About the parlor
Жека3000
Post by Жека3000 » Thu Nov 12, 2009 0:01
Иррина wrote:will try to master
Try it!:) Tell us then!
Post by Guest » Wed Nov 18, 2009 20:09
Hello. please tell me, how do you create a chamber in Krasnodar
Ростислав
Post by Ростислав » Wed Nov 18, 2009 23:22
Guest write in PM your phone will tell you where to find the office!
Лео
Post by Лео » Fri Dec 25, 2009 17:46
My girlfriend recently purchased the SS. Now we carry her in turn, still loads of water. Tell me, is it possible to share or SS should be personal? If possible, does it have any meaning or effect would be too small?
The same question about the rest of the parlor.
Жека3000
Post by Жека3000 » Fri Dec 25, 2009 18:08
Leo
Can wear any number of people, but the efficiency is naturally reduced because SS is not with You constantly. Can be used without compromising the effectiveness of the Parlor which are not constantly and doing them is a mirror and a rug.
Идущая вперед
Post by Идущая вперед » Sat Dec 26, 2009 6:10
Leo
you can ground the room when you pass another person - ie half an hour to hold the Golden ball joint towards the ground... or just put on the ground for half an hour.... although I gave the room the girl which has a bad headache - she was attached to the forehead it is literally 15 minutes the pain is gone and I'm not grounding her just put it in my pocket without consequences for themselves
Post by Dimas » Sat Dec 26, 2009 22:00
THE ROOM GROUND IS NOT NECESSARY! :)
Экко
Post by Экко » Thu Jan 07, 2010 20:48
Looking for information about the working principle of the Parlor on this site and on the network, but nothing concrete found. So how does this work??? The principle of MM, Alfaria understandable, but it's something very obscure..
Post by Dimas » Sat Jan 09, 2010 23:29
ASD
Forgot to remove the Svetlitsa Super from your jeans pocket and washed it with my pants in the washing machine... She is not "dead"? Why I ask, because in case there is a very very thin crack on the body near the groove...
Post by Guest » Sun Jan 10, 2010 3:39
I also have a very very thin crack in the housing Chamber. Therefore, I package wear.
And one of the element Mirrors small dent.
awaken
АСД
Post by АСД » Sun Jan 10, 2010 22:29
Dimas wrote:ASD
I think that everything is fine. Next week will be in Moscow, take a look. Can check for GRV.
АСД
Post by АСД » Sun Jan 10, 2010 22:36
Anonymous wrote:I also Have a very very thin crack in the housing Chamber. Therefore, I package wear.
awaken
If this very thin crack in a groove that is on the perimeter, then do not worry, if in another, it is possible impermeability is broken and then it really is better to wear in the package. Small dents on the element of the Mirror will not affect the operation of the element, since the film structure is flexible and not damaged from kneading.
Магирани
Post by Магирани » Mon Jan 18, 2010 1:48
ASD
I have a question about the SS. It is possible to structure the water. OK. But will remain of this structure, when the water boil? I.e. whether SS to structure water, which is then poured into a kettle and bring to a boil?
АСД
Post by АСД » Wed Jan 20, 2010 15:50
Магирани wrote:ASD
Of course, when boiling, the structure is partially destroyed. Exactly how much is not know, have not investigated. But if you structure the water before boiling, it gives a smaller scale, there is improvement in him. composition. Therefore, if possible, it is better to structure and to boiling and after.
Post by Guest » Wed Jan 20, 2010 18:58
Me still here what question interests. It was probably for the developers (ASD)
ASD wrote that the key to good water to structurewhat. Does this mean that the information structure in the "CC" in keys to "Good" and in the "Benefits" overlap? And here arises the question, if Yes then how effective structurewith water "SS" compared to a front room the good or the key to a good?
Василий_V
Post by Василий_V » Wed Jan 20, 2010 22:54
Dimas wrote:Carilo
And I also have Svetlitsa-super,bought from the developer directly..I noticed when she put you. at night,dreams become very vivid and memorable...the load on the neck,on the lanyard,but the PARTICULAR physical actions don't feel...easier for her to concentrate.
As its on a cord to wear it? she hooked not deductible.... :roll:
Post by Guest » Thu Jan 21, 2010 2:02
I explained already. Take a ribbon, tied in a ring. Invest in a furrow. 12 hours decussation, back down to 6 hours, optic chiasm. Rise to the top, with the two sides of the groove, the threads on the surface and get under the lower output, around 10 o'clock and tighten. All! The finished product with two locking points.
Not turned, worn on the neck, in the midline of the body, at the level of the solar plexus as well as wrote az
Galan
PS we like the thread, again, EV, passwords lost with the next inevitable reinstallation of Windows.
Будующий покупатель
Post by Будующий покупатель » Thu Jan 28, 2010 22:51
Please tell me do you plan to release new products?
Maybe some new versions of parlor?
Or is the idea fully realized? new products will not?
Петя
Post by Петя » Sat Jan 30, 2010 1:54
Будующий покупатель wrote:please Tell me do you plan to release new products?
Support question :)
АСД
Post by АСД » Sun Jan 31, 2010 1:31
Support question :)
New items will be. Work on the development of technologies continues. We will inform about updates after appropriate testing.
Post by Guest » Sun Jan 31, 2010 9:29
And can custom make a device that insulates me from the physical reality? From this space-time continuum? Or a device to get into the fourth dimension, that is, during? So to say, to obtain four-dimensional perception, without leaving the physical body?
Пси-Комбатант
Post by Пси-Комбатант » Mon Feb 01, 2010 10:39
A device that allows you to chat to people living in a parallel physical realities? You're not going to deny that such realities are an Infinite number?
Post by Guest » Mon Feb 01, 2010 11:41
Question by ASD:
ASD You wrote that the key to good water to structurewhat. Does this mean that the information structure in the "CC" in keys to "Good" and in the "Benefits" overlap? And here arises the question, if Yes then how effective structurewith water "SS" compared to a front room the good or the key to a good?
АК
Post by АК » Sun Mar 07, 2010 3:56
http://kostya-kiev.livejournal.com/326669.html
(c)
Need testers of the new magical device
Read in our group Vkontakte ad Maria Chevguz:
In January is preparing to release a new product of the laboratory of information design ("Svetlitsa 5-th generation"), his studies at the International Academy of frontal problems surpassed all expectations (PI MD).
In St. Petersburg will be held an additional study by independent scientists, laboratory Kirlian ru, which involve all of those (the control group about 30 people).
___________________________________________________
ASD, could You comment? Than the front room of the 5th generation is different from the drawing rooms of the 3rd generation? Any details about testing that "exceeded expectations"? Why the 5th generation, not 4th? When can we expect the end of the test Chamber 5-th generation and its publication?
Новик
Post by Новик » Sun Mar 07, 2010 13:20
Well, the most interesting question to ASD.
Why not acknowledge the link with the Boris Zolotov? Not quite satisfied with his dubious reputation?
