Solar wind
Post by Андрей Патрушев » Wed Aug 04, 2010 16:48
Anonymous wrote:Good luck to You !
When proslushivanii Conductor, was vaginal, pulling middle fingers up, very distracted from listening, the impression I want to touch, do hands lie exactly on the bed, and from Drive C. V. move the toes as if playing the piano :) even the feeling of the pole in the back, as if aspili on the needle along the spine, (well, all the above description in the forum, the feeling was also, in one day, in another session, the session does not like). The feeling is very distinct, I wonder what that would mean?
I was told that there are ukloneniya in "green coridor" what does that mean?
And another question points(color) while listening to To put on white color, it gives red, blue, green, listening to the light changing constantly, it is my personal impression, or these color changing machine in accordance with the signal?
Better, of course, white. But subjective sensations of color strongly depend on frequency and duty cycle.
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Mon Oct 25, 2010 1:52
Мария2000 wrote:Going forward
Please tell us what Kundalini yoga different from regular yoga? all that you have listed in the regular Hatha yoga- what's the difference?
thank you
Maria
anything.there is no difference az
Post by Нетрезвый Сурдопереводчик » Mon Oct 25, 2010 1:58
but,again,I ,in the instructions,do not understand.in practice understand instructions-no :D
if Song of Chakramov="Healing"then,that's why,from native "Healing" sleep like a log from a song by L. van Beethoven and "Songs Chakramov" I have a feeling that I swallowed a battery from Gelenvagen? or two battery... :lol:
Наоко
Post by Наоко » Tue Nov 30, 2010 16:34
Hello.
I would like to clarify a bit. All the above written is not mastered...a lot of beeches.
When the listening solar wind, I was faced with the activation of all the chakras, but not concentrating on them. But as I do it a second time(second day). Yesterday the feeling was quite different. Worried about the cold fire that flowed through the body. Do cold flame. Is that bad? Okay? or what I'm doing wrong.
Plus, I slept on the cat at this point.
Post by Dimas » Tue Nov 30, 2010 16:51
Naoko
I also felt the ice in the coccyx,I think it's normal,everyone's different.
Наоко
Post by Наоко » Tue Nov 30, 2010 16:59
Dimas wrote:Naoko
I felt the whole flow through all the chakras like a little stream. A feeling of icy cold
Post by Андрей Патрушев » Tue Nov 30, 2010 18:40
Нетрезвый Сурдопереводчик wrote:but,again,I ,in the instructions,do not understand.in practice understand instructions-no :D
In the Song Chakramov much more powerful in the higher frequencies that are exciting to the brain. The Healing power of these frequencies is lowered.
Post by Андрей Патрушев » Tue Nov 30, 2010 18:43
Наоко wrote:Hello.
Hello.
Some perceive it as warmth, others (especially, for some reason, those who are engaged in Tantra, but not necessarily), how cold. But the ultimate effect of these sensations does not.
Кнопка
a question about usage
Post by Кнопка » Fri Dec 24, 2010 4:20
Hello dear friends. I have a question about usage of "solar wind". I worked with a conductor, but for a long time a year ago or more. I think that with the alpha I have no problems, regularly meditating for many years. Expect today to begin your "wind" mode 15-15-15. Was very badly bruised spine but a long time ago, 5 years ago. Can that will advise? I read all the forums on the subject, and would still like to hear a competent opinion on my case.
Post by Dimas » Fri Dec 24, 2010 12:34
Button
What advice You want to hear?
Кнопка
Post by Кнопка » Sat Dec 25, 2010 0:52
I do not know. :?
Today before class. No side effects yet, except that cold symptoms eased. To listen to suffered terribly, as much as a week.
Василий_V
Post by Василий_V » Sun Mar 20, 2011 19:39
The strange thing that stopped the session to act as before I was. Before the first track and immediately soothed into sleep pulled, and now the silence....
And theta session with other CDs as it is not touching, what can be the matter?
Post by Андрей Патрушев » Mon Mar 21, 2011 0:09
Василий_V wrote:the Strange thing that stopped the session to act as before I was. Before the first track and immediately soothed into sleep pulled, and now the silence....
Adaptation... :? Need a break or change modalities.
Иррина
Post by Иррина » Wed Jun 15, 2011 10:14
Hello :) Prompt, pozh-hundred where to find "Chabrowy vocalization". Searched - not found, and I want to see :oops:
Нак_Нак
Post by Нак_Нак » Mon Jul 25, 2011 17:05
By the way I haven't been able to find.
Ларин Иван
Post by Ларин Иван » Mon Jul 25, 2011 18:44
Here were found when using search
http://www.kornilov-s-a.ru/arc/m089.htm
On the disk of the solar wind - Chabrowy Vocalise
Earlier in this ezine were written on the disk Andrey Patrushev the solar wind. Recently there was a series of publications about it in the newsletter "About meditation." Author Andrei Patrushev has sent an interesting message about another opportunity which appears at the person when you work with this compact disc(Chabrowy vocalization). This drive the solar wind can be used not only to monitor the chakras of the human body but also for real and is very effective in cases of diseases with the help of Cukrowego Vocalise.
. Below is the text from the letter of Andrey Patrushev on the disk of the solar wind
Chabrowy vocalization:
Can anyone, absolutely not familiar with the chakras, to obtain real benefits from working with the disk of the solar wind ? In order to minimize emotions while listening (just no time) and
to increase (or to make specific and clear) positive effect, I suggest You to do "Acrovyn Vocalize". This method (authoring), my wife still gave only at seminars. We jokingly called "technique FAQ", by analogy with the research Institute of the FAQ (of witchcraft and wizardry) by the Strugatsky brothers from the book "Monday begins on Saturday).
The method is very simple. The result is the General improvement and development of beautiful, sonorous, powerful voice. When it starts pure tone, you have to adjust in unison with his voice and propagate any vowel, for example, "AAAA" or "oooo", or something in between (what is easier). When You get into resonance with the main tone, the voice begins to sound freely, strongly and flows easily as if by itself, and there is a pleasant feeling throughout the body. When there are other (coupled) sounds, give yourself a break. When he begins to sound just a pure tone, continue vocalizing, only this time with a closed mouth.
Again conformed in unison, singing the sound "MMMMMM", imagining that from the back of the sky forms a dome. Similarly, it is necessary to catch the feeling of resonance when there is pleasure, a voice flows as if by itself. Then starts to sound a different tone and You again start to adapt to it with an open mouth, singing a vowel, and so on... be Sure to drink a glass of pure plain water before class and
immediately after it. And in any case do not engage with only one tone (one chakra). After three or four sessions You will be able to remedy. In the presence of any pain - choose tone, resonant
with this area, and prophete his fifteen minutes (will feel when it's enough), all the while trying to stay in resonance (and resonance characteristics may change gradually). After three or four weeks of regular classes You will be able to help others effectively using this technique
Иррина
Re: solar wind
Post by Иррина » Wed Aug 24, 2011 22:03
Ivan Larin
Thank you :) Read - interesting. I'll try to do it can get :oops:
Влад Н.
Re: solar wind
Post by Влад Н. » Fri Oct 21, 2011 8:23
Andrei Patrushev, Hello!
What is the amps. I can't work with the drive more than 7 minutes. (already tested). When listening to any program for more than 10 minutes, there is nervous exhaustion (dry mouth, tension in the body, a little heartburn(lying on back)), a glass of water before and after does not help to overcome it. Goes on for 3-5 hours.
Can I listen to the program on this disc in 5 minutes?
Например1: morning 1 chakra 2 chakra 3 chakra in the morning, the evening of the 4th chakra, etc.
Например2: Song chromanol (15 minutes) divide into 3 parts. on the morning of the 1st part of the evening the 2nd part, 3rd part in the morning.
Thanks in advance for the answer!
Re: solar wind
Post by Андрей Патрушев » Fri Oct 21, 2011 9:35
Vlad N.
Yes, you can. But then it is better according to the scheme: 7-2-6-1-5-9-4-8-3-7
леша я
Re: solar wind
Post by леша я » Mon Oct 24, 2011 14:18
Andrey Vadimovich!
Did You measure the "cunning devices" in opinion (what a reaction) of the chakras or areas of body of a human in the pronunciation of vowel sounds/beeches of the Russian language(or another language). If there is an interesting relationship? I think if there is a dependency method "Chabrowy vocalism" will give more productive results.
Thank You for a very interesting and productive works. :ay
Re: solar wind
Post by Андрей Патрушев » Mon Oct 24, 2011 14:39
Alex I
No, they did not. :?
леша я
Re: solar wind
Post by леша я » Mon Oct 24, 2011 18:00
sorry.
Re: solar wind
Post by bofara » Sun Jan 15, 2012 21:24
Today, I first time felt the raising of the Kundalini, thanks to the CD "solar wind". bi
Andrei PatrushevThank you! :o
Has thanked: 5 times
Been thanked: 8 times
Re: solar wind
Post by Воффка » Tue Jun 19, 2012 22:58
Andrei Patrushev
Hello, Andrey! I apologize if this question has already sounded, but that's the thing. With this disc, the chakras don't feel so good, but that's not the point. And that prevents them well to feel the sudden sharp contraction of the muscles of the body, as a variant separately, lower body separately or the thorax, sometimes of the whole body at once. Here is how you should concentrate as an option on the lowest chakra, begin to exhale the energy in the anahata chakra it feels like all is well and then Bang! the sharp decline in the body and sensations are interrupted. This happens as the lower chakras and upper. For example, when the "breath" of energy from Sahasrara on the tongue can feet jerk and this is a common phenomenon, it bothers me. What to do? Just continue in the same spirit, or have any recommendations? What is it?
Before the session put (record in notebook) purpose the same as on the conductor, alternating with the conductor through the day.
Re: solar wind
Post by Андрей Патрушев » Wed Jun 20, 2012 0:14
Voffka
Just focus on relaxing (until you stop pull).
