BJ 2.1 / 2.2 / 2.4
димыч
Has thanked: 7 times
Been thanked: 16 times
Re: BJ 2.1 / 2.2 reinforced "hard" version 2.0
Post by димыч » Fri Jul 04, 2014 21:23
have you tried at least BJ 1.0? or just found out and bought it?
many try unsuccessfully to do what you have a easy work:)
at least try mentally to start the module "power silver thread"
or
"28 of lives" - the analogue of "9 lives", a stronger version, recovers
energizes and silver, builds around it a dense structure as armor, including the additional channels.
Пилигримм
Post by Пилигримм » Fri Jul 04, 2014 22:51
ДавайЛама wrote:a Month ago I purchased 4 bracelet os 2.2+. Wear on the arms and legs. Feel nothing, nothing happens. People wrote that 2 of the bracelets specifically sausage. And I 4 not valid. What can be the reason? Is it worth it to purchase a more powerful version or can upgrade to 3.0 N?
Don't feel anything doesn't mean nothing is happening.
Sausage,not sausage depends on the sensation,Yes it is not an end in itself.Consider a side effect.
You purchased 4 cool tool and wipe them light with a three-pointer simply barbaric :) If you want 3.0 N,buy пару2.2 and make of them,but the best beginning of a Cure, IMHO.
Read the forum,everything is there :)
The out-of-body, I'm kind of jealous :)
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Mon Jul 07, 2014 18:50
Dalailama you Have little energy free and is all for the restoration of the body and organs( I am writing this because I know the situation). Wait a bit , when restored , then going to say that you don't feel the energy)))
Шерин
Post by Шерин » Sat Jul 26, 2014 23:35
Greetings to all!Today I received your BJ 2.2,all services worked quickly.Thank you!Once you've decided and placed an order,went to sleep-I feel that there is stroenie,stir thin phone Then went embedding in the network BJ is reading the forum -understood.Now it's been hours now,while there are pleasant sensations,mainly in the area of Anahata.At work had a bit of *hitting*,even before receiving BJ.On the hand looks quite presentable.
Галатея
Post by Галатея » Sun Oct 12, 2014 19:23
Hello. Not found in themes how to use cards for the transfer. I write here as interested in the map transfer 2.2. Please describe how to use or give a link. Thank you in advance!!!
Бисо
Has thanked: 49 times
Been thanked: 38 times
Post by Бисо » Sun Oct 12, 2014 20:46
Галатея wrote:Hello. Not found in themes how to use cards for the transfer. I write here as interested in the map transfer 2.2. Please describe how to use or give a link. Thank you in advance!!!
Put the item you want to charge on the card. I'm not sure how much you need to keep the subject on the card. Can be an hour or more.
Charged object (not necessarily the bracelet, for example clothing) catches her.
When you change the subject to "disabled" remains charging БЖ1.0 (TO remain with the map).
Владмосква
Been thanked: 7 times
Post by Владмосква » Mon Oct 13, 2014 8:46
how to use cards transfer
the subject should lie on the map for 1-2 days. More than 48 hours makes no sense.
After the map you can remove the paper and the coating matrix
TSL
EUR
OTS
but not necessarily enough mental command to restrict a map to charge other objects such as a table or a book.
If the card lies and 2 courses at the same time, they will have half the power each.
Галатея
Post by Галатея » Mon Oct 13, 2014 16:34
Please tell me, and to charge the subject again after some time it is necessary? Or charged once in 24 hours and all.
Бисо
Post by Бисо » Mon Oct 13, 2014 16:46
Hello Vladmoskva,
Someone wrote or discussed at the meetings with Michael, if some object happens to be on the map transfer, it will not charge. This happens because there is a conscious desire, intention, or command, and the transfer process will not start.
With this in mind, I missed to mention this detail.
Thank you for the clarification. Now everything is clear.
Бисо
Post by Бисо » Mon Oct 13, 2014 16:50
Галатея wrote:please Tell me, and to charge the subject again after some time it is necessary? Or charged once in 24 hours and all.
That's all.
If you charge the item again, it erases the previous attunement with the operator. Bracelet some time it will work "as new" and can it you to rock.
Владмосква
Post by Владмосква » Mon Oct 13, 2014 17:39
products Michael do not discharged. And no matter what serial or card transfer. And in the word "charge" is chosen to simplify more complicated is the message properties, the announcement to the world that is the subject of 2.2 for example.
Галатея
Post by Галатея » Mon Oct 13, 2014 18:03
It turns out that with a single card transfer, I can sequentially charge two subjects, all right?
Бисо
Post by Бисо » Mon Oct 13, 2014 18:33
Галатея wrote:it Turns out that with a single card transfer, I can sequentially charge two subjects, all right?
Yes, you can consistently charge a variety of items, but only the last item will be 2.2.
All previous will be БЖ1.0.
Владмосква
Post by Владмосква » Tue Oct 14, 2014 8:49
If parallel (simultaneously) to charge 4 items, all 4 will be 2.2 with 25% power.
If consistently (alternately) to charge 4 items, the first 3 will be 1.0 and will be the last 2.2 with 100% power.
Галатея
Post by Галатея » Wed Oct 15, 2014 20:34
Tell me, power is very different of the original product from the products we receive through the cards transfer?
Владмосква
Post by Владмосква » Wed Oct 15, 2014 21:58
Power are almost identical. Products from cards work a bit differently, but the difference is not in terms of power. Original products through ebony loved by many. Map transfer better to use for charging belts, clothes, shoes, watches and jewelry are not believers in the technology of the BZ family.
And here is a useful quote of Michael:
the Blank-carrier in the case of a map migration is somewhat less criticise material. Since the card does not charge, and catches himself for the object. But it's also heavier and larger.
Галатея
Post by Галатея » Thu Oct 16, 2014 0:42
And what material is best to choose: wood or semiprecious stone?
Post by Михаил_ » Thu Oct 16, 2014 5:02
it does not matter
Мишико
Post by Мишико » Tue Dec 09, 2014 0:09
Summer has manufactured and loaded bracelets 1.0 (for hands and a special little wider foot). Reviled them for about a month without removing. No the described effects were not observed except for one time. Had to go from the country to the city and must be appropriate (of type out). Took off all the bracelets, I drove for a couple of hours, returned to the cottage, put all 4 of the bracelet and ofigevayu: almost immediately floated as the alcohol (but not drink for more than 12 years). In 20 minutes the status was normalized.
A couple of months ago I bought a BJ 2.2. Like anything especial has not noticed, day by day passed like usual. Last week mom felt a strong weakness, nausea, vomiting (apparently poisoned fish - all the facts indicate precisely that). Without hesitation I gave her my bracelet. No instructions are given, just said to wear on his left hand. After a couple of hours to visit "sick" in her room. She is happy, watching the telly and all glowing with happiness. Its first sentence was: "He's some sort of magic?" :)
Their Pets keep away from this kind of information, many of you are probably faced with all sorts of close relationship... I will not Explain, I understand.
After the incident, looked at your life and realized that after purchasing the bracelet it is still the same:
1. Sleep. Sleep was less. Stay up late (on average about 2 hours a night) get up early: 7-8 in the morning. While Sleep!!!. Although I could sleep 10-12 hours and felt broken, heavy.
2. Food. There was less deteriorated selectivity, strange sensations even BEFORE you try. Already know in advance I need it or not. Drink only coffee and water. Coffee: 2-3 cups in the morning (not instant, but a normal, grains) but I feel that soon he will refuse unnecessary. Picked up in unpleasant coffee notes. From the water get a special thrill. Though we are in the classroom of physics and chemistry and hollowed what is a liquid without color, taste and smell, but it turns out she's got taste! I always keep next to two bottles with printed matrices P and 1.0 L. To a particular follow on the basis of their spontaneous desires. "P" is often tastier.
3. Vigor and ease! Everything around became like a little easier and a little easier. Monotonous things do not tire if you don't want to do something, this nehochuha either easily overcome, or gently replaced by something right now, in this moment.
4. Work. Radically changed the scope of activities. Suddenly found himself a disciple of the four (!!!) different new courses. 've never had that need or desire. Learn something new, implement it in the new daily and now earn. A lot was wondering where to evolve, etc. are Changing habits that are considered a full part of himself. Off as unnecessary.
5. People. Circle cool corrected in favor of the interesting, bright, new, exciting, fresh for me.
6. "Luck". Luck is definitely! If problems arise acute, smooth out to be surprisingly easy. Attitude to various deadlock situations, too, has changed. "Random" way, be the right people, solutions, situations, phrases, books, etc.
7. Money. Not to say that they were added somehow. Come and go (sometimes it even seems that it takes more time) but the thread became something else. I can't accurately describe... to Earn "kicks" or something. Do something interesting, the clubbing at all, enjoying the process, and it still brings income.
That's never going to write so many things, and look how it flooded. Sorry so many, but wanted to share...
BJ pushes and guides? :wink:<
Post by Михаил_ » Tue Dec 09, 2014 1:42
Thanks for the feedback :) I also sometimes need a pinky and the reviews they are quite - true :) That is when you realize that can help many, there are forces even in difficult moments to shove the tank forward. And "heavy" they really are almost always due to the physical lack of time and many other resources.
On the subject of explanations of family - my friend and partner came up with the technique. He says something about a micro-antenna and other stuff, and then demonstrates a simple but effective "trick", almost the same as I did based on the tonic of EPS when doing tests of AMB, but slightly different. Test from kinesiology (a recognized medical discipline/direction) - indicates the muscle strength, elongated in the direction of the hand to resist third-party lowering the hand effects (the subject is holding the hand horizontally, he pressed on it lightly from time to time). test approx. then the same thing, but in the other hand the test cell in a call/conversation (UM background per person/ cocoon distorted) - the hand falls once, the light touch, the body was out of control, muscle tone has changed. Third test with BJ on the hand or card 2.2+fairing - hand is "stronger" than before, despite the phone. 4th test, as they say in advertising, with a card of the "Other manufacturer" (I mean some well-known names like Nate...... distributed some great MLM structures, I'm not talking about products here), and the 4th test shows the result is worse than without anything but the phone (t/e/ completes the phone in its pathogenic effects). The 4th test, which took a lot of that as a replacement ( and also changed the order of the tests) at the same time replace the test for a placebo. Because many of the people on the contrary usually think "it's working" or even "this and the more work."
Because it is a simple physical test, many impressed and change their minds - in all things not explained by science and Vice versa :)
As recently revealed, yet clearly running a test on live blood, but there is best done BJ + water after a BJ.
I promised videos (video) with these tests the blood of patients before and after. I have unfortunately no time to do it personally, but later I'll get these videos.
However, I do not call all around to agitate :) many of my close relatives and friends have no idea what I'm doing :)<
Аиша
Has thanked: 56 times
Been thanked: 14 times
Post by Аиша » Tue Dec 09, 2014 2:28
Михаил_ wrote:that is when you realize that can help many, there are forces even in difficult moments to shove the tank forward.
Thanks for the "tank"! :) Just today a friend heartily thanked for the fact that I stumbled upon this website. This is the heart praise you, Michael! :o
For the year ,probably did more than in my whole previous life))) along with your products. And working on myself I'm alone and upset at all my friends and relatives. :wiz Well, and to know them all is not necessary. :wink:
When home overcomes any sickness, I ask my "magic cap"( painted with matrix 1.0), of course, later, recovering they deny that they have any there my fintifluhka helped...anyway, the main thing that the favor was! 8)
The cat loved the card transfer 2.1( caught her doing this 3 times).In any did not want to leave, but the collar is 1.0 to wear refused.
Аиша
Post by Аиша » Tue Dec 09, 2014 2:40
Михаил_ wrote:As recently revealed, yet clearly running a test on live blood, but there is best done BJ + water after a BJ.
It would be very interesting to see.
Мишико
Post by Мишико » Wed Dec 10, 2014 1:29
Sorry for offtopic, but don't know where to write its history. Plan to expand your Arsenal of BJ, but can not determine the choice. Michael in PM does not respond like, read about it in one of the branches.
Looking towards 2.6 or three pieces 2.2 to bring their number up to four. Working primarily with the restoration of health is necessary, but some situations push would not hurt. It is very necessary.
Still interested in KV IIM-1
Who can help to determine the choice, suggest the right solution? Who can I consult about the upcoming purchase?
Been thanked: 10 times
Post by Мастер 108 » Wed Dec 10, 2014 2:05
For your purpose you can use: 2.2(for symmetry :) ) + OS 2.2+(mainly recovery) + 2.6 (as some situation does not prevent to push :wink: ) Total you will have 4 BJ - well, the full symmetry :D
Евгений-М
Post by Евгений-М » Wed Dec 10, 2014 2:12
Мишико wrote:to Work mainly with the restoration of health is necessary, but some situations push would not hurt. It is very necessary.
But this is not necessarily BJ. :)
Watch live video and the UK as a physical product. Moreover, SK3 discount Christmas large.
And 2.2 is automatic in the broadcast, keep that in mind. Stream and more powerful and "greener".
