Advice from Andrei Patrushev
Post by Dimas » Thu Apr 02, 2009 16:23
Anonymous wrote:what worked? worked with an alpha of 15 days.now a break.a feeling as if the addiction damn...
15 few days,at least 21 days need...and what worked out that's You know better :) the dependence of the device can cause,on the contrary,will deliver (or will do much to facilitate) from existing ones.
Алексей Кузнецов
Post by Алексей Кузнецов » Thu Apr 02, 2009 16:42
Yes, Dima as well saves I week after "Explorer" began to speak like Andrew, slightly stretching the end of words. Pulls and pulls to embark on the path for the "Conductor". Wait here after 21 years of one day and again seem to go after him. And "Star traveler", too, everything is addictive, especially the bells of the New world and the tempest "Solar wind".
Post by Dimas » Thu Apr 02, 2009 16:59
Alexey Kuznetsov
So You are very lucky that you are so tighten to a path of self-improvement :) :) :) :) You are the first from whom I hear about such,mostly, few,especially the first time,it was just fun! :ay
АЛЕКСАНДРРРР
Post by АЛЕКСАНДРРРР » Thu Apr 02, 2009 17:18
KU KU :) ANDREI PATRUSHEV :o TELL ME PLEASE: AND THESE ARE THE THINGS YOU CAN LISTEN bc bc
http://torrents.ru/forum/viewtopic.php?t=1710944
Post by Guest » Fri Apr 03, 2009 12:57
hmm.poor poor Mosk.as above it only not bullied.binaural beats is like crack pulls and pulls :(
Post by Dimas » Fri Apr 03, 2009 13:10
Anonymous wrote:hmm.poor poor Mosk.as above it only not bullied.binaural beats is like crack pulls and pulls :(
This is Your personal experience?
Post by Guest » Fri Apr 03, 2009 13:14
Guest:
and I think that I have some sort of dependency to the disks.here we stop to listen, and as if it draws me again to switch on and listen...I think it's crazy.on disks that suggestion what is what???
Dimas:
suggestion is not)))))and if drawn,then that is not processed)
Here is citatet Andrei Patrushev, I was specifically copied to the ward, a lot of useful tips and nuances
21 days - the period of full fiziologicheskoi adaptation (after which all procedures and medications can lose their effectiveness). In light of our recent investigations, it turned out that it is better not to bring it to adaptation, and to stop in time to avoid re-adapt ourselves. As a result, the efficiency is considerably improved. Optimally 15 15
I understood it so. 21 days study is not as deep as the 15-break-15. That is, the Guest has simply not yet all worked out and there is no adaptatsii and the brain still requires). But when after the break listen to another 15 days the effect will be deeper, so there is no reason for concern. And after full consideration, thrust to drive there, checked on my experience.
Post by Guest » Fri Apr 03, 2009 18:02
most likely all these rhythms placebo effect...making money...
Елена_
Post by Елена_ » Fri Apr 03, 2009 22:30
I'm about a year listening to the Explorer... the exact time between the courses don't measure, but I heard somewhere 4-5. I think, over time, decreases my ability to take. Before I somehow fell into some heat, and now just laying inside no response (I think), relaxing not so much.
And yet... I do Sleep much better (more Healing you listened to and Dec alpha session was).
But problems such as lack of confidence, communication difficulties, loneliness has not gone anywhere :( Easily upset over nothing and occasionally fall into a depressive state. Maybe you should try to set goals (I did one course CD for self-hypnosis, but to no avail)... or change the approach? Why doesn't it work? No special changes in my life during this time did not happen, although I would like.
Post by Guest » Fri Apr 03, 2009 23:03
Elena
and maybe still, the psychologist needs help, and not ordinary bee-rhythms?...all taki seems to me not all the problems of the chemical composition of the brain and alpha and other waves and from the perception of the world....
Post by Guest » Sat Apr 04, 2009 0:27
Андрей Патрушев wrote:
Anonymous wrote(a):
Hello, Andrey. In the second round listen to the Healing. After listening, there is a severe itching of the limbs, as an allergic reaction. The first time was the same. The water they drink. What does that mean? The body is cleaned or does not accept the program?
It was after? With the rash? Maybe just from a motionless lying creeps?
Hmm :o No, not goosebumps. Exactly, this is after the Healing. I alternate through the day with a Guide. After such a reaction no. I'm telling you - itch, damn it! After the first year decided that it is necessary - reaction is all different, I understand. But the second year is too much. Does anyone happen like that? Rash special there, just a little redness.
оуаакун
Post by оуаакун » Sat Apr 04, 2009 2:28
Елена_ wrote:But problems such as lack of confidence, communication difficulties, loneliness will not leave Easily upset over nothing and occasionally fall into a depressive state.
From all the above helps not alpha and Beta.
You can still Range to listen to.
Елена_
Post by Елена_ » Sat Apr 04, 2009 12:47
оуаакун wrote:you Can still Range to listen to
This theta? :)
оуаакун
Post by оуаакун » Sat Apr 04, 2009 14:36
Елена_ wrote:This theta?
No, not theta.
Gamma session should be for Mind Machines. ( whatever they are called do not know).
You can find the disk Jeffrey Thompson's "Gamma meditation system"
there is a track Outer World. Meditation Golden light: while listening to recall a problematic situation or person from the past and mentally surrounded by Golden light. Then just relax, surround yourself with Golden light and quiet to hear the rest of the track to the end.
A lot to listen to. Gamma can enhance the A\D and cause anxiety.
Post by Андрей Патрушев » Mon Apr 06, 2009 18:13
АЛЕКСАНДРРРР wrote:KU KU :) ANDREI PATRUSHEV :o TELL ME PLEASE: AND THESE ARE THE THINGS YOU CAN LISTEN bc bc
You can - just music, all the rest is Your intention, regularity and faith...
Post by Андрей Патрушев » Mon Apr 06, 2009 18:22
Елена_ wrote:I'm about a year listening to the Explorer... the exact time between the courses don't measure, but I heard somewhere 4-5. I think, over time, decreases my ability to take. Before I somehow fell into some heat, and now just laying inside no response (I think), relaxing not so much.
And You never did anything in life to get out of depression, to stop being upset over nothing, to communicate with interesting people? It is useless just to listen to discs of any kind - they can only help to get the ball rolling and the rest is in Your hands.
Post by Андрей Патрушев » Mon Apr 06, 2009 18:29
Anonymous wrote(a):
And You actually like this CD? Maybe it's a trivial annoyance that I have to listen to "is." People who suppress some feelings (for example, believe that the way to behave badly :)) this is a common...
АЛЕКСАНДРРРР
Post by АЛЕКСАНДРРРР » Mon Apr 06, 2009 23:27
:oops: ANDREW :o SO THERE ARE NO PLANTS???? bc bc
List of Programs - Installations recorded on the disc:
1. I believe in myself 100%!
2. I believe in your abilities!
3. I certainly believe in yourself!
4. I always wisely and intuitively to make decisions!
5. I intuitively understand the situation and its possibilities.
6. I believe in myself in any situation!
7. I'm confident - Here and Now!...Etc.
IT TURNS OUT IT'S A HOAX :oops: :) ??? bc bc
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Tue Apr 07, 2009 0:25
АЛЕКСАНДРРРР wrote:TURNS out IT's a HOAX ???
"Oh, fool me not difficult,
I obmenivatsa happy!"
(A. S. Pushkin)
So, any wish of the client.... for his money... bi
Post by Guest » Tue Apr 07, 2009 0:49
Андрей Патрушев wrote:And You actually drive like this? Maybe it's a trivial annoyance that I have to listen to "is." People who suppress some feelings (for example, I believe that his behavior was not good ) is often found...
Just Healing love. Explorer worse - it is already very long :? And during the Healing feel good. Maybe it's because my body is cleaned?
And the Rainbow what came up? What a fight, what helps?
Post by Guest » Tue Apr 07, 2009 0:51
Гость wrote:Andrei Patrushev wrote(a):
And You actually like this CD? Maybe it's a trivial annoyance that I have to listen to "is." People who suppress some feelings (for example, I believe that his behavior was not good ) is often found...
Just Healing love. Explorer worse - so it is very long And during the Healing feel good. Maybe it's because my body is cleaned?
Oh, by the way, I austeno to blame themselves for any reasons
Post by Андрей Патрушев » Tue Apr 07, 2009 18:52
These guys are absolutely honest, you wrote that all of these units recorded on the disc BELOW the threshold of AUDITORY PERCEPTION. This means that the drive has no settings there, and they are spelled out on the website - You've read them and they were in your head. Now just need to arrange for regular listening, in which You do these installations will be in my head to turn. A little not fair, but it actually works...
Post by Андрей Патрушев » Tue Apr 07, 2009 18:55
Probably again blame personal trance history (see FAQ), and in this sense the body is really clean...
And about the Rainbow has a lot of what is written in the appropriate branch...
оуаакун
Post by оуаакун » Tue Apr 07, 2009 19:02
Андрей Патрушев wrote:These guys are absolutely honest, you wrote that all of these units recorded on the disc BELOW the threshold of AUDITORY PERCEPTION. This means that the drive has no settings there, and they are spelled out on the website - You've read them and they were in your head. Now just need to arrange for regular listening, in which You do these installations will be in my head to turn. A little not fair, but it actually works...
And Kelly Howell is also a liar? :?
http://www.brainsync.com/product.asp?specific=200
Post by Андрей Патрушев » Tue Apr 07, 2009 19:10
Who knows... There I didn't find detailed descriptions of the technologies. But I can tell you - where is the statement that the phrase written below the perception threshold, and not disguised in some way, is only your intention, regularity, consistency and faith - that is, ritual.
