Panacea or product "P"
Has thanked: 24 times
Been thanked: 142 times
Re: .Panacea or product "P"
Post by Маг.нет » Wed Jun 26, 2013 16:50
and why not? after all, it is a Panacea....... therefore, do not interfere, but after a time (not immediately, give the first "panaceas")
and programming and reprogramming and....... transfer of operator's powers, in General, all accompanying the Panacea.......
Sincerely, MAG.no 〠
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Wed Jun 26, 2013 17:30
Of the fun. Panzer parent's house from the satellite. Turned pan mode (in Yandex). And there my sister and niece in the shot. Well, came under shelling pakazany :)
арте:м
Been thanked: 8 times
Post by арте:м » Wed Jun 26, 2013 18:12
thank you for your answer and come from the desktop version of the generator (under Windows) to do. while it will duplicate the functions of the online version, but it will be devoid of restriction to 2MB on the file (I often even screenshots of this limit will not say without recompressing) :)
there will also be a function of projection screen as in my post above described and the opposite projection on top of other Windows. essentially transparent form which contains any image from a list of matrices or user with the possibility of free of scaling and regulation transparency. it is assumed specifically to work with online maps. not to write a plugin for each browser, which would output the desired matrix on top of the page while viewing it. for example, you can run the app while watching a private street in panorama mode, and place over the derived map a desired matrix in 10 minutes - move the contents of the viewer a step further and thus the entire street to cover details or (perhaps even preferable, given that the pictures in Yandex and Google have done a year ago) - to remove a phone or web Cam fresh video of their district, and then during playback it in the player - window on top of the matrix place and in this simple way "of operateit" all the videos at once... lots of variations for the application seen. save screen area in the file along with the image on top - will also be provided.
and finally, I would like to share seen with the amplification effect by multiplying the number of storage devices are "charged" images. for example, if (exaggerating) to photograph in the yard of a kitten, and cause, for example, the program "General stabilization" and then upload to Yandex.photo (where love apparently photos with cats) that a huge number of views will be accompanied by background you save the image in your browser cache. this allows the file to be replicated in many parts of the world. it looks like it significantly enhances the effect of prescribing information. I now keep all obtained through the generator files, not just the phone but also on all available computers.<
Post by Михаил_ » Wed Jun 26, 2013 21:07
Yes, including it affects.
The desktop version will be a requirement in the source code. Well, it is connected with the idea of a public safety code.
In addition to storage - you can make a superposition of many frames (where used footage from a video actually available a lot more than they used) and also influenced the process of matching in real time, even without operator intervention, what I wrote above. But in this primitive case, this effect is relatively small. If you take some special measures, it can be kolosalnoe.
We will talk about this later in another thread.
арте:м
Post by арте:м » Wed Jun 26, 2013 23:44
that's the way, regarding the "blending many frames" I wanted to mention the well-known free utility Virtualdub. right there comes with a couple of filters to add standard translucent logo to the video. thus it is possible all the same image already with the video mixing. moreover begs the reverse operation when the video posted here, for example, "2.1" above your target photo place with high transparency. this is of course not entirely correct. more correctly (IMHO) in the multi-track editing program to stretch the image to fill the timing "of the artifact video" and then the movie is over with the desired degree of transparency to start. but, unfortunately, I am not aware of such programs in the freeware category. somewhere deposited in the memory, there are free and full online video editors, but the bookmark is not found. maybe someone met. in any case, you will easily find "free software for recording screen", using which you can record your session travels in Google Earth and then on this movie as a whole a picture to attach. it's like the idea.
Post by Михаил_ » Thu Jun 27, 2013 0:19
1. all the videos of my production is simple digitally
from which you can rebuild a new generator will be different graphics.... but frame-by-frame from
2. in some cases the photo can be applied directly digital number and not a different image, i.e. the data from the file
directly can be summed up with the pixels the photo or video
3. it is better to write your stacker being integrated, given 1 and 2, and ideally, fast and multithreaded, that could eat ndtsat of cores on modern processors.
4. the idea is to use the power of the GPU on modern graphics cards - is not empty. Ie I want to say that if you drive the generator for yourself, you can include the option "superimposed on a circle without stopping".
5. for video recording with gogoplata good to use any version of Camtasia (Camtasia Studio 7 for example), there is for example on the torrents.org a pill. There is allocated area of the screen, the sound source, there is a pause on the recording and postprocessing plus save in different formats.
арте:м
Post by арте:м » Thu Jun 27, 2013 4:32
Michael_will be asked to pay a certain amount of time to clarify itself mathematics summation.
I then will direct efforts in designing "graphics engine" in 2 versions:
for a Canvas that uses a CPU and operates a 2-dimensional matrix of pixels with the possibility of addition/multiplication with another matrix or vector, as well as the standard set of bitwise logical operations;
for OpenGL which is GPU load mostly.
the question is the interpretation of the data. if I correctly understood - a problem more CPU resources to capture for the operation of summation of two digital rows possible units and with higher system priority. and the most important is the moment of "docking". but in this case it's more of a pure file operations? that is, until the viewport can not bring because the operation information has already taken place at the level of RAM or disk buffer or memory on the graphics adapter and the display device is only its fragment (which is dictated by the rate of frames per second), which is by nature a copy of the graphics buffer stands for. may be if the demonstration results to the operator rather secondary function - just focus on the memory management? well, to the resulting array housed in a single dedicated unit and was not physically refragmentation around the address space? in this scenario, it turns out a purely background application, which in a loop reads the stream from the file data and image file. then reserved a "whole" block of memory where they in some way are summarized. can be in the mode when every 3 bits in the data file are interpreted as containing information about the pixel color in RGB and the 4th transparency information to an alpha channel? here of course my imagination is not the place you want the exact formula. the resulting fragment is then flushed to disk (where fragmentation probably also have a separate fight), and going to the next fragment. if the end of file with the image receiver, then returned to the beginning which will lead to successive addition the whole data file with multiple copies of the file custom image. Then the final file on the disk is erased and it all starts again.
in the case of using the graphics library, the sum of the two files can be represented as texture mapping, but then you will have them pre-formatted lead. or data file, you can still somehow be interpreted as a map light or as a list of coordinates of vertices of the polyhedron or the easiest way as the fragment color, which is one of the 16 standard methods buffer with the color of the fragment of another part of the image, but then the visualization in question - as it's an abstract operation is not tied not to any object in the context. It is certainly possible that it was broadcast on a face of the cube, which will be randomly alternate the colors, but this is unlikely to be spectacular or beautiful look. Interpretation and subsequent submission to do very much. So I will not continue to paint the rest of the details of the wanderings and wait as the perhaps more precise instructions. And it so happened the digression into computer science of some sort.
Perhaps it should not erase or move to the branch where roll call programmers to spend going to a live project to fly steel :)<
Post by Михаил_ » Thu Jun 27, 2013 4:52
in principle, all right, and how to display the result (or how to interpret the input data stream) is not important, i.e. changing interpretations (tried many options) is not fundamental (i.e. how to turn in a schedule). I think it shows on the commercials time.
Yes, I think (based on real experiments) that the important Yes, the process itself, the importance of defragmentation - I'm not sure....
but not checked.
true, I worked with the special data streams - i.e., with the two sides both streams consisted of spitalnik data (in the case of processing a single stream of photos or video - they are not special).
the topic tomorrow will lead, and then maybe here will be demolished.
Post by Михаил_ » Thu Jun 27, 2013 14:04
in General, I'm afraid this is going to sound strange, but on a good not need to do anything special. programs to increase sales, just a panacea, a program that involved those who need it the most (your goods). Ie themselves to increase sales is not inherently harmonious if her forehead to drive and maybe there's a conflict with the basic principles of the panacea, and in General BJ.
But of course there are those who thing that sells really need. And well, if they will visit the site and they'll like it, and the decision they will take themselves :) it is a harmonious approach.
Advertising is a bad idea in this world :) well, it's such a short summary....
ie Afanasiev pictures on the website it is possible to effect a more direct interaction between seller and buyers, more intuitive approach of customers to the products.
Well, if the item is really necessary and useful, it will lead to increased sales.
It is also important not to dwell on the result.
АлексейХ
Post by АлексейХ » Thu Jun 27, 2013 14:16
I want to clarify. I put the panacea in the photo through the generator, after applying the open photos in the browser on the created link in the generator and then concentrating on the photo saying the affirmation program for superimposed panacea, and further photos are stored on the computer do I do?
Or need affirmation to overlay on a photo to blend the miracle cure? As hereinbefore said Michael, the overlay process is like a small avalanche (strong process). As better or does not matter for efficiency?
Ярый
Post by Ярый » Thu Jun 27, 2013 14:25
Michael_thank! Make soft, harmonious option! :ay
Post by Михаил_ » Thu Jun 27, 2013 14:37
АлексейХ wrote:I Want to clarify. I put the panacea in the photo through the generator, after applying the open photos in the browser on the created link in the generator and then concentrating on the photo saying the affirmation program for superimposed panacea, and further photos are stored on the computer do I do?
don't know what You call affirmations, but it certainly wasn't here :)
АлексейХ
Post by АлексейХ » Thu Jun 27, 2013 23:16
Михаил_ wrote:don't know what You call affirmations, but it certainly wasn't here :)
Michael, well, You probably understand the question. Well I don't well-chosen, let it be "program" or "command", i.e. in addition to blend panacea on the photo I give the program to execute, with regards to this photo. So when you need to give mental program before applying or after? now I hope I managed to convey the sense of my question :)
Post by Михаил_ » Fri Jun 28, 2013 5:14
well programmed it is a panacea or a photo, do you think? because of this, and the answer should be. As a panacea for bad programming phrases, it is much better to tasks and images (advanced)
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Fri Jun 28, 2013 7:04
This morning went to the river and the road, one bird on a wire I tried something "to say," at first I did not pay attention, greeted her mentally and went on, she tried to catch up with me. When I went back she again started me something "to say," if I started to turn away and go, she flew in front of me, attracting my attention, even on the asphalt in front of me sat down, when we stopped again flew to the wire and continued something "to say," I popytalsya to assume what she needs, but she didn't react - just sat around and "chirp". Unfortunately the bird's language you do not understand. When she spoke, looked me in the eye, and above, of course, if it was a reference, maybe I sang a song and wanted to appreciate.
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Fri Jun 28, 2013 10:56
арте:м wrote:...to take pictures in the courtyard of a kitten, and cause, for example, the program "General stabilization" and then upload to Yandex.photo (where love apparently photos with cats) that a huge number of views...
Cats, of course, but how could using a huge number of hits another snake Udd-er , sorry, revive :) - the indispensable "almost each member of the family."
But it needs the world to stay - won "Hydra" which http://www.hackwmc.info/images/10563940 ... 2_41lo.jpg Directly under the list of "heads". :)
By the way, an interesting question. It was said that P is a monster at devouring orphan energy. And in some places image ray according to ljuminoforom still struggling, which is a process of energovydeleniya, even creating a "three-pointers-EN" improve. Maybe even a "tuft of wool" with this "sheep" to you? :) It is unclear , since the emblem on the screen several virtual and not directly processed.
And yet - the box "magnetized"?
Petr99
Post by Petr99 » Fri Jun 28, 2013 11:11
Petr99 wrote:this morning went to the river and the road, one bird on a wire I tried something to "say",
maybe it makes sense to tie it, after 3 hours in the garden not looking for son (played outside), the result - the cut of his temple and eyebrow, sewed, is now sitting at home with mom.
АКВО
Post by АКВО » Fri Jun 28, 2013 15:08
Loading photos from the past, we're changing now? i.e. shifted to another branch, where all the world's japanesein?
Post by Маг.нет » Fri Jun 28, 2013 15:25
well, if the offset is not just in fantasies....... a photo by itself will not offset, in the time of "application" it is here and now, but can become a guiding vector to a certain point "the circumstances of space-time." maybe, but not "default".
Sincerely, MAG.no 〠
АКВО
Post by АКВО » Fri Jun 28, 2013 21:11
MAG.no, let's say I separater childhood home (an old photo)... then, when I was a kid, I was already charged, although we don't know anything about panacea... it's a bit changes my reality in which I grew up in a normal house... something like that)
And if you take photos of the planet and on the same principle... it turns out that I already grew up in a very different world... or both?
Post by Маг.нет » Fri Jun 28, 2013 22:45
Real even a small change in the past "as it is" changing the future (about the prospects for the current branch, it is the future, since the present has significantly more inertia, of course, if not considered from 3.0) - causal relationships, but to provide such correction (even with tools) you need to get to this point in time, not only in fantasy, i.e. "it was so" (to the World) and "I think it was so" (event person) are not the same thing as objective and subjective reality but maybe....... with these abilities, but only the old photos is not enough, although the past through the subjective "look" and to reach objective (of the World) and there to hold the correction, again, for this you need to have the appropriate skills.
Sincerely, MAG.no 〠
Алекс С
Has thanked: 2 times
Been thanked: 7 times
Post by Алекс С » Sat Jun 29, 2013 9:10
Perska remember the old joke - "to have a happy childhood it's never too late". Some Nlpshnye and, and not only NLP, but also other psychological techniques work with past problems, eliminating them and changing the future by dropping a load of problems with the patient.
Once 7-10 years ago read an article in which the author very gently hinted, there seems to be a psychological study of the past (modeling traumatic situations in a new positive way) not only psychological, but also directly affect your current reality.
Well, if you change the past just by applying psychological techniques, the panacea it will be more harmonious and more efficient. IMHO, of course.
Post by Маг.нет » Sat Jun 29, 2013 9:30
So the fact is that such Techniques can only change the subjective past, or rather the attitude that practically "does" not affect the World, not change it. And changes often (not always) possible to tell time (experience) - activating the previous anchor picture of the past (for example encountering eyewitnesses "altered past") this Technique can begin to fail and the end result will largely depend on the strength of Consciousness (whose consciousness is stronger, the picture of peace and "real") and its configuration. Ie actually this is a very good Technique (recapitulation) at the change their attitude the events of the past, but alas doesn't change the past (well, if You are not conscious of waterbending - the ability to adjust the World at the point of the last changing).
Sincerely, MAG.no 〠
Post by bofara » Sun Jun 30, 2013 19:34
For programmers: in addition to discussing Google Earth so it would be great if there is a possibility to include and what digitalisering human model as an option for the overlay on top of these images - about this 'chelovekoraz' at the beginning of the overlay process receives from the operator 'name, gender, what the attributes of the date and place of birth, name..', it creates a link to a specific person /about myself/ and then work with the overlay. It would be very nice if there vozmozhnoti to allocate system - about blood, or the brain hemisphere, bones, skin, teeth /popular trend from some/ etc.. Thanks.
арте:м wrote:move the contents of the viewer a step further and thus the entire street to cover the details
This reminds the technique of "telescope" /Michael gave Pro 3.0 here/..
Михаил_ wrote:OK.... let's try to learn.
Please forgive me in advance for some of the original practices, but based on 3.0 otherwise not as effective
1. try to feel the difference in your state of consciousness at 3.0 and without it.
2. try to understand this difference as "side view" of the processes.
3. try to imagine that You look at everything, including himself from somewhere far away, and your real position is not concerned with what You see.
4. seeing the picture from the switch to the aspect that it has all the ingredients of the big world, actually it is the world, including the one on which you should concentrate (at your option 12ба)
5. bring the right aspect as increasing the object in the telescope and work with it.
here
Михаил_ wrote:technique of manipulating the visibility of the cloud cell and the technique of regulating its own "tweak" or of alignment with the world in a thread about the modulator, for validating the Merkaba.
The point is, TO not losing the saturation may withdraw from interaction with us and the world,staying as it is, but not here (not in this phase). Can you imagine it as a kind of regulator of manifestation and some time with him to practice to turn it from the "fully manifested" to "never seen".
2. In fact this setting of manifestation is associated with the setting in place and time "here and now" and for the parallel branches of reality, it will be another option. Actually for our branches and at least another place - is different.
Ie then you can begin to play with the same parameter, call it conditionally "phase shift" signal its cocoon relatively of this world," but for himself and not for KO. First, just on the subject of "I manifest and I'm not shown". You should track both "presses" the world is manifested and not manifested person.
It's funny, but most of the population of the planet is only partially "there" because her attention is much taken from reality all sorts of virtualhostname.
3. after playing with changing their manifestation in the world, you can learn how to optimize it for the tasks (although generally it is usually better to keep it on a high and this, incidentally, makes 2.6 and the "mirror of ISIS".
4. Then you can try to shift yourself to another place (e.g. to another city, at least for a few hundred km) is not on the "I submit, I see", i.e. not etheric-astral output, namely the parameter phase. In another point of the planet at the same time, this is different, since it depends on a superposition of internal energies (vnutriplitnykh) and external (let say the zodiacal and solar), and both of them are in their cycles and these cycles depends on the place too. Ie if you shift your attention to another place and prove himself there that is tuned to the phase parameter of this place, the effect will be completely different from the one just astral or partially astral projection there. And realism and consequences in the physical location of the body after the return of attention.
a little play around with this, you can find these techniques useful application :) but of course the experience you first need to dial.
I read BM and like a Druid he did on openmedia/ about a device with magnets, which simulates various places on the planet, and thus easier to recall his past incarnations. Even here it was written that changing residence can be healed from the troubles in the cocoon. Is it possible to generate via a phase shift TO using some kind of software /software/ a combination of Google Earth+a'chelovekoraz', to achieve emulation of this effect?<
Алекс С
Post by Алекс С » Tue Jul 02, 2013 0:35
Маг.нет wrote:ie actually this is a very good Technique (recapitulation) at the change their attitude the events of the past, but alas doesn't change the past (well, if You are not conscious of waterbending - the ability to adjust the World at the point of the last changing).
The fact of the anecdotal situation that some Nlper noticed that the past changes. Ie, the future becomes so, if there was a traumatic event. There was an article appears in the journal of NLP, and maybe in another psychological journal (NLP because there is cursing), where in the first half described the risk of contact consultant<--->the patient for the psychologist consultant and the second was viewed as an incredible theory of the influence of the patient on the past, i.e. as in the movie "back to the future".
As a magician to be... so we are all mages, just don't know it :)
But in any case, for what has bought, for and sell. I myself did not practice NLP professionally, but I believe that any technique that ISS, at least partially, and that means miracles are possible :)
