I'M BUILDING A PYRAMID
Мденик
Re: I'm building a PYRAMID
Post by Мденик » Mon Apr 29, 2013 14:44
Вадим Перелыгин wrote:
Мденик wrote:Build a pyramid report.
Yes, good photo. :)
It would be good to consider the hypothesis that over the tops of real and virtual pyramids danger zone. :roll:
And what will happen if the top of the inverted pyramid in the water????? in the well. The water will be bad?
Вадим Перелыгин
Been thanked: 7 times
Post by Вадим Перелыгин » Mon Apr 29, 2013 16:22
It has a height of 1 m. the Water is much deeper. It's your roof. And the wall 2m. probably Unlikely You will constantly be in threat point.
Радха
Post by Радха » Sun May 05, 2013 21:30
Hello! I want to make a small pyramid for home use (to charge the water, for example). Tell me. please "teapot" in geometry - what should be the dimensions of the sides? How correctly to make? What material? The cardboard will fit?
Вадим Перелыгин
Post by Вадим Перелыгин » Mon May 06, 2013 14:05
Радха wrote:what should be the dimensions of the sides? How correctly to make? What material? The cardboard will fit?
Hello Radha. This whole topic about this and says! And You too lazy to read? :roll:
Викторович
Post by Викторович » Tue May 07, 2013 19:58
Вадим Перелыгин wrote:B3 – pyramid Perepelkinoy already using 2.75 day significantly reduced ORP, turning the anolyte to the catholyte and the PH changed from slightly acidic to slightly alkaline.
... And then the B3 vigorously shake and measure PH and ORP... :) .. should be interesting.
Вадим Перелыгин
Post by Вадим Перелыгин » Thu May 16, 2013 14:42
Викторович wrote: And then this B3 vigorously shake and measure PH and ORP.
Anolyte produced by electrolysis is rapidly changing the ORP in the negative, and when you shake again becomes plus. :roll:
Вадим Перелыгин
Post by Вадим Перелыгин » Sat May 18, 2013 9:08
Measured from the neighbors water from village wells and private wells 8,5 / -250 / 18. About like me.
Had experience in another place, at a distance of 1 km from the pyramid of Harmony.
Tap water 8,3 / -140 / 18. Poured in the jar and put it on the ground. Through 21time became 9,04 / -239 / 11.
Washed with soap the electrodes and wiped it with a napkin. Measured. BDN from -20 continuously changed within 20 minutes and stabilized at -220.
It turns out that the land changes the water from the tap to 9 / -220 / 11. :roll:
Викторович
Post by Викторович » Sat May 18, 2013 13:37
Вадим Перелыгин wrote:it Turns out that the land changes the water from the tap to 9 / -220 / 11. :roll:
Probably, a soil with a high content of silicon?
And yet - it would be interesting analogue of B1 and B3 from the previous series, to put indoors, away from the pyramid and the ground, but at a temperature similar to the one in the pyramid. Then it would be clear that gives the ground that the pyramid and just what the properties of water and the General background.
Вадим Перелыгин
Post by Вадим Перелыгин » Mon May 20, 2013 17:47
Викторович wrote:Probably a soil with a high content of silicon?
Yes, in the ground filled with sand.
Вадим Перелыгин wrote:had experience in another place, at a distance of 1 km from the pyramid of Harmony.
Tap water 8,3 / -140 / 18 . Poured in the jar and put it on the ground. Through 21time became 9,04 / -239 / 11
Repeated experience with the same water from the water away from the pyramid of Harmony, but the Bank left on the windowsill on 21time. Became 8,8 / -107 / 20
Then the earth shifts the ORP in the negative, and the plastic sill - in plus. :)
Викторович
Post by Викторович » Mon May 20, 2013 21:10
Вадим Перелыгин wrote:Then the earth shifts the ORP in the negative, and the plastic sill - in plus. :)
No, he does not slip. just a distillate, normally, in a plastic neutral packaging - a little minus. that way (-30) - (-50).
And the land you have a specific, with a silicon: water from her trace had accumulated, external action, and even a glass Bank encourages.. :) All this leads to the structuring, i.e. to the appearance of increased amount of quasi-stable molecular associates, in which the protons are relatively free... Hence the ORP and PH.
And now some real properties of the pyramid became clearer to her because -200 is committed? In principle, all these results can be made more accurate if packaging to take. for example, from cut plastic bottles. :)
And Shironosova Your results, which I took the liberty of trying to bring him down, clearly disturbed http://biorezonans.3bb.ru/viewtopic.php ... p=5#p59118 :? Because it does not fit with a coherent theory. Image
Оксана Костенко
Post by Оксана Костенко » Thu May 23, 2013 22:52
Hi everybody! Vadym Perelygin, read about Your experiences. (Just read, because the first time was registered in my name and can't remember what, I had more time to register under the name of his wife). And here's a question. To date, some conclusions about the pyramid that is above Your bed?
Вадим Перелыгин
Post by Вадим Перелыгин » Fri May 24, 2013 0:34
Викторович wrote:In principle, all these results can be made more accurate if packaging to take. for example, from cut plastic bottles.
Spring in the village - a hot time. Later I'll try to repeat the experiments with plastic containers. And I wonder what the results will be on the third level of the pyramid of harmony. :)
Оксана Костенко wrote:And here's a question. To date, some conclusions about the pyramid that is above Your bed?
Every morning drink with my wife in 250ml of water present on the shelf in the working area of the Cheops pyramid above the bed.
Problems with the gastrointestinal tract disappeared. Yes, and even forgot I was ill. Ugh, so as not to jinx it! :)
Of course it can, and NLP and hypnosis, but feel PROTECTED from the negative (mental, biological, energy, parasitic,...). :ay
Oh, and a razor lying there in the working area and serve for 15 months as new.
Оксана Костенко
Post by Оксана Костенко » Fri May 24, 2013 0:42
but tell me, You all night under the pyramid sleep? or what then it's definitely time?
I've been watching Your messages, went online, and decided to make a pyramid on Your method and parameters.
Оксана Костенко
Post by Оксана Костенко » Fri May 24, 2013 1:03
Vadim! Big promise are now looking for Your messages, the size of the pyramids, can't find... found the photo, found some dimensions, but I don't know whether they're to this pyramid.... Please try again. And another question, how far it hangs off the bed during Your sleep?
Оксана Костенко
Post by Оксана Костенко » Fri May 24, 2013 1:17
All dimensions found.... were not looking right, chose -"All the communication" and only after hours of searching found that they still need to uncover((((
Оксана Костенко
Post by Оксана Костенко » Fri May 24, 2013 1:24
By the way I have the same problems with the gastrointestinal tract((((
Вадим Перелыгин
Post by Вадим Перелыгин » Fri May 24, 2013 1:32
Вадим Перелыгин wrote:Here's my ex-pyramid of Cheops above the bed
viewtopic.php?p=71818#p71818
and its calculations in red above the bed, black - 2 times less – 3l jar with water
viewtopic.php?p=71143#p71143
Now it is a mirror with the bottom
viewtopic.php?p=97480#p97480
and a shelf in the work area
viewtopic.php?p=97767#p97767
Up all night. Usually hanging at a distance of 80cm above the bed. To be in the second direct(not inverted) virtual pyramid.
But when needed, is lowered directly on the problem area. Like for example today on the lower back. Had to shovel the road in the yard of one cutworms shovel 3 cubes of sand and gravel. :wink:
Оксана Костенко
Post by Оксана Костенко » Fri May 24, 2013 1:44
so... it seems all very clear! If interested will unsubscribe and brag... ( unless of course it will)))))
Рамильчик
Re:
Post by Рамильчик » Wed May 29, 2013 23:20
Вадим Перелыгин wrote:Frame built
Vadim want to build a pyramid according to your calculations on the sketch of the frame I think it is for others to the calculations above, it significantly enhances the positive power of the pyramid if you can help with the calculation I have in the garden not many places near circle structure ten meters away from the block wall of the garage to the fence of a neighbor and build a I would like. I have such dimensions height-2.5. the base of 3.92. edge-3,74. But if the height сделать3,5m . base,and a rib at this size what happens I'm not good at this. on one site I read that if the pyramid above it is significantly stronger. s. u. Ramil
Вадим Перелыгин
Post by Вадим Перелыгин » Thu May 30, 2013 0:55
viewtopic.php?p=48503#p48503
Here the sizes of my pyramid (detail).
Base=2,81 m Height H=5,24 m Rib=5,54 m
They don't work for You?
Рамильчик
Post by Рамильчик » Sat Jun 01, 2013 23:21
Vadim wanted to ask YOU to evaluate my situation more accurately drawing with the dimensions of my plot as I put the pyramid I have little space on the site to build the pyramid will I have to work, and generally if you can calculate the dimensions of the pyramid for my plot I'm on one site chose sizes if they fit me .Don't know from here how can I send my drawing to my e-mail ramil-avto@mail.ru Please answer me I will send you my drawing. My selected size height-2.5 m, the base - 3.92 m, the edge - 3.74 m. If the height to make 3.5 m, base-3.92 m. more precisely the height of that above to do so as I have a high garage with all the covers,still saw three coal pyramid. Help me what to do.
Вадим Перелыгин
Post by Вадим Перелыгин » Mon Jun 03, 2013 0:46
Рамильчик wrote:My selected size height-2.5 m, the base - 3.92 m, the edge - 3.74 m
It proportions of the pyramid of Cheops. This topic describes several different types of pyramids, the Golden section.
I have (in previous message) pyramid of harmony.
I can't recommend You anything. Because I don't know how we are affected by the pyramid - either positively or negatively. :roll:
I just describe MY experience and use them at your own risk. And I'm glad when someone shares his experience.
By the way, this topic describes sad experiences - death of one of the researchers of the pyramids.
I can't for You to read, to understand what suits You and, especially, to advise. All You have to do yourself (if there is interest and time) :?
Рамильчик
Post by Рамильчик » Mon Jun 03, 2013 21:30
Thanks for the reply. The interest is great since you have podotrasli health. I have another specificity of the work I do repairs and restorations of vintage cars bothers pancreatic,stomach,lower back about the pyramids in recent times say a lot about the beneficial properties,and in the net, too many to delve into for a very long time and in the calculations I'm a little weak in the Ufa that someone built or understood that I have not heard or do not know.At your own risk, I will build from these calculations that will not know I will try.
Вадим Перелыгин
Post by Вадим Перелыгин » Mon Jun 03, 2013 23:23
Tamilchyk
for treatment the best option - the pyramids-bed in the proportions of Cheops. I gave her account recently.
It is also good to read the technique of paramedicine Silva. Also there is a link to the book in this thread.
There are also links to psychotherapy and on water quality pyramid.
In General I recommend you carefully read the whole topic.
The street version of the pyramid of Cheops, lightweight design, can not withstand our snow - crushed.
I wish you success. az
Рамильчик
Post by Рамильчик » Tue Jun 04, 2013 9:25
Thank you today will deal with the understanding of the essence of this topic. s. u. Ramil.
