Michael, just to clarify, throw off please photo links are already processed bracelet common form, for example of the line 2.0 presented on the website.
Bracelets Life
- Дмитрий_999
Enough that a couple of hours until "recharge".....and then of course erased.Тоха wrote:)) marker I drew, but I think that will be erased. Should either Lucite or epoxidice, or something else. Wear). Join logic. Pricked) And kakieto unfamiliar sensation on his arm.
Michael is already somewhere I said..
Yeah, I gel pen...Erased but still lightly visible, what is written(bracelet of wood).
It will be a TAINTED bracelet older version and all.Метхуселах wrote:I like this question ......Воффка wrote:what if this upgrade to make a bracelet of the older versions?
between 3.0 and 2.x virtually nothing in common except the man himself
erased not erased...this is the call charging system. Put the night aside he choooooose charged. And so it is well to begin with is not the most powerful option, but things are slightly proplyene them.Тоха wrote:)) marker I drew, but I think that will be erased. Should either Lucite or epoxidice, or something else. Wear). Join logic. Pricked) And kakieto unfamiliar sensation on his arm.
will not change.Воффка wrote:Michael_
If not token to put the characters, and the burner on wood, this something will change?
What if you just present these characters as if they are written on the links and keep some time in your memory?
imagine, too, can try at your leisure. Depends on how developed predstavlyali.
1. where will I take this photo? charging system for older versions does not involve the application of letters, in the case of laser engraving applied to the 3 images one on another letter there too, but letters there 3х3х3х12+is 3ґ3ґ3 cell+3x3 = three-level matrix trenchline qualities of crossing planetary 9 and 12 external channels in the area of the object бж3.0Воффка wrote:Michael_
when a version is created it has been described that the condensed version of 9букв works as a button.
and just to clarify it will consider the filter
Judging by today's events probably really should read "strictly prohibited", unless of course a treat to yourself gently and with love.Смелый wrote:Michael, You wrote that a person not previously worked with the bangles, it is not recommended to do a light version of 3.0. It means, is STRICTLY PROHIBITED? Or could we try? For being. Because only on the days will receive the first of 2.0.
the Lite version is something (tangible impact) work harder the next, and something weaker. When fully charged spell is still a big block of information, which is not in alphabetic and graphic matrices, but to use it you need more reach (make a fortune in General, the usual).Логик wrote:pricked sarasa...
N - full version, easy charging, normal, will be available to the club and may in the future publicly, includes 4 stages of manufacture.
- this version is not supplied in the sale.
S - super-version will be available in commercial form, media + special charger technology, but based on the same four stages as in Normal version, only sold on special. install.
- this version is already in the office (first few pieces) and can be quickly attached to him.
price 20 000, material of Blackwood, aka Eben, he's black African wood (thanks for the idea Methuselah and contacts), this material is well suited for 3.0, size closer to standard bracelets, usually present in the office, the links are rectangular, color black. Photos later (can be ordered separately on these 2 links.x in addition to 2.5, for 2.5 we need a different wood, while maintaining regular prices).
It will be the cheapest of the paid versions 3.0, still restrictions on the quantity in which it can be made (limit of resource production).
currently there are multiple pieces.
S+ super versions with custom laser engraving and add a special composition, which includes the meteorite substance are extremely rare type. By the way don't know what I'll do when it runs out, as this type of is hard to find, only in personal collections.
Used in the manufacture of special methods of processing materials. In the production of this version will have 8 stages to reinforce it.
it is not the cheapest version.
This version broke the two
S+ = same as N version, blank same but different processing, multilayer laser engraving on two sides of links and additional activation procedure.
price 50000r
these can be pre-order. Will go to the office tomorrow or the day after, I will focus on the number of orders in manufacturing.
S++ = too, but harvesting more massive, larger, which in addition to the multilayer laser processing caused by the composition containing the rare meteor brotowasisto - chondrite C1 (or Сl1 it is the same), i.e. if in General, the chondrites are named due to the formation of chondrules - inhomogeneities due to heat in the fall, then in C1 of these chondrules actually no, he was not exposed to thermal attack in the fall (apparently these pieces are from the inner parts of meteorites, which did not have time to heat up), so it is not broken "native" signal energy.
this meteoric material has a very high value and extremely rare with a unique power characteristics.
photo of the workpiece will lay out later, photo finish will not fundamentally can publish (your head mind).
This version will cost 100 000 and requires special care in use.
will be back in stock in the next few days, you can place pre-orders, I'll focus on them.
Unable to REFUSE the sale (I'm not the right candidate for a mental hospital). Ie I will ask the office to say those who want to buy from me. And then believe your caution, I have long ceased. Also strongly recommend to take it to someone who has not worked for some time with 2.x, preferably from 2.6
SE+ This is the high tech version that contains the embedded source of energy is extremely high power. Until available, worked through the technological process of production, but it can not be purchased from, you first need to gain experience from working with previous.
This version will appear in about half to two to three months. Will only be sold to those who bought one of the preceding. It will be tough and strong additional energy flow. For many enough for it to hold out a few minutes to a long time to experience.
Since today is my trained colleague got almost the ultimate thrill of 3.0 S, and the events started to happen YESTERDAY when I outlined (specific bracelet) as intended for him and he started to work at a distance, on the basis of this experience I do not really recommend to play with expensive and powerful toys, even if there is such a possibility. OK?
I can count on consciousness? in short don't overload yourself.<
price 50000r
You can certainly imagine that you create a wave and are in the centre, but greater objectivity can be considered the center of the wave elsewhere. Then their own actions and the actions of others are part of more General processes and patterns. Perhaps this transition from the "geocentric" model to the "heliocentric" to see something new and more simple.Михаил_ wrote:Yes that's exactly what happened to 14-on-15 Oct I do not fully understand, there's a lot of it was for one night at the same time and apparently came out really strong surge, which resulted in including in strange positions some people do not keep it. Just imagine that You are creating a wave in the water, but they are in the midst of, and there are other items from them and starts to go back the wave that returns to the point of creation, weaker but opposite in phase.
Actually this splash and seeing. The phenomenon is amusing and harmless, but worthwhile observations. In particular it is a clear demonstration of how our "internal" motivation is actually external, in spite of our habit of considering everything in my head = his. To control it rather... difficult... especially with the habit.
But the question of what our motivation is external in nature, so this is no doubt. The only question is what we allow to inspire in yourself, taking the guide to action, and that reject nariams.
Okay, thank you. Because some really are not very carefully (using the brain as a simulator).Михаил_ wrote:Judging by today's events probably really should read "strictly prohibited", unless of course a treat to yourself gently and with love.Смелый wrote:Michael, You wrote that a person not previously worked with the bangles, it is not recommended to do a light version of 3.0. It means, is STRICTLY PROHIBITED? Or could we try? For being. Because only on the days will receive the first of 2.0.
Sure?Сергей12 wrote:Ready to order a S++
I think You are in a hurry.
The application to the office, me in a personal letter indicating what 1.0-2.0-2.x use and as long as took the Lite 3.0 (how does it feel how can you describe in your own words, etc.). While the sensation comes with a clear "no", between Pataskala Lite a week for a little bit and possibly themselves will change his mind. Don't change your mind - we will return to this issue with the given approach and sequence of steps. While I don't think it's a good idea, although today I am tired and afraid to be a little objective.
