't see anything wrong. The temperature rises after listening and falling in the night, in the morning - normal. For me this is another confirmation of disk activity. And the cough really, thank God, is)))) cheers!!!
Thanks, Andrew
