СК1М
In the case of known impacts e.g. on business practice, the best results were given by the production on the audio in a loop continuously (24 hours a day, continuously for many days), soft streamlined wording in the common harmonious improving the welfare and development of all aspects of personal life and tvorchestva, administered through the job (business). Ie noted that this is pushing various options simultaneously, but has a side effect could overload the operator's business, i.e. the need to filter the excess out emerging opportunities.
You can smoothly shift into a new position (this is usually a real change in life and in themselves, related to the setup as would the other alternative), and a new provision that was not possible can become possible. Just do not this very shift to do with a purpose to access impossible, or moving to a standstill and remain in it. You just need to slightly change the system state through an approach that "will make something new, but we'll see how to use".Логик wrote:Yes, working СК1м gives sometimes to really understand what this option impossible. Signs that he submits it is difficult to ignore. (Examples from life, will not show who used СК1м, he will understand)Михаил_ wrote:Efficiency is good, not just when the SK "wings" event, but the operator can hear and see some signs, i.e. inclined to see the possibility of change.
ACC. what I mentioned above, does not fit in the described egregorial model and is in contact with her only as half of a whole. Somewhere earlier in this forum, I gave a brief his attitude to the egregors.Маг.нет wrote:the Genius of the Earth
The genius of the Earth is an egregore from which it is impossible to leave. Also, it is impossible to get out of the human egregore, while being a person i.e. having a human form.
the Tree of life
In ancient times, Magicians have made a scheme of the functioning of consciousness Genius of the Earth. The processes occurring there, of course, impossible to understand on a human level, but some abstract constructions allow one to assess the overall picture and, most importantly, make it possible Separations Magic. The study of the functioning of consciousness Genius of the Earth, the ability to enter in the desired channels, is the basis of all Separationthe Magic.
Sincerely, MAG.no
Combining natural processes - they are the Homo factor uniting into a single view that has a different interaction. Will lead a "fabulous" example. Put a man acts in the world as the only Creator (or small group) and the busy population of this new world of different creatures (by the way Zelazny is funny work, which describes a civilization in which there is a job - creation of new worlds in the planets, and it ...as it were popular, can't remember the name, sorry). While the view of ONE individual, the range of her personal experience and impressions are clearly narrow and limited, but individuals should make a LOT as they can start to interact in the world with many different sides and aspects. Multi-faceted. Here the principle of conservation of community helps to expand and work within the world as a whole.
But when the same principle regulates the social motivation of a person, which in itself must be a Creator, then it works in exactly the opposite direction. Of course if there was a uniformity, as the unifying features of society, a certain kind of uniform structure occurs. I mean the "ideal" option.
The same what I wrote above refers to the other side of the world. To "personal" (perhaps you should write without quotes) perception of world events. I don't know the documentary magic and esoteric sources with similar information, at least available nowadays. Although a number of references to individuals faced, but it is not possible to ask where and how their approach came from.
In direct comparison with a person egregorial part will be the subconscious world and the personal - his identity ... so to speak.
Again, in the above quote of Sator, the concept of the tree of the Sephiroth somewhat simplified, apparently in order to fit in a short text. To start with, that sephirah in the same manner to generate thrust (potential difference) for a channel tree, is an artificial entity set on top of what it was before. And to finish the fact that the configuration has changed many times and practice see traces of the old "tree" but see them as shadows. Who knows, this is the reason that they are residual effect or that are built so modern, even development of perception, uzrasine on specific signals.<
Well, a lot of options. One of them, if the character really is not suitable this technology can and really it is not worth using. Or Vice versa, is more fulfilling to "curb".Новик wrote:Michael_
Thanks for the replies long read(for it is written not a few) and reread too many times...
But need clarification:And what are we going to do?You put a negative anchor to the housing problem and now with it not even rushing with the UK. Defining SK is inherent in the wording of the desire of the operator, not the words. It is most likely that the events - related stuff. But the only reason is not in the UK and You.
I'm also not as simple ie I have is almost a daily practice: body-Aikido an inside job-at with elements of self-hypnosis+MM on the mood
My character is cheerful and friendly(i.e. no depressiv not) BUT there is one thing I'm very good. demanding why I write here now!
I have one friend who reads this and my forums, and he writes here sometimes... he has a lot of problems with the fact that plenty of practices with a strong desire to get the result gave the smallest possible or no, but sooner or later started to turn...
If the problem is the alleged "demands", i.e. waiting for some bright or a more manifest effect on time, "Packed" etc., then you may want to start with experiments that do not involve questions of principle and position of the observer, not ozhidala. I.e. to formulate an approach like - " I study technology to the most complete to use it," the Study does not involve the setting of requirements and deadlines, but rather an observation without interference.
The second point may have to work with audio V-series, if you haven't tried. As it develops the perception, and it is the accuracy of the language (I mean not verbal)
I did it the first time for themselves and almost by accident, and therefore without much expectations and was both confident in the effect, but acted to some extent on autopilot. Next is the matter development.What is БЖ1-2.x. BJ is the consolidated experience of the world (always positive) is displayed at one point. Hard to say, but it is.what I did is "fixing" this for items.
How did you do it? With the help of his own perception of the experience and its power? or it can repeat any?
To repeat, theoretically, can be anyone, but develop certain aspects of perception and contact with the planet's consciousness to a good level (refer to module BJ). I.e. for example from those who actually work at the club I have already two years, including almost any cope I think, well, maybe plus or minus with different quality released, i.e., the efficiency will change. An ordinary person will take some time. Not known. And motivation are appropriate and correct.
However to repeat what BJ will be difficult, you will need to come up with something completely new and this world is like, twice to play the same thing the world does not like - boring, i.e., redo will not be done, and without his participation, though opposite from the strain
The second aspect is that in fact it wasn't me, and the world itself, ie, I asked for the right or, more precisely, offered an interesting change of game conditions.
One person wrote to me that recently the work of the modules BJ was tracked in the info channel Reiki. Without physical media. This confirms the above. Ie once the structures formed have nowhere to stay, they feature the world as the sun. Of course this does not apply to technology implementation and to technical methods, i.e. this mostly applies to version 1.0 as such, and the technical implementation of the "enhanced" versions is the application of some knowledge and cellular technologies that do not relate directly to technology, although BJ is close to them.
The third aspect is my perception and my experience here in General not and, as personal power. Impact rather how I relate to the world and he treats me. And apparently it is this "situation" among many others. No, of course my perception had some influence on how built recording system such as the first version.
But in fact it was possible at all to do otherwise, because modules like "replication" or "copier" working without a SOA record....
Well, I hope You don't think that the record and copy of each BJ as something personally to do with me? I would have died long ago
Ie I only described the phenomenon, and using their experience did a number of technologies amplify this phenomenon, in the older versions. That it was possible to distribute - distributed. What requires with care or require special. means for the manufacture, sale yet.
and no. And where You saw the work artifacts made by "literature" ? point, me the right interesting.And what literature it is possible to read?I'm talking about the separation of "egregors" and "experience" of the world?this "subject" has nothing to do with the concept of "thought forms", i.e. this "experience" consolidated not egregorial, and personal
1. everything good started to happen to me when I began to trust the knowledge that is inside, not literature.
2. among the things that are inside, apparently there are a few incarnations that I did "shop" work, i.e. the production of artifacts with the use of traditional knowledge of those who are doing this from generation to generation, but it is rather a secondary factor influencing the use of some techniques, not more.
Not buyNUU is very similar to the definition of egregorei.e. the world, being the second party interactions, as it projects onto us the experience of many as a hint via BJ.
well does not look like. Egregore works in a particular manner in the social sphere he is interested in readership and eat. The most "predatory" is most clearly acting. In this case, even close to nothing.
There are simply "anomaly" of the world, called BJ, and it behaves differently.
Generally I've described on your forum and it seems to me more than once.
The aforementioned quote has NOTHING to do with the understanding of the BJ and especially the UK. We're talking about things that are not related to the presence of something in the sale and in the world.
The work by BJ is also not relevant, the question is, what are the rules on which it is possible to do something like a BJ. The second BJ the world to do is not likely to be one already there, it is ready to be projected, if that, and the interaction of these cannot be documented they just need ...well, to hear or understand. Well You want the guide "how to see" for the blind from me to. Ie sooner or later it can make everyone, especially given all support possible. But to discuss it now makes no sense. Those who appeared at the right time and in the right place, get some of this information, but everything has to go as it consistently, i.e., there is no sense to talk about the fact that it is not good to anybody and understand the fact of presentation. To the topic, once again, is not the case.
Since the BJ and technological or behavioral methods of creating BJ are completely different. Single - user level, the second in captivity-know-how.
Want to find out - just develop your work with BJ and practise using the module mentioned above is not in their own interests and in the interests of harmonizing the space around.<
Новик
amplifiers in Moscow, waiting for EMS to do their job for final delivery, + they will stay with me a day to install the program.I hope Thursday will be in the office, but with the EMS - not a fact.
Minus your in this party will be only three, and one more coming in a week, because the other party all disperse for domestic needs.
Then Supplement will be 2-3 weeks for those who do not have time.
She has long been ready, but so far it has no access to users. After its organization it will be some time to be available for free, I think about a year. Then we'll see.Дениc wrote:In the description of СК1М refers to a special computer system, which can work in conjunction with the device.Is it ready?
(the system / server because it uses sensors).
if not for the amplifiers to SK, then the next dayМаг.нет wrote:...and the expected output "Stabilizer" is planned soon?
Sincerely, MAG.no
not affected, just the system of the interior fixtures were not designed for the planting of box legs (apparently it is in the mail happened to him). In the result, despite the tight soft insulation, massive coil in one copy were separated by the method of breaking thick plastic boards which were mounting. I suspect that collectors could not imagine that such a breaking off (and treatment) at all possible
well, now they know
our mail is the worst email in the world...
the device will acquire additional super vandal resistance after the modification. I.e. if it can be to throw someone about it or someone knock and it will be all no-for-what.
In General production we can say nothing to do with. Ie it's not their fault, they simply have not calculated the coolness of possible loads.
But the first buyers of the stabilizer promise a special bonus.
The first 5 standard and the first two large will get increased power at the expense of the author's work in manual mode. The next will be on production, so the improvement will be eliminated.
You what stabilizer to reserve?
Today I received SK+HF until held in hand and familiar - all intevals and obrydalas, tears flowed.30 minutes sitting. The feeling is great. Strong tension in the head. Interestingly,and I knew that today will bring the shipment was right after a physical connection with him, and until I called and said that bear, I sat at home and waited. The kit came with a name, and brought the names Parliament and of the Stabilizer, this magic trio turned
Michael, You will not believe it, but this night had a dream in which you saw the written word Stabilizer and the word Bonus. Honestly, I took it at the expense of expectations of the product, and suddenly You write about the bonus.
photo of semi-finished product will not spread.
The stabilizer is so round ... field, let's call it "map"
based on booolshoy metal dish, filled with the composition with defined properties, crystals and mandalas determining zonal characteristics. Top are heterogeneous (different formulations are used) but implemented at the same time (as a whole) to the polymer layer reflects the already "collected" the picture of the world.
on the surface of the hardened mass the marked zone boundaries, the centres of the zones, the boundary region, they all have certain impact properties.
(properties will be documented at the output of the product in the light).
Machine audio Jack, which acts on the whole space and is able to demonstrate one of the traits as dominant or to broadcast personal language.
For space travel ... well, in this case, the word cartridge is not very suitable, I think, which is the word anchor.
They are of two types. To specify the object, device, process, object (including non-material, or describing the combination of material objects - for example a firm). And to set additional influencing factors, for example, "spirit General health" is to create a trend to improve the health of frequently ill employee, and how much it happens is not important, for example, he(she) will find the right doctor who will diagnose you, or take up a sport, or happen direct impact and so on.
Ie a lot of options. Additional factors yet implemented only a few, and I think a lot of them don't need.
All the basic techniques associated with the displacement of the armature in the operating area of the device in a particular area. For example, a stabilizing influence on the technique is offset in the area with Homo-qualities that have a stabilizing effect.
The anchor associated with those whom he has exerted influence through the marker and can be reset to zero, but I can imagine that for many will be useful to keep many of the anchors on the active view.
In addition to the anchors in the kit with stabilizer will go a few special items to carry them with you and have an impact on the system operator stabilizer. Their role is special protection of the + operator to remotely turn on the stabilizer special lock mode external influences.
Or to provide for someone, from something like "Guest login", which is associated with the possibility to ask for example on territorii certain qualities, which for someone may not be comfortable.
All additional anchors and items will also be boxed sale + most of them will be free documentation. True homemade will be somewhat weaker (other stages of production).
The differences between versions.
(N)Normal 29cm diameter, complete 24 standard anchors and 4 specialized for each type.
(B)Large 45cm (total area having, as is well known quadratic dependence is approximately 2.5 times more)
includes 50 anchors and 12 specialized for each type.
(M)Small. Maybe will be implemented later, if it will make sense and demand. Will be similar to the homemade paper in the simplest version, but it will be an additional charge. The size of the width of a sheet of paper, so that you can wear in a folder with documents. Will be equipped with thin plastic anchors on adhesive basis. If we are to do it - will be cheap and disposable principle. I.e., to be used and discarded if desired, or to defer recorded in the far-back corner. Included will be a few anchors.
(C) not super
just redistributable - this is a description of the components, the graphics for their printing and the process of self-production.
"factory" versions are from handmade, special production(special charging system, laser technology) and a special applied materials. Plus will have one small know-how
Versions N and B will appear at the same time, but a lot will first be made no more than 5 (there are problems with the "bottom" it has ceased to deliver to Russia... will need to continue to order the production of that long and dreary, we need certain material quality and form).
And the "N"OK do what you need.
The fact that there is demand for the "M" with the free version is still doubtful, so she is not to be, and now there is no time.
Publish all data for free version will be delayed for 1-3 days from the release of the commercial.
The value of N is 60, 120 B
Yes. The stabilizer is associated with the operator. The operator does not have to be involved in the processes described on the "map" of the stabilizer, but should be a kind of observer in relation to them.
Several stabilizers tied to one operator begin to operate as ONE, i.e., they are mirrors of the same process, but with the addition of several their power is not growing very much. (just the number of field managers is increasing) is associated with a number of processes linked to the operator.
Power version B is more than two times bigger than version N, but it makes sense for example for the stabilization of a large plant and so on.
As always BJ, SK, IIM - simbiotica with the Stabilizer of any versions for the most harmonious work, and all these mutually reinforces each other.
Well, as always that was not raised extra flame Stabilizer not materializing desires, does not replace physical processes, but only affects the information components. Where "late drink Borjomi" may not affect this... you need to understand.
Full custom description will be later. To configure the object will be enough.
One reservation request for a "B" is, I remember about it.<
(C) not super
Want to I didn't know a moment's peace (can't stand to be efficientlyМалика wrote:So maybe it is possible to prepay ?
Yes.. I am glad that the product came in time
PS there's a joke I came up with for the regulator, I hope all will appreciate
Veronik...
in General, the STABILIZER, as the name implies, it is primarily to stabilize. F-tsiya influence on the processes of such a thing, which should be used very carefully, because it is actually manual mode. I mean, that is a "desire" to brelivet understanding of at least the optimal vector.
I.e., the range of possibilities is associated with the qualities of tenacula + with the ability to create and break links in the interactions. Sometimes the regulator if you use them carelessly, not stabilizing, and administering f-tsii can cause not the effect, because the direct instructions of the target language in it, for these purposes is the UK.
The stabilizer is good for neutralization of external and random factors, and, conversely, additional opportunities where "stagnant" + give energy where slowly moving.
on the theme B - don't know. B optimal for tasks where there are many links in the process in one way or another, something or tied to any energy-consuming Affairs.
In General, the device is primarily conceived as a stabilizer to eliminate bounce from the zone of personal processes.
