Michael_On the website in the description of the broadcast in the section "modifiers on broadcast mode" it says: "Modes 5 and 6 can be combined with 2-3-4, but it is not recommended to do that." Please explain why You do not recommend? What can happen?
Re: Stream. The basic features and rates.
overload You may occur.
In the women's team is often without broadcasts and BJ as the fact that the woman is better looking (or trying to look better), working in the women's team, but not in men. Well here purely female psychology. And jokes about the serpentarium is not the invention ofМихаил_ wrote:I watched the other situation when female part of the team do not respond adequately to women with too strong energy
And Michael is right about to add a feminine touch... Stressed business women with bright appearance with colleagues in the men's team "dangerous to life".
If you connect the PC+ with modifiers 1,2,3,4 in case of overload?!Михаил_ wrote:overloading You may occur.
well, maybe not so will be, many connected 123456
And so I took the advice of Michael and hooked what he advised. I went to cleaning. I am very hot just in shorts and t-shirt. Ill lower back, I'm a little down on the weekend to straighten really could not. Well, snot, where do without them right lumps. Just slightly altered state of consciousness. Here is a cheerful start.
Let me another question about the "normalization of male urinary-genital areas" - is there an approximate time frame (min./max.) when will the "expected result"? It is clear that all individually, that's why I ask about the "frame".. Just now I have again a shortage of funds and had not "add to" and to replace the Panacea+FRM+1 more slot to take)
интересующийсябж
- Been thanked: 1 time
Hello,
The question on the effects of the broadcasting PC and the physical 2.2 and 2.6 - itself recently I have noticed a certain change of good stability in the direction of randomness, and this is manifested spontaneously and I realize it is already late. Under the randomness I mean the increasing speed of events, the emergence of "healthy excitement", and the increase in noise (i.e. something that can be explain in 10 words, I obyasnyayu 100). In the PC is a complete cure - can cause the subconscious mode 2.5 and 2.6 physical block (2.6 nikogda I wasn't tired and I really harmonious)?
Thanks in advance.
Thanks in advance.
The increase in the rate of the flow of events, the emergence of "healthy excitement", increase noise and such can be a manifestation of increasing energy potential, the entropy (multiplicity) is (in my opinion and I think not only) a bit more.......
The subconscious mind may govern the action of Forces, building them the most balanced, useful (and Operator and the World) and in the optimal way, often much more efficiently than it can organize the consciousness of the individual Operator. Correction of previously accumulated deformations of the cocoon is quite energy-intensive work, so (especially noticeable on contrasts) may sometimes be felt no excess/stock - some temporal conditional "drawdown" (relative to the previous power burst), but in General "patching holes" subsequently significantly increases the potential. While some "bounce" in the surrounding of the Operator may be a few more to show, but not at the expense of amplification of randomness, and due to the increase of potential energy just became more energy, and reduce the deficit "slow process" went much faster now and is more noticeable due to the raking congestion.
Sincerely, MAG.no 〠
Sincerely, MAG.no 〠
some days effects... some don't know.... in your case, I guess, not fast, because linked to the overall behavior stronglyrel wrote:Let me another question about the "normalization of male urinary-genital areas" - is there an approximate time frame (min./max.) when will the "expected result"? It is clear that all individually, that's why I ask about the "frame".. Just now I have again a shortage of funds and had not "add to" and to replace the Panacea+FRM+1 more slot to take)
Panacea in the PC usually does not manifest itself in an active form.интересующийсябж wrote:Hello,
Thanks in advance.
But the influence on the buffer is possible and can be very diverse, including your ability variability of growing - need some conscious and proper purpose (not to be confused with the paths of fictitious imposed goals) and the management of its new features. Usually it's all very "attached" as the activation PC...
One person I've turned off URGENTLY usilenno version of this translation is too "destructive" effects started
Hello Michael,
I can already see a positive impact stream ”Kids calm” for my daughter. Today we had a situation in which her reaction was much more relaxed than before.
I want to ask you, what would you recommend to use for a 40-year-old woman can not get pregnant?
She's wearing БЖ1.0.
I also see the positive impact stream 2.2 on my 85 year old grandmother.
Thank you very much.
Michael_ please tell me how you can connect kids calm (and whether?). My twins are almost a year old already. The main problem at the moment is jealousy. If someone first gets food, the other is causing quite a strong reaction, until the tantrum. Besides the kids sleep in the bed with us and such incidents are repeated practically every night.
I idle 4 open slots, and apparently will long stand before I lumped on a PC+. I understand these slots cannot be used for kids, you need to buy two separate channels for each?
Thank you.
Thank you.
Oh, I get it))) but I have trouble not quite there with the "sexual" part (relatively*) fine (* if "norm" is considered the norm)) - the problem in "urine", or the ureters, or the bubble, or kidneys.. but I don't want to rely on refined hints (to miss something You dont have)) - trust broadcast, can "thinking" and my excessive..Михаил_ wrote:too "killer" effects
интересующийсябж
Thanks for the replies.
Regarding the excess or lack of energy - I have noticed 2 peculiarities:
- if the dream was very emotional, then sleep Wake up early and energetic.
- if during the day nothing exciting happened, then the dream usually not bright and sleep time regular.
Question regarding the buffer, a buffer is something between personal and external space. It turns out the subconscious mind pulls in external space (in this world) something that bends the stability and variability appears. How can I determine where the inner world and where the buffer is and why you need it the subconscious if you can pull out (materialize) directly from the personal world?
Thanks in advance.
Thanks in advance.
Please temporarily till Tuesday not to create new orders or modify existing broadcasts in connection with the commissioning of automation (so we were not torn between the two processes are transferred into the database).
Good afternoon, Michael. You can stream calming baby son, a student 23 years? There are psychological problems since childhood - a strong resentment, problems with endokrinnoj, completeness, is under the supervision of an endocrinologist, prescribed medication and diet, was badly disorganized. And which translation modes it can help ?
1. it is possible, but it would be better additionally a competent psychologist to him and his parents....
2. PC genome, a panacea (or at least 2.2)
Erlanthe question is not as simple as it seems at first sight. Need a complete description of the family, including grandparents and great-grandfathers and great-grandmothers, and what are the relationships between all. dedoe calm can relieve stress, but will not eliminate the cause. I think so.
Should not think so, everything is possible (although not mandatory, i.e., not guaranteed), I'm sorry that You have here is not the topic of the fry.
You made this post possible to cut the likelihood of resolution of the situation (programming people are able to influence the outcome) because of personal limitations of understanding the processes of translation and all processes in the world.
I understand that this will not eliminate the reasons, but I also understand that without the participation of the person no one will resolve this, if he does not want and does not understand this.
so we are talking about changing an existing situation, trend in the best way - to improve health, education, status, relationship.
of course a good psychologist can help, but if the son does not want to work with a psychologist, I can't get the power.
