Stabilizer.
Has thanked: 24 times
Been thanked: 142 times
Re: The Stabilizer.
Post by Маг.нет » Sat Feb 02, 2013 12:50
Can lacquer (pre-test to figure not "drip"), you can tape.......
Sincerely, MAG.no 〠
Ярый
Re: The Stabilizer.
Post by Ярый » Sun Feb 03, 2013 10:24
MAG.no
Any varnish will form in the epoxy or looking for a specific?
Re: The Stabilizer.
Post by Маг.нет » Sun Feb 03, 2013 10:45
And why the varnish on the epoxy??? You asked what the top (final) Mandala cover from wear and tear.......
Sincerely, MAG.no 〠
Ярый
Re: The Stabilizer.
Post by Ярый » Sun Feb 03, 2013 11:46
Well, Yes, I agree! :) Thank you!
Has thanked: 13 times
Been thanked: 49 times
Re: The Stabilizer.
Post by ФилиНН » Mon Feb 04, 2013 13:41
Visited there summer cottage(standing under the anchor against any rotting, decay, fungal and other lesions). Mousetrap with a piece of cheese is intact. Whether mice do not eat stale - one for the season took a long time, in the fall. Whether at the same time mental and wording against them tweaked, it works. But the mattress is polyurethane foam(backrest of the couch) that is used for sunbathing and standing outside under a canopy leaning against the house, they are in impotent rage gnawed, although get in the house-do not want(even produhi in the basement is not closed).
In General then... Against worms - lovers my plum work, it seems. Mice, too. Here's something a helluva lot warusaki independent. This undead was originally designed as a cool weapon target assignment, you say?
Has thanked: 5 times
Been thanked: 16 times
Re: The Stabilizer.
Post by Вячеслав. » Mon Feb 04, 2013 14:21
Hello,last observation,as something much more powerful was the effect of the stabilizer,more guided by circumstantial evidence,rather amusing...much more has become to do daily physical exercises,easy-postepenno sliding into the raw,increasingly, I notice that for example eating a carrot with a straight face,and all in the same key.
Re: The Stabilizer.
Post by Михаил_ » Mon Feb 04, 2013 14:33
must grow all products ....
Re: The Stabilizer.
Post by Михаил_ » Mon Feb 04, 2013 14:34
Warusaki Yes.... this is such a tricky thing. But they still react to the environment, i.e. they can be anchored via an external objective properties (a La the anomalous zone).
Re: The Stabilizer.
Post by ФилиНН » Mon Feb 04, 2013 15:04
Interesting... So breeding them for a certain(fairly local to site) - in stopper. And if in themselves they there made, that it was not a fart, and ...huh? :)
Or even abnormal area as its location to describe?
Re: The Stabilizer.
Post by Михаил_ » Mon Feb 04, 2013 15:28
in a very anomalous zone You is not very comfortable with the habit
better to use the body as the abnormal area through the clean-up thereof - they will simply burn nafig
Ярый
Re: The Stabilizer.
Post by Ярый » Sun Feb 17, 2013 15:34
I tips when forming objectives.
The situation is this: just over a year ago, my wife and I settled in an apartment after a complete overhaul. A few months ago to us from the neighbors above came the cockroaches. Apparently, in the riser or on the hood. The question is how to formulate the anchor and where to put it to the cockroaches gone? If the very wording of the anchor should take the form: "Cockroaches in my apartment", and the anchor put in the Homo between Stopping and Braking, whether this will lead to the planned effect, or when the wording of the anchors have to register the task into their care?
Re: The Stabilizer.
Post by Маг.нет » Sun Feb 17, 2013 16:00
The stabilizer is the translator's mental actions Operator in the World, and how to formulate it in the most part depends on the Operator (different Operators may have the same to formulate different words, even if ONE MEANING, and sometimes at this level "desires and intentions" to do without words, to the same work Images, Pictograms and Signs) at the location of the stabilizer corresponds to a trend (trend - vector action primary or secondary) is selected more often feels "correct or not correct", if necessary, adjusted. It is, in General, and in particular: "the cockroach escape" and "the apartment without cockroaches" can be similar as intention and different, because sameness of the end result "my life without cockroaches" are defined different ways: in the first case may be an attempt to control cockroaches motivations, i.e. the influence on the process (the dynamics), the second is control of the final result (static), and how it can occur (dynamics) is wide enough field to accomplish when you know how - is this trend when there is no clear understanding of "how", and the wording is often (but not always) more efficient end - (can fly and not go away or just die))))))))), I hope the essence of this message to catch out.......
Sincerely, MAG.no 〠
Ярый
Re: The Stabilizer.
Post by Ярый » Sun Feb 17, 2013 16:24
Well, of course! Then leave the version that is currently on stabe: anchor - "Cockroaches in my apartment" in the area of Homo between Stopping and Braking, but with the mental command that they just disappear from the home and, in the future, no!
Thank you!
Астрахан
Re: The Stabilizer.
Post by Астрахан » Thu Feb 21, 2013 4:03
Greetings,
Does it make sense to isolate the stabilizer from the bottom and sides, if he for example made of glass and metal bases?
Is it possible to draw a panacea matrix on the bottom for example?
With respect.
V
Астрахан
Re: The Stabilizer.
Post by Астрахан » Mon Feb 25, 2013 22:00
In three of the stabilizer, while simple on paper, pasted mandala and poured a thin layer of epoxy. Interestingly, the feelings, all three are different, depending on the overall picture emerging mandalas. Also there was a sense of altered space in the apartment.Does it make sense to glue all three into one, to enhance?Question about escaping the day, too, remains relevant. The question of "panacea" has resolved itself.
Sincerely,
V
МаксСк
Re: The Stabilizer.
Post by МаксСк » Sat May 25, 2013 11:13
All kind time of day!
Question to Michael in three pots with water, you need to do so?
Thank you.
Re: The Stabilizer.
Post by Михаил_ » Sat May 25, 2013 13:01
What nonsense. I did say about three bowl of water? no, of course.... I was told that you need three bowls (and never told that they the water). and say that you will need running water circulating in a circle. None of the basin of water there.
Re: The Stabilizer.
Post by Михаил_ » Sat May 25, 2013 13:03
the quality zones of the stabilizer are not associated with the direction of rotation of the water quality of the world, associated with the direction of rotation may occur, and always in one way or another as manifested in each zone
МаксСк
Re: The Stabilizer.
Post by МаксСк » Sat May 25, 2013 13:24
Thank you.
So came to mind. And as or secret?
Re: The Stabilizer.
Post by Михаил_ » Sat May 25, 2013 13:42
There are (collected-bought) ready-made components? what? photos of the Studio. N
МаксСк
Re: The Stabilizer.
Post by МаксСк » Sat May 25, 2013 13:57
There are ready-made stabilizer (basis oak glued Д450мм, there are Druze and all pribambasy as by the method, the epoxy hardener etal). Photos in the evening (the camera my daughter at the matinee). And how to protect information and photos (SEE)?
Друид
Been thanked: 3 times
Re: The Stabilizer.
Post by Друид » Sat May 25, 2013 19:37
You are clearly on the wrong radio station tuned :) Not at the armored car :)
МаксСк
Re: The Stabilizer.
Post by МаксСк » Sat May 25, 2013 20:45
Hello again.
If the question is from Michael for a theorist, or I figure it is just enough.
Here's my stab.
If you pumps cans and other then this there is no theory or so say the directions, but the technology I can try to make (the chemical engineer).
About the armored car with the radio do not understand sorry.
Друид
Re: The Stabilizer.
Post by Друид » Sun May 26, 2013 0:05
About the armored car... I mean what you heard is not the question that was asked. I meant the photo of the components (pots, tubs, etc.), for the manufacture of the future device.
PS: a photo of your stabilizer, I recommend to remove from public access :)
Re: The Stabilizer.
Post by Михаил_ » Sun May 26, 2013 0:22
Yes, the question was about the pots, hose, pump and so on.... it is expected that NASA will work long. As long as this is the first practical question about the enhanced version, and I'm saving your time, without a photo complete set and approved the matter (explanations) will not go further.
Cutting away from the photo staba nothing really depends - it is configured on the operator and it by and large to sneeze on external.
