Advice from Andrei Patrushev
Three days is the maximum.лиза wrote:Andrew, I read somewhere on the forum,and now can not findYou have to ask the question. Listen to the Healing and had to take a break in three days, so keep happened only in the fourth. I re-counting or three days to miss? How many consecutive days do you miss during the course???
Владимиров
Andrew, please tell me:
1. If the study You recommend to start with a disk of "Star wanderer" what is needed "Ultramag".
2. 2nd track "Star wanderer" to listen to during or before the study.
3. What could be the intensity of the training? On the drive specified is not recommended to do more than 45 minutes. It's an hour, a day, a week or what?
Thanks in advance for your answer.
1. A training track Star Wanderer enters Ultramesh. Star traveler - for children with problems of memory and attention add and ADHD, and Ultramesh for students.Владимиров wrote:Andrew, please tell me:
2. It does not matter. Better to listen to in the morning.
3. A day.
АЛЕКСАНДРРРР
You can:Пророк wrote:is it Possible to walk the course different drives simultaneously, for example in the morning, the endorphins, evening healing?
FAQ http://www.mindmachine.ru/viewtopic.php?t=2181
АЛЕКСАНДРРРР
KU KU
ANDREW
AND TO IMPOSE ON ANY MUSIC YOU AND ON ALL YOUR DRIVES?????I BRIEFLY RECORDED A BARELY AUDIBLE VOICE AT A FREQUENCY OF 4 HZ WITH BINAURAL BEAT:)))))))))
BEFORE ME THERE ARE 2 QUESTIONS...WHAT SHOULD BE THE VOICE WHEN RECORDING(QUIET OR INSPIRED BY)...."I HAVE CONFIDENCE IN MYSELF"MY AFFIRMATION:)...AND MUSIC MUSIC CAN BE GENERALLY ANY??)))..IF YOUR
FOR EXAMPLE CD" - HYPNOSIS AND HYPNOSIS" IS ALREADY THERE FOR YOUR VOICE...SO IF I CHARGE BACK MY VOICE NOT HURT?????
AND CAN I ASK YOU JUST A LOT OF POSITIVE AFFIRMATIONS TO SAY...OR NEED ONE FORGENIE REPEATED
Is not hurt. Did not understand only - what's the frequency 4Гц?АЛЕКСАНДРРРР wrote:KU KUANDREW
BEFORE ME THERE ARE 2 QUESTIONS...WHAT SHOULD BE THE VOICE WHEN RECORDING(QUIET OR INSPIRED BY)...."I HAVE CONFIDENCE IN MYSELF"MY AFFIRMATION:)...AND MUSIC MUSIC CAN BE GENERALLY ANY??)))..IF YOURFOR EXAMPLE CD" - HYPNOSIS AND HYPNOSIS" IS ALREADY THERE FOR YOUR VOICE...SO IF I CHARGE BACK MY VOICE NOT HURT?????
AND CAN I ASK YOU JUST A LOT OF POSITIVE AFFIRMATIONS TO SAY...OR NEED ONE FORGENIE REPEATED![]()
The brain quickly gets used to the monotony (and begin to ignore), so the more varied intonation, the better. One goal, and affirmations for that purpose can be countless.
АЛЕКСАНДРРРР
Hello,Andrey! I want to ask You a question. I have a CD of Alexander sviâša with affirmations that subconsciously instigated with the help of special technologies. The theme of this disk is extremely important to me,so having innerpulse and read the forum the question arose - is it possible this drive to listen to in conjunction with the machine? With L03,for example? This session is used for hypnosis and self-hypnosis,but if it is compatible with subliminal suggestion? Not will do too? On the CD the sounds of nature ,the affirmation cannot be heard. Sviâša writes that listening to every day for 40 days. Or maybe just use the disk that-niud r sessions? The drive already has some wave rasstaralsya. Not perior whether to impose the wave is and wave machines? Maybe they are not the same? I apologize for my ignorance in this matter,but I think if you connect the drive with the machine will be more efficient,but since I am a complete ignoramus in matters of any waves, etc., have to ask You this question
In advance of olsha Spazio for the answer
АЛЕКСАНДРРРР
DETAIL as POSSIBLE ONE GOAL AND AFFIRMATION...Ie DEVELOP ONLY ONE QUALITY or WHAT?Андрей Патрушев wrote:Is not hurt. Did not understand only - what's the frequency 4Гц?АЛЕКСАНДРРРР wrote:KU KUANDREW
POSSIBLE EXAMPLE???
ANOTHER QUESTION IN DOBAVLENIE BINAURAL BEATS, THE PROGRAM ASKS TO PUT CASTATU...THE DEFAULT IS 8 HZ AND WHICH IS BETTER????? AND ABOUT THE VOICE EVEN MIX YOUR VOICE AND MUSIC I NEED TO HEAR YOUR VOICE OR IS IT NOT IMPORTANT??????????????????THE VOICE SHOULD BE BARELY AUDIBLE????
With this disk session should not mix.Anonymous wrote:hi Andrea! I want to ask You a question. I have a CD of Alexander sviâša with affirmations that subconsciously instigated with the help of special technologies. The theme of this disk is extremely important to me,so having innerpulse and read the forum the question arose - is it possible this drive to listen to in conjunction with the machine? With L03,for example? This session is used for hypnosis and self-hypnosis,but if it is compatible with subliminal suggestion? Not will do too? On the CD the sounds of nature ,the affirmation cannot be heard. Sviâša writes that listening to every day for 40 days. Or maybe just use the disk that-niud r sessions? The drive already has some wave rasstaralsya. Not perior whether to impose the wave is and wave machines? Maybe they are not the same? I apologize for my ignorance in this matter,but I think if you connect the drive with the machine will be more efficient,but since I am a complete ignoramus in matters of any waves, etc., have to ask You this questionIn advance of olsha Spazio for the answer
АЛЕКСАНДРРРР
АЛЕКСАНДРРРР wrote:DETAIL as POSSIBLE ONE GOAL AND AFFIRMATION...Ie DEVELOP ONLY ONE QUALITY or WHAT?Андрей Патрушев wrote:Is not hurt. Did not understand only - what's the frequency 4Гц?АЛЕКСАНДРРРР wrote:KU KUANDREW
The brain quickly gets used to the monotony (and begin to ignore), so the more varied intonation, the better. One goal, and affirmations for that purpose can be countless.![]()
POSSIBLE EXAMPLE???![]()
ANDREI PATRUSHEV
Алексей Кузнецов
- Been thanked: 1 time
Yesterday, the 26th continued to read "the Living brain" grey Walter. He has a sample of EEG alpha rhythms and in the middle of the chart rhythms with open eyes. The figure clearly shows that the amplitude of alpha rhythms with eyes closed twice the amplitude at the open. Tonight while listening to "Star wanderer", when the hint of some unpleasant events (as I assume) the brain momentarily opened her eyes and immediately closed. It happened against my will. So it was two times. Andrew, what would these opening and closing could mean?
АЛЕКСАНДРРРР
KU KU
ANDREW
)))I HEARD A RECORDING OF AFFIRMATIONS WITH MUSIC
THE PLAYBACK SPEED OF AFFIRMATIONS REDUCE 10 TIMES
THE VOICE BECOMES STRETCHED
THIS MUST BE DONE OR BEZRAZNITSY))))AND HOW MANY TIMES TO DECREASE THE SPEED??
YOU HAVEN'T ANSWERED MY QUESTION, HE JUST AT THE TOP
THANKS FOR THE EARLY
Strange thing today when listening Star wanderer on the third track I realized that hear a new very high-frequency sounds in the right ear. Decided to check the program sound generator "NCH Swift Sound" your hearing range immediately after listening to This.Str. The sound in the extreme ranges at full volume did.
The left ear of 20.4 Hz 17КГц
Right ear 27Гц is 19.6 KHZ.
How could this happen?
Or I thought?
Or I thought?
Гостья
Dear Andrew,
I am very interested in the theme of Your forum. Trying to help myself.
I have several times asked You questions regarding Your disks,which You kindly answered.
I have a history of trauma of the spine,herniated disc,sciatica Ypres., and a displacement and fracture of the coccyx. Somehow my spinal injury was transformed into cystic adhesive arachnoiditis of the brain with multiple cysts in the white matter and large cysts in the temporal departments. Maybe I moved something like encephalomeningitis, but it was difficult to independently identify many symptoms that I encountered after the injury. Do You have data on patients with such problems, which has had a healing effect Your CDs ? Is it possible to influence purposefully on the temporal area ? The Massage of the brain, as You write,affect the frontal lobes, may be for the temporal lobes something You have ? Maybe you can contact someone from patients with similar problems ?
I asked You a question about the effect of "Healing" through the application of headphones to the affected areas (similar to Montagu). Can anyone help me the attachment of headphones, e.g. a hernia ?
Are You familiar with the technique of Santorini (electrostimulation of certain areas of the brain) ? I'd love to hear Your opinion about it.
Sorry for the big number question. They are caused not by curiosity, but an attempt to change something in my life. "Experience" of my injury - more than 20 years.
Can I write You a personal letter ?
Thank you.
Tatiana
Thank you.
Tatiana
Re: advice
Hello, Marina.МUZUNGU wrote:Hello Andrew.
Currently going through treatment for hepatitis C, very hard all this tolerated, constant headaches, nausea, the day completely lost, not able to sleep at night.
I would like to know if I can help Your drives, and if so, which one.
Sincerely, Marina.
This drives the healing and the Conductor.
