CD "healing: the magic river"
With regular listening to in the background alpha rhythm of the brain copes with these problems on its own (as intended by the Creator), then there is Healing.Anonymous wrote:Андрей Патрушев wrote:of Course, in the beginning there is a manifestation of internal problems and dominant.First. And then? What problemma to do?
In my practice I have noticed that if you listen to the drive after 12 at night, is the same as the designer - "can not sleep until morning, and then off". Try to listen to the disc at another time.Конструктор wrote:Conan, I fall at 2 a.m., it's my rhythm of life.
It helps to ask yourself: "do I Want to listen to this CD and at what time?", and then to listen to myself, my feelings, vibrations in body etc. the Answer will come. It is possible that at the moment this drive is not suitable.
By the way, I noticed that "Healing" occurs not only on a physical level. The environment, or in other words "my world" the same is starting to change! And aggravation happens not only in the form of a temperature and runny nose, but also to conflicts at work, the growth of tension around you, the real "black stripe". But perhaps that's just a coincidence.
People noticed like, share! [/b]
Conan
Yes, indeed this happens. This is not once mentioned in this forum, not only after the disk Restoration. Conflicts, dismissal, change of partner/s, etc. But in the long run, these changes are only for the better as practice. Leave unnecessary/hindering communication, is a reassessment of values, change perspectives on life and many more. Can posmotert branch "Disk Explorer", there is a lot of information on this subject.the environment, or in other words "my world" the same is starting to change! And aggravation happens not only in the form of a temperature and runny nose, but also to conflicts at work, the growth of tension around you, the real "black stripe".
"God helps him who tries..."ТауРус wrote:a Question to Andrey Patrushev. Listening to "Explorer" and "Healing" was close enough to the solution to your problem. But to go further, to overcome the barrier does not work, because the first trance experience happened very early. And I'm stuck - don't know what to do next.
"The road of 1,000 miles begins with a single step"
Start to do something on fizicheskom level to solve the problem (well, at least wash the dishes
Soap - does not help
. It may, of course, emotions get the upper hand. But the fact of the matter is that like lets go in the classroom Sedonas, for example. And then out of the blue seems to be the place POPs up again. When a person is relatively adult - it is possible though for something to hold on, but if 3хлетний child?
Can be more specific (in PM)?ТауРус wrote:Soap - does not help. It may, of course, emotions get the upper hand. But the fact of the matter is that like lets go in the classroom Sedonas, for example. And then out of the blue seems to be the place POPs up again. When a person is relatively adult - it is possible though for something to hold on, but if 3хлетний child?
сергей711
Hi Andrew.
I have a problem - fear, dreary state, the anxiety is constant. Sleep more-less normal. Psychiatrists in one voice say that I was mentally healthy, which is a consequence of stress, which need not score a soothing, and to work, to dig to the bottom of it by yourself or with a psychologist. Can help your disks, and what and how to listen to them?
Thank you.
Thank you.
Yes, you can work out a guide and a Healing alternating through the day, gradually abandoning sedative (classes with discs not earlier than three hours after receiving a sedative). There is a threshold effect - the first three weeks it seems that nothing is happening.сергей711 wrote:Hello Andrew.
Thank you.
сергей711
сергей711
Разрушитель мира
- Чаёк с сахаром
Yesterday before going to sleep the first time I listened to the CD "Healing." Overall - I liked it. There was a feeling that the body is asleep and I'm awake. There were different nice images, especially like the feeling that I sunlight pours. However! I didn't fall asleep, although I really wanted. Moreover, I then another half an hour could not sleep, his head continued to occur images.. All night I woke up and I had a nightmare about the fact that my son went swimming and disappeared from my sight. I'm in a dream a voice broke - so screaming his name. Hands searched the bottom and found none. And in the end it turned out that my son was asleep in the hands of some old woman who did not consider it necessary to warn me...
I woke up same as always broken in the morning, and the same mood depressed. But I will continue to listen to the Healing. Something happened, it means the process has begun
Question: is it possible in the morning immediately after waking up to listen to the Guide, and on the same day at night Healing? (another time to listen to the discs I have). Or it is better to alternate - one day in the morning the Conductor, next day before sleep, the Healing, etc?can work out a guide and a Healing alternating through the day
- Чаёк с сахаром
- Чаёк с сахаром
Andrei Patrushev
I had such difficulty: each morning after an evening of listening to the CD "Healing" I have a headache. Especially when you bend over - head is just pounding. Listened to the disc 9 times, a headache for the fourth morning in a row. Drink water (before and after the session, a glass of water, and during the day also drink water instead of tea and coffee). Sleep was hard, no feeling of weakness in the morning. But why the headache? It will soon pass?
The browser is not listening for 5 days, because after Healing this morning I want to sleep and not listen to anything else. At other times fails.is it possible in the morning immediately after waking up to listen to the Conductor
- Чаёк с сахаром
Andrei Patrushev
What else can a headache?
And here still wanted to ask. I became more scattered. Previously, I had always been collected, in any mood, remember all of the details. Now I can't stop "blunt"
Well, for example: I came in the clinic today with the kids. They wore Shoe covers, picked up his pair of Shoe covers and instead of dressing - put them in a bag and went to the office. Only in the office was surprised to find that Shoe I wore. This is of course a trifle, and the other person would not pay attention to it. But it wasn't like me! And so during the day I always forget something and confuse, and not even immediately realize that I again stepped! This effect of "Healing"? I was expecting another... Of positive change is the only noteworthy deep sleep and easier waking. I would like to after the course (21 days going to listen to) positive results were left and negative left, as to be scattered I do not like. And whether it is possible during the day to listen to some CD for concentration, but not through MM, but just from the computer through the normal speakers? And given the fact that a number of children running around... They then concentration to anything, I suppose
Or, say, listening to this CD on the concentration in the headphones, but not to lie down or sit, and walk around the apartment and do household chores? Or even not necessary to load yourself with relaxation and concentration at one day? Sorry for so many questions
Yesterday I measured the pressure before and after the session. To listen 119/66, pulse 61. After listening 109/66, pulse 61. My "working" pressure 110/70, so it turns out that after listening to the disc pressure becomes closer to the norm.please, HELL before and after school with the disk.
