BJ 2.1 / 2.2 / 2.4
Мишико
Re: BJ 2.1 / 2.2 reinforced "hard" version 2.0
Post by Мишико » Wed Dec 10, 2014 2:19
Thank you! Somehow did not think that it is possible for such a set to collect...
2.2 OS+ in a price that is not observed. He is? What if it is from two to take for symmetry?
Eugene, thanks for the tip. I understand what broadcasts are. Yet little idea.
Post by Михаил_ » Wed Dec 10, 2014 11:36
2.2 OS+ in price should be (as bracelets and cards)
Любознательная
Been thanked: 7 times
Post by Любознательная » Wed Dec 10, 2014 12:41
Михаил_ wrote:2.2 OS+ in price should be (as bracelets and cards)
Dear Michael I want to ask for Your advice, I have a physical bracelet 2.0 2.6 broadcast connected for almost six months, I'm going to buy a second hand БЖ2.2, and then completely ceased to feel a surge of energy, the question is: will this Supplement and will not be any imbalance if worn on one hand 2.0 (I understand that he is weaker than the BZ 2.2),and on the other BJ 2.2? although probably should not be,because it is not as strong products as BJ 2.6-2.x, panacea, with BJ 2.0-2.2 BJ shouldn't be imbalance, but I don't know. Physical or bracelet when connected 2.2 2.6 role will he play?
Been thanked: 182 times
Post by Андрей Кабанков » Wed Dec 10, 2014 12:57
Yes, in price and has always been. In the section of bracelets, the second line bracelet, the fourth card.
http://www.mindmachine.ru/price.htm
Post by Михаил_ » Wed Dec 10, 2014 13:00
a role play - 2.2 has its advantages (not to say that 2.6 is stronger or on the contrary - they are functionally different), and in broadcast 2.2 is not connected You (it is by default).
Yes, I wear the physical products itself, in addition to broadcast (it stacks), but about the flow of energy here is another look at a purely physical, third-party factors (cleaning of the body/ physical exercises, etc.), plus by itself, the rhythm of life and the purpose/fulfillment in it, in other words if there is a "ceiling" on energy, it is necessary to analyze all the amount.
Мишико
Post by Мишико » Wed Dec 10, 2014 13:18
All right, in General, price found, and in the pinned thread section its not.
Post by Андрей Кабанков » Wed Dec 10, 2014 13:22
http://www.mindmachine.ru/braslet/index.htm
The second and third bracelets, a fourth card.
Атом
Has thanked: 8 times
Post by Атом » Sat Dec 20, 2014 23:53
Владмосква wrote:If parallel (simultaneously) to charge 4 items, all 4 will be 2.2 with 25% power.
If consistently (alternately) to charge 4 items, the first 3 will be 1.0 and will be the last 2.2 with 100% power.
Please tell me what is the method of producing 1.0 efficiently and is there any difference in the bracelets, obtained by self-production (audio ducking) and consistent charge card transfer 2.2
Thank you.
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Sun Dec 21, 2014 18:56
via audio immersion
Post by Михаил_ » Sun Dec 21, 2014 21:46
subject to availability, to make their own panacea (just ) and 1.0 Lite (as simple) logical stop on the ground (the panacea) or the second... method of water charging working and effective but the most ancient of all :) card transfer leaves quite comparable track,but maybe less efficient (in the sense of after the transfer to the other object), with (in the case of maps) do not care which card was used...
Атом
Post by Атом » Sun Dec 21, 2014 23:40
Михаил_ wrote:, subject to availability, to make their own panacea (just )
It is a panacea Lite (AIT VUA ONYA) I understand correctly, or is there some kind of not found me a way?
If so, then everything on the shelves, thanks Michael!
Post by Михаил_ » Sun Dec 21, 2014 23:49
Well, the panacea can be a lots of ways Nanette, Yes including panacea Lite.
Post by bofara » Mon Dec 22, 2014 1:21
Атом wrote:Is a panacea Lite (AIT VUA ONYA) I understand correctly, or is there some kind of not found me a way?
http://openmagic.org/ph/showpost.php?p= ... tcount=901
p.s. do not forget about the possibility of 'mental application'..
Филипп М.
Post by Филипп М. » Tue Dec 23, 2014 1:40
Hello! Someone please give a link to a description БЖ2.OS 2+. Or where to read what "stoppage" and "fairing"? Curious... I'm sorry, but my quick search could not find.
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Tue Dec 23, 2014 6:30
Артур888
Has thanked: 7 times
Been thanked: 5 times
Post by Артур888 » Wed Jan 14, 2015 15:02
BJ got 2.2 today when I put just went for a feeling of freshness in the head. Before bought broadcast BJ 2.7 for 1.5 years somewhere :) After disabling wore 2.1 a week.
The appearance of the bracelet is nice.
Took another drive APK NO SMOKE. I think to try the module with dependencies together with the disks. But I feel BJ is not like what I smoke =)))
The question is this: I constantly read that to work out the channels preferably have 4 BJ , I have 3 bracelets 2.0, 2.1 and 2.2. If they are at the same time wear what is the effect ? Each channel is from a different version will be different to be worked, or the rest of the bracelets will be managed by the bracelet version 2.2 ?
Евгений-М
Post by Евгений-М » Wed Jan 14, 2015 16:20
Артур888 wrote:Think to try the module with dependencies together with the disks. But I feel BJ is not like what I smoke =)))
I have now painted all my desires to smoke that gives you Smoking and so on. (preferably several) and would put a stop on the Stabilizer. The most effective thing.
Now as for body physics, you just have to endure 7-10 days, and it's quite a bit. Agree? :)
And for the first 3 days buy cigar type Partagas (malicious) is sure in the aluminum case. Wanted to smoke - "suck" or "chew" a lit cigar, will popyhtet her without inhaling. A little nicotine will go into the saliva. To pant, and then will need a pencil case, put it back and close, it will fade itself. Repeat 2-3 times. Then only sniffing a cigar from a case the desire to smoke will disappear.
Don't smoke since 2000 for 15 years, the experience was great from childhood.
Post by Михаил_ » Wed Jan 14, 2015 20:49
well, you can wear 3 bracelet only swap them in a circle-that is, they are still a little different. The effect of the fact that they are different is also a kind of will (like less adaptation, more buildup when changing the place of the bracelet).
Артур888
Post by Артур888 » Fri Jan 16, 2015 13:56
And what could be a dream that had a dream school fears(injury) and in the same dream bracelet 2.2 on hand, but it faded black paint and it became this light brown color ?
Petr99
Post by Petr99 » Fri Jan 16, 2015 15:03
the study was in a dream and 2.2 too annoying
Мерлин
Post by Мерлин » Sat Jan 24, 2015 16:55
All kind time of day! Read, read, read forum threads, I decided to write here, as purchased BJ OS 2.2+ :)
To say that my "world picture" after reading moved, it will be too soft. Rather, she's gone)). I read the forum, until the answers he found, but because the info is not very structured, I can not understand, it is true, I learned it or not. So I want to share feelings and a bit to ask). Well, bought BJ 2.2 OS+ a little over a week ago. The first three days, no changes noticed. Then start terribly tend to sleep, slept for 12-14 hours. At first the dreams were normal, then went horror :) Moreover, the horror experienced, but in the dream I say to myself: "Holy shit the chatter from the band!"). About the food. Early vegans/raw foodists generally not taken seriously, I thought what strange people). Now he want to be a raw-foodists)) In General, loomed the following picture/plan of action for the near future.
1. Wear BJ 2.2 for a month and a half, watching.
2. Gradually turn on the raw food diet (or not smoothly? :) )
3. Connect the stream 2.5 and 2.6. (Using 2.5 get the "choice" of options for the development of the trend, with 2.6 drag any trend). And even if you fail to use them right away, the cocoon from this not become worse and in the end learn).
Well, it just so long as everyone can see, for a start. Tell me, if I'm on the right path? What to add, what to remove? Need your advice. Thank you :)
Любоовь
Been thanked: 3 times
Post by Любоовь » Thu Mar 12, 2015 12:50
DISTRIBUTE THE PROBES :wiz
It is very interesting to observe people who are not in the subject, when presented with samples
The girl is quite far from izoterike, magic, modern technology (the computer does not use!!!)
Gave the probe of the bracelet is 2.2. Understand. that forum will not read NICOWOULD - for this reason on your toes explained about the "magic pill" and by the harmonious desires (like if you're BAD at destiny, will not come true).
The first results was a good Wake - fits 2-3 nights and 8 stands as a cucumber - happy, even bounces, although it is said that feels like a tank - all on the drum. HARMONY - TO THE MASSES!!!!
Лоцман
Post by Лоцман » Tue Oct 27, 2015 23:18
Today a purely speculative discovery was made,just compared my mental on which the algorithm was embedded in 2.2 OS+ my current condition is the squeak of a mosquito in the rough and the deafening roar of the waterfall.
Post by Михаил_ » Wed Oct 28, 2015 11:45
Not very clear, frankly :)
Владмосква
Post by Владмосква » Sat Oct 31, 2015 2:16
Михаил_ wrote:is Not very clear, frankly :)
Conventionally, a mosquito = 1%, waterfall=100%. Ie this user has mastered the 1% of the projected 2.2 OS+ and he still needs to pass the remaining 99%, then at the end of his mental will be no mosquito to squeak and rumble falls, and deafening!!!!
