Structured water
Re: Structured water
Post by Михаил_ » Thu Jan 19, 2012 12:09
by the way, given the fact that "frost" in the usual sense of the word for this year, our latitude, and that date came (and they are directly related to the change in the structure of water in this), then process this year was weaker than usual
Белый Камень
Post by Белый Камень » Thu Jan 19, 2012 12:39
We have approximately d n -25 -35 is not the first day is already, well, it's probably a bit warmer than usual.
Post by Михаил_ » Thu Jan 19, 2012 21:09
here, much warmer than usual (near MO I'm temporarily), the relatives went to take a dip at night, say water with the smell, although usually well understood - such ideal type. i.e. the algorithm is not fully fulfilled because of restructuring the world's energy.
Константин.
Been thanked: 2 times
Post by Константин. » Fri Jan 20, 2012 12:36
add: I'm drinking water carried with river and mountain. The perfect taste, no odor.
So on the morning of the 19th I drank as before and it is not tasty and what it smelled like.
I am not, clearly something went wrong! :)
Post by Михаил_ » Fri Jan 20, 2012 12:56
water prescribed extraneous infa associated rearrange the energy of the world - well, relatively speaking "bounce" was recorded.
I suggested such a scenario for this year, but I think that version of "extreme cold" and a stronger than usual water is more likely.
most likely it is including means that the rest energy of mono-strongest day of the year will also be different from the usual going through the process.
Друид
Been thanked: 3 times
Post by Друид » Sat Jan 21, 2012 11:43
Also noticed that this time water is not available. Arrived at the spring as usual to type water. Look at her and not feel anything, tried it, also not impressed. At first I thought that we came at the wrong time. And then read this thread and realized what happened.
Константин.
Post by Константин. » Sat Jan 21, 2012 18:58
Today the conversation came up interesting information with regards to over-all health through water.
Told this recipe in 1978, the man who was responsible for the health of astronauts.
The fact that the astronauts own medicine different from conventional is I think many people know.
Recipe that never hurt. using the power of the earth. (literally)
Poured into a bath of boiling water, full. throw a tablespoon of chamomile pharmacy. that would be in the boiling water brewed.
Before the water has cooled to such that is not possible, but it is still possible to climb very slowly.(actually judging by themselves 41-42 Celsius you can climb.). So that spoon heated by a lighter sugar, and after it in a spoon on fire.
burning sugar drip into the water drop by drop. All! Water cooked.
We climb in and lie on the health.(seems to me that in the water I'm 5 minutes in a rush and want out)
Those who tried it, says that after such water only b & b half an hour or what.
So here is a recipe we learned today from space ' 78.
Димас
Сотрудник mindmachine.ru
Post by Димас » Sat Jan 21, 2012 19:11
Constantine.
Hmm..and how in just as water boil?..and bring it to the bathroom! 8)
Post by ЗОМБИ » Sat Jan 21, 2012 19:40
demAs
use the boiler
Constantine.
try mixing a teaspoon of pine oil with two or three tablespoons of any shampoo and severely beat in a bottle (from under the same fir.oil), make the water 41-42, pour oil shampoo in the water and in the tub
I was vylizyval 15-20 minutes max... and then still have to gradually get up to pee..nutsya to faint... it is desirable to be able to play with pressure through respiratory manipulation (well, there is force the smoke out through pursed lips, etc.)... also worth noting is "pleasant" tingling all sorts of places fir oil... the motor is really strained.
"on the bed" only because the temperature of the water is obtained
for chamomile and sugar can not say anything :)
Константин.
Post by Константин. » Sat Jan 21, 2012 20:08
Dimas, boiling water was meant from the tap, there are more than 42. At least told sources that simply boiling water from the tap poured then.
Zombies, fir mean essential? tried tingling, but then on the bed I did not pull much.
I can say that it is not in the boiling water. that is not from him on the bed:)
I have at hand four different hot source, natural. The pools are poured and cooled to 42-45.
Somehow it was possible to climb. from the ground they are about 78.
So each source completely different water and substance and impact.
the only one I want in bed.
From other otherwise.
Hot probably need to remove the structure, and the sugar as it is then in its structures, because once in the water instantly melted kristallizuetsya.
Post by ЗОМБИ » Sat Jan 21, 2012 20:35
Константин. wrote:fir mean essential?
yeah,... essential meaning of mixing and whipping with the shampoo-to make as the smaller the dispersion, the mixture (so it is called I think)
Димас
Post by Димас » Sat Jan 21, 2012 21:28
Today I received rusalochku:
Esoteric encyclopedia of Water,carrying the energy of the 'Hado'
Know him ,of course, not all, but many .
Masaru Emoto is a pretty popular person on the planet who have proven their scientific studies that water has the ability to change its structure is not only influenced by physical factors , but ,more important, under psycho-emotional impact. For example , water ,a charged positive vibrations "Hado" capable of carrying a person healing. The term "Hado", which he introduced in his book ,which became an international bestseller ,a single mean vibrational frequency, the underlying of all things .
Made Emoto pictures of water crystals , which received the impact of different sound sources ( music,human voice, emotion) surprise and reaffirm the fact is accepted by many serious scientists that water has the property to preserve and pass on information.
After the earthquake , tsunami and disaster at Fukushima,when Eastern Japan faced a serious threat of infection by radiation , a charity mission through Masaru Emoto was transferred to several dozen trucks with water ,structured on the technology MRET - technology molecular resonance effect. According to many years of international research , the use of such water stops the growth of cancer cells and boosts immunity. Charity event from the Thailand manufacturer in excess of 30 million yen was a huge response of gratitude and encouragement among the Japanese people.
He Masaru Emoto ,examining this water with the method of magnetic resonance and by making the crystal of this water , called her , translating from Japanese, of the Angel .The beauty of its crystal structures are comparable with the images of the crystal key, the Antarctic or natural waters.
With much gratitude to its inventor Igor Smirnov (USA) ,he called it the best water carrier "Hado". At the time this technology was developed and patented in connection with the need to find a radical remedy for the victims of the Chernobyl disaster.
And a reference as to the MRET water
http://vivalife.co.il/index.php?option= ... Itemid=131
The process of activating this technology (Molecular Resonance Effect Technology MRET) changes the structure of water and other liquids, creating from water molecules a sustainable dynamic multi-layer structure similar to the structures of cell water in living organisms.
In the process of activation the water is subjected to weak low frequency electromagnetic fields (nano fields), comparable to the geomagnetic field of the Earth in the areas around healing water springs.
These fields are generated by unique MRET-a polymer having a fractal structure, comparable in its properties with the structures of living tissues.
As a result , under the influence of nano-fields in the water created structures similar to the cell water of the human body. Physical properties of water change. Such water activated effect of molecular resonance ,penetrating into the cells , supports and transmits the information to the complex mechanism thinnest biochemical reactions in the body. Because it is fully compatible with the cell liquid, it is readily absorbed into living tissues, improving hydrated. cells .
It is a biologically safe process, because activated water is made in a contactless manner from drinking water and remains chemically pure and non-toxic."
About how! 8)
has anyone seen this?<
Димас
Post by Димас » Sun Jan 22, 2012 20:02
What, no one has tried this water? :oops:
here it pleased " American scientistDr. Igor Smirnov developed the "Technology effect of molecular resonance", and on its basis created and patented in the United States "System of activation of water and liquid substances" (patent N6022479). http://patft.uspto.gov "
:lol:
Sounds like an outstanding Russian scientist, Professor Ochirbat Badamtala :wink:
Белый Камень
Post by Белый Камень » Sun Jan 22, 2012 21:10
Local names in America only the Indians and Eskimos))
Димас
Post by Димас » Sun Jan 22, 2012 21:49
White Stone
Yes it is clear, just sounds funny:)
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Mon Jan 23, 2012 2:10
Found my old notes from the seminar held In N. Bogdanovich.There is another recipe. Ash bath to raise the tone.3 tablespoons of wood ash (wood clean)+ 2 tablespoons of salt ,pour three liters of water in an enamel pot,bring to boil and cook on low огне20-30 minutes under the lid .Pour it in a bucket and add cold water to the temperature of 37 degrees ,to walk in it.And to hold 15 minutes, not more,so the pressure was always 37 degrees,you can pour boiling water. Then Pat dry your feet and wear cotton socks.Do it at night.To do it 3 days in a row, then 2 times a week for a month.Not more than 2-3 times a year.Ready solution can be used 3-4 times. Maybe a bit to pozabite ,legs burning. It is better to do the APR,October,but not forbidden, and in other months.Employ channel :kidney,bladder,liver,spleen,small intestine(immunity)Course is brought to the end necessarily.
Post by ЛИЛИЯ-Р » Mon Jan 23, 2012 2:12
ЗОМБИ wrote:yeah,... essential meaning of mixing and whipping with the shampoo-to make as the smaller the dispersion, the mixture (so it is called I think)
Some of the oils and their mixtures wrong sometimes long the chill lasts.However how never get to read.
Терве
Has thanked: 72 times
Been thanked: 22 times
Post by Терве » Mon Jan 30, 2012 3:58
Good evening,
I have a question for the experts:
If you purchase a device that produces a "live" water with a high negative ORP (e.g., BSL, Emerald or something else) - this will replace Microhydrin? It seems here on the forum had mentioned how good Microhydrin to obtain a negative ORP.
(For example, a quote from one site: "One capsule of Microhydrin in a glass of water, milk, or other beverage, changes its ORP of +300 mV to -500 mV and more, significantly more, than fresh made carrot juice (-70 mV).")
In the Microhydrin there is still some benefit in addition to that which can be obtained using these devices?
Thank you.
Post by Михаил_ » Mon Jan 30, 2012 12:58
Microhydrin is clearly worse - use it the one that you can throw in anything, quickly and on the road.
Терве
Post by Терве » Mon Jan 30, 2012 17:14
Thank you!
Post by ЗОМБИ » Sun Feb 05, 2012 16:02
Димас
Post by Димас » Wed Feb 08, 2012 14:01
Post by ЗОМБИ » Wed Feb 08, 2012 14:21
demAs
like ionizer with platinized electrodes, in burgonde only such and enjoy
Димас
Post by Димас » Wed Feb 08, 2012 20:47
ZOMBIE
Interested to try the water after this unit..
Искатель-2
Post by Искатель-2 » Sun Feb 19, 2012 14:50
Hello people.
Added Emerald os from flask Asbaha. http://www.dina-aschbach.ru/kolba_ion_opis#q
The output was -340 GP. Input +240
also soon to be a prototype protochnika bath to -700 (i.e., nearly 1,000 Delta shift)
made a list of activators including Japanese Panas
join 8-)
http://iskateli.info/showthread.php?t=370&page=15
