Panacea or product "P"
Re: .Panacea or product "P"
Post by Михаил_ » Tue Jul 02, 2013 0:49
the past is fixed (difficult to change) only at shallow depths or when there is dependence on significant events. I.e. Yes, it is possible described. But not always.
And Yes, there are pitfalls and dangers.
Just used some hack with the past in the past to remove the old magic build (nested bias). Not saying that has created a change in the present (see else), but some - Yes. Although I am unfortunately not an indicator in which something can be judged.
There are still some strange things, for example a person can not change the past so much, how many the branch of reality in which they live or other aspects. Ie need to consider all of this some multiply connected sponge versions-times-realities and impact slip someone whose past is rewritten in the least costly manner, or does not slip at all.
In schools where time is energotherm parameter and changes the density in the course of its existence (which is actually not quite true, there is changing it to another setting), it is believed that the past changes hard or any way.
In General, I'm not going to give the technology associated with it due to the fact that and so chaos enough and new I don't need and very few people want, but the above simple techniques in some cases will actually be effective. Depends on a number of parameters.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Jul 02, 2013 6:35
Алекс С wrote:the fact of the anecdotal situation that some Nlper noticed that the past changes.
Kind of pedantic approach to any study information, and I wrote:
Маг.нет wrote:So the thing is that such Techniques can only change the subjective past, or rather the attitude that practically "does" not affect the World, not change it. And changes often (not always) possible to tell time (experience) - activating the previous anchor picture of the past (for example encountering eyewitnesses "altered past") this Technique can begin to fail and the end result will largely depend on the strength of Consciousness (whose consciousness is stronger, the picture of peace and "real") and its configuration. Ie actually this is a very good Technique (recapitulation) to change their relationship to the events of the past, but alas doesn't change the past (well, if You are not conscious of waterbending - the ability to adjust the World at the point of the last changing).
1. This Technique only affects workers (Operator) with it directly, others indirectly (only through Operator), i.e. direct impact on the world has not.
2. Changes can not be considered sustainable because of the above already described, once again, the interaction of this Operator with the witness "picture of the past before correction", it is possible to rollback "to the previous picture of the past" if the witness's memory about those events is good, the story is important for him and mind stronger. So we can say what's going on fill-in "picture of the past" and there is a likelihood of rollback.
3. The magician knows (feels) that he is a Magician or he is not a Magician.
4. Miracles and sustainable results from the Technique are two different things, so is not appropriate about them in this context to talk.
5. The miracles and the relation of Operator to peace after the recapitulation can vary, which may entail some changes in the interactions (the world has not changed in the past). To make it clearer, the world also has its own memory called the Akashic Mirror, if the memory of the event for any reason changing in the mind of a man, in the memory of the world ", a record of the event" remains the previous version (and it is more meaningful, more objective or something), although there can be "a little correct history", but it needs to have first at least Operator access, and secondly the ability to work there, and thirdly, the "new history" should fit - be consistent with other surrounding sectors and the Technique of recapitulation does not do so.
Sincerely, MAG.no 〠<
Post by Михаил_ » Tue Jul 02, 2013 12:34
hmm... Yes... will correct its message in light of the above MAG.net - I always wrote a little wider and I think it's left overs. I was referring to the recapitulation and correction of deeper current incarnation as a case where it can work effectively, including the fact that the reduced factors of the fixing reverse (old) picture of the events - well, if it is very simplistic, as long there is no desire and reason to describe. I.e., the farther into the forest, the more wood :) But without a proper understanding of their collection rather really a coincidence and not a pattern Mage.not entirely in his message right.
Алега
Been thanked: 3 times
Post by Алега » Sun Jul 07, 2013 1:52
Is it possible with the aid of wheel power stabilizer and/or the UK ?
Post by Михаил_ » Sun Jul 07, 2013 2:54
you can of course
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Mon Jul 15, 2013 16:44
Can I use as a medium for solidification a concentrated PVA glue?
(I started to do - there is a long course and in layers - the digital panacea + PVA glue + video)
Usually in the theme of the epoxy used - I decided to ask.
Post by Михаил_ » Mon Jul 15, 2013 19:57
well, you can, but it will be a little different.
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Sat Jul 20, 2013 18:21
Almost a month has passed since I, satellite maps and generator separater, among other things, the place of my residence. So the house finally and unexpectedly activated the gas (almost a year the house was without gas). Before my entrance suddenly broke the flowerbed and planted flowers :o and blooming (probably someone met the "dear guest"). I twisted a finger at a temple (middle of the summer heat and it's wrong), but to my surprise the flowers have taken root and continue to blossom. Place for garbage was almost perfect. Disappeared rats, although they are funny and I do not interfere. A week ago, builders and above and below and from the side suddenly finished work and don't knock on my head :). Appeared cleaner and now in the stairwell and on floors clean. Invited friends and relatives from the Urals to yourself for a week or two. Unexpectedly agreed :lol: although the plans have long been the Crimea, and booked at the hotel. Life is fun :ay
Кимили
Has thanked: 6 times
Post by Кимили » Sat Jul 20, 2013 18:53
panacea + card= power!
new Elevator ( Otis) in the simple Stalin-era building, the new( completely) the ladder group. the year of 2012.
asphalt to the neighborhood !! ASF has not been since 2008 ( the construction and delivery of the Mr). the year of 2013.
the bus FROM The Mr to the metro( previously 25-30 min walk to the bus stop). the year of 2013.
"small" "coincidences" do not even write:)
Post by Михаил_ » Sat Jul 27, 2013 0:44
АндрейКо wrote:May not very topic, but something the world is happening very quickly magicnet increases(?)... The power of the newly-made items (using digital panacea) has clearly become stronger.
And that is only noticeable now? I mean it is already a month say.... including about the fact that the power of all of my products will grow (including previously made, too). They are environmentally friendly, so as to restore peace, balance himself in the direction of such as they move.
Post by АндрейКо » Sat Jul 27, 2013 1:04
Михаил_ wrote:And that only now has become noticeable?
It was noticeable earlier, but so clear and quick growth what tonight felt.(before the giraffe probably...)
Post by Михаил_ » Sat Jul 27, 2013 1:10
well, just the last days.... (not just today) are a fun process and curiouser and curiouser in the world :)
people do not have any relation to BJ also noticed very clearly and plasticity and the strengthening of personal abilities and the implementation of different jokes from the big to the small things, sometimes quite anomalous.
Алекс С
Has thanked: 2 times
Been thanked: 7 times
Post by Алекс С » Fri Aug 02, 2013 13:24
Andreyko say why :)
I don't want to relax, I want to WEAKEN.
I am at this stage of life are classified as "rogue", i.e., to the comrades who can afford commercial products only because of sheer need or just rarely or if the product is inexpensive. It is not in money, but in the family. Financial decisions are made jointly, as well as isoteric in the family I'm the only one, not all my desires are fulfilled. Especially since my son was born and priorities changed even more. Just yesterday, "ogreb" from the wife, ordered not only agreed labotomize sling-scarf cotton-flax (thanks to Michael for the theme of the children), but after him this soft knit, although the issue price of all 1150р.
So, while the main emphasis is on free products. Especially when to give.
The second trouble I'm a perfectionist. This means that if there is a way to charge BJ as much as possible, I should follow this way and not any other. Perfectionism is bad, but to do nothing I can. Tell me, HOW I can give the product person if you know it could be better??? Therefore BJ I got charged for the kiss these goodbye, first alphanumeric matrix, then erase the token if the bracelet, then disassemble the parts, charge video with the laptop at a distance of 30cm from the screen, turn, charge again, then the screen in focus, too, on both sides. First video is not a panacea, low-resolution, then high. Then lies on the printouts of screenshots. Of course, every day shift, "stir". Trouble, by the way, a little bit, just a long time.
But "plateau" is guaranteed.
Of course this is not a complete "perve". I don't give a P with bismuth and shungite as trouble drilling a lot and do not reinforce with epoxy so as not to spoil the appearance of wooden bracelets. But, I think, is doing fine.
As soon as the digital panacea, was told that it was a completely different technology. Close to PC as I recall.
As "charge" the product erases the previous exercise, the question arises, and will not erase if the digital panacea so diligently and for a long time charged units earlier technologies? And isn't this "charge level" "weaker" than videosurface.
That is the question.
Of course, the term "charge" in this message is meant as understood by Michael.
As Michael wrote the message, I will add a few words.
I don't know how to operate a commercial hologram, but before charging was carried out with a laser, whose power was important and the finished product was "stronger", "more charged" than the Lite version. And since nothing is the same, it means a literal matrix, videonarezka and digital matrix giving the result.
Therefore, I must either choose the strongest of the three, or to perform them sequentially.
I am ready to perform consistently, but I have to be sure that will not deteriorate the performance characteristics of the product.<
Post by АндрейКо » Fri Aug 02, 2013 14:25
Алекс С wrote:And isn't this "charge level" "weaker" than videosurface.
Need to check, but remember MAG.no somewhere wrote (paraphrase in my own words):
If panacea contains 1000 points, the letter matrix 20 pixels, digital, some video and some add...
In the result we come to the conclusion that just will not weaken.(unknown if it includes a digital matrix of all points letter...)
Better all three ways to simultaneously charge (I charged the panacea - bracelet - no conflict is not felt but when 3.0 n was not to do that from the 3.0 L - I immediately knew something was wrong and reread the entire thread... had to repeat everything correctly)
If the nonsense you wrote - please correct.
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Fri Aug 02, 2013 14:39
Not better than all three... In any case, is not always better. MAG.no at the time distant led a good example on the subject of what would happen if the 2.0 card transfer to catch a Panacea, IMHO, in this case an example is also relevant.
Маг.нет wrote:I'll try to draw - to take the sand (nursery) form the "stars" and make a star (say it is a Panacea) of sand, and after this asterisk is round (let's say it's 2.0) mould, of smaller diameter, where the piece of the ray will be clipped, where the inter-beam space sprockets is filled, that is, it may turn out not quite stars and not quite is something between.... But in any case, extremely limited example, the trim range and settings as such would not be a mutual desire to balance the difference, and it may be that the top of this "star" more useful point. I don't know how so clear.... but I will hope....
Post by АндрейКо » Fri Aug 02, 2013 23:53
Андрей С. wrote: "pokojowka+matrix" != "pokojowka" != "the matrix".
And try the "pokojowka+matrix" to compare with "pokojowka" + "the matrix" (the processes together and separated in time)
with your statement clear:
the Union of sets a and b is not equal to and not equal to
PS a Guinea pig the second day is behaving strangely - rearranges his bowl of food according to strict mathematical laws;
x1 y1 x2 y2... she has x1=x2 if y1=y2 and const1=const2 complied with all the provisions of... - was it the artifact of 4.5 sheets A4 panaceas...(but the pig is probably less scary than the dog, the cat, the crow...)
Post by АндрейКо » Sat Aug 03, 2013 23:43
In the Guinea pig after artifact on the digital panacea woke up the instinct of the correct otrigine-sharpen-self trimming!
I'm confused - I'm so sure no scissors, forceps not to do!
(this happened after the installation of the artifact immediately after harvesting the cells... along with cleaning the wool...)
Even took a picture of the claws - back nature of the program - a fact.
С. Альбатрос
Post by С. Альбатрос » Sun Aug 04, 2013 0:58
АндрейКо wrote:PS Guinea pig the second day is behaving strangely - rearranges his bowl of food according to strict mathematical laws;
Andrew, it seems Your pig has nothing to fear :) And anyway, I have a strong suspicion that in a past life Your pig was albert Einstein, and now paid the price for their theories :)
Post by АндрейКо » Sun Aug 04, 2013 1:21
S. Albatross :)
Thank you! On the one hand it turns out that the garbage you write - but if you think of it - becomes clear for the simplest examples, as a Panacea builds fine, corrects various disorders.
Алхимик
Post by Алхимик » Mon Aug 12, 2013 6:11
Thank you for the quick response, Michael. And do you ever sleep? :)
Post by Михаил_ » Mon Aug 12, 2013 6:13
And it should really? why ? :) I sleep when I need to do something.
Алхимик
Post by Алхимик » Mon Aug 12, 2013 6:19
I guess I'll ask crazy from your point of view question, but does the man not need sleep?
Post by Михаил_ » Mon Aug 12, 2013 11:39
I did not say that he did not sleep? I just didn't sleep much when I'm comfortable.
here half of the forum's dream on the occasion of the normal state of body and mind udobnogo is reduced to a minimum, and this minimum is actually designed for the intended purpose and not as a person-contused (normal).
It happens that sleep a lot, when a lot (not in the sense of fatigue and physically feel the need to work there), is that little. This is usually at a convenient time occurs or unexpected. When as. This is perfectly normal and many here as I understand it, that's at least judging by the night of yesterday's correspondence with people who, as I understand it and still go to work, unlike me.
The dream of the human need for functional and not for leisure (for the most part).
Алхимик
Post by Алхимик » Mon Aug 12, 2013 11:47
Never seen this view of sleep (or no attention).
Thank you for the Navoi vision! :)
Post by АндрейКо » Wed Aug 14, 2013 0:09
Used "special means".
Found a spot on the map - got the photo at all scales - download.
removed the card with the message that there is no such permission.
Each remaining file processed "means"...
The intermediate "results";
1. Hours ~15 calls from the sanatorium, the wife and says that ceased to feel my impact... (prior to that, and he already knew...)
I think that started the process has involved the lion's share of resources as operator. (as it should be - because the task was added, the potential is smeared).
The modules are run (you can briefly switch resources).
Look, when a violent phase will pass and lasts for about 2 days.
then the results are visible or not visible.
PS - just strange that nobody says about the fall of potential due to its redistribution... (or maybe it's so obvious...)
But I would still have done the same thing!
(already corrected... for example, the wife has extended the permit in sanatorium, and would like :) )
