AMB - a product which seems to be there :)
Re: AMB - product of which seems to be there :)
Post by Михаил_ » Thu May 07, 2015 3:50
Yes you can, you can, but no switches for the autopilot steers :)
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Fri May 08, 2015 14:27
Михаил_ wrote:Yes you can, you can, but no switches for the autopilot steers :)
Of course, the autopilot steers!
But I think the owners of the AMB need to know about this possibility. (A Panacea turns out very strong yesterday even removed one of the two bracelets).
Now even more clear, why such value (for example, if you count the power with a wide Panacea of the BH... I think even more will come out... in my opinion of course :) )
Post by Михаил_ » Mon May 11, 2015 23:49
Well, I kind of wrote about this possibility in the beginning... the Cost is not due to the power of a panacea but because of the complexity of the product and its kompleksnogo impact.
Эдуард
Has thanked: 4 times
Post by Эдуард » Mon Jun 08, 2015 23:23
Druid what is the bracelet "man of action"
throw off the link or write please - something in search not found
Post by Михаил_ » Tue Jun 09, 2015 20:56
Эдуард wrote:Druid what is the bracelet "man of action"
It is not clear what was going on, I think this is a figurative description concerned the actual SBA, although I could be wrong (without the quotes, do not clear the context of the phrase) .
Эдуард
Post by Эдуард » Wed Jun 10, 2015 17:21
АндрейКо wrote:andreyko
The more detail you can about strengthening digital paper versions.
How many sheets do you have?
as I understand it between sheets missed with epoxy or PVA.
there are links to the video?
Post by АндрейКо » Wed Jun 10, 2015 19:53
It was clearly not about AMB (I have one snake in the tree and one ebony) , and probably about a Panacea or a Cure-Youth.
If you do PVA from a great height takes a lot of time - more than a month for sure.
Faster just about a Cure-Youth - took German PVA (solid when frozen),
The cover, for example from 5 liter plastic cans, a thin layer of PVA, matrix, Panacea of Youth as a box that fit in the cap - drowned :) and while withers layer play a video Panacea-Youth, then the next layer through a day or two, and so is the cover to the top is filled.
In the cover layers 7 probably, and the Bank about a hundred. The feel of the artifacts with PVA and epoxy (much faster generated) differ.
Videos for AMB is unknown to me.
Video panacea-youth http://openmagic.org/molodost.wmv
You can of course between the sheets fluff PVA (so he did).
Post by Михаил_ » Wed Jun 10, 2015 20:29
videos for AMB I intend to put :) in the reasonable near future (end of month), as long they are made for a different technology, it can honestly be considered light :)
АМарта
Has thanked: 2 times
Been thanked: 2 times
Post by АМарта » Wed Jun 10, 2015 20:55
Michael,thank you!! :) :o
Андрей Ермаков
Has thanked: 3 times
Been thanked: 15 times
Post by Андрей Ермаков » Thu Jun 11, 2015 5:53
Interestingly, and AMB light sunglasses is possible to charge?
Petr99
Post by Petr99 » Thu Jun 11, 2015 14:25
I think that it will be possible to charge anything. Just to be different from selling SBA points as the specifics of AMB other, especially for the points made
Андрей Ермаков
Post by Андрей Ермаков » Thu Jun 11, 2015 14:51
I had a case, I was loading three sunglasses, loved. Really gone somewhere.
Эдуард
Post by Эдуард » Thu Jun 11, 2015 22:48
For AMB Lite has an alphabetic matrix?
found only digital
Michael_ wrote:
7,3,7,3,9,0,0,0,0,0,7,0,7,2,6,3,0,2,3,7,3,2,3,5,0,5,2,5,8,5,0,2,6,5,5,7,0,2,3,5,5,2,2,7,6,5,9,4,3,9,4,6,3,1,9,2,3,4,5,0,0,8,4,9,4,9,0,9,4,1,0,2,9,5,4,5,0,9,3,3,5,3,6,2,0,7,9,7,3,2,9,9,3,1,3,2,6,0,3,0,1,0,2,7,9,3,8,4,7,7,0,5,9,5,8,4,0,8,4,6,1,2,9,6,1,4,8,5,6,6,2,6,7,3,3,2,0,2,8,0,4,3,8,4,5,4,9,1,1,5,1,7,9,5,0,3,5,2,5,7,4,0,7,1,2,4,4,2,4,3,7,7,6,0,0,3,4,1,0,8,5,4,7,7,1,2,3,9,5,8,3,3,9,1,8,0,2,9,0,1,2,7,1,2,8,0,2,0,3,3,5,2,7,8,6,2,7,3,8,5,2,3,9,0,2,4,0,0,8,4,2,0,8,9,1,8,6,9,1,3,5,0,5,1,6,7,8,4,4,3,5,7,2,6,7,0,1,9,8,9,9,1,0,3,1,8,0,0,7,9,0,7,4,4,3,5,7,1,6,6,9,4,3,8,5,8,8,0,8,8,3,4,4,8,4,0,1,0,5,6,1,9,4,8,9,0,7,7,5,3,7,1,7,9,0,5,5,1,2,3,3,3,5,4,9,5,5,5,6,2,1,1,5,5,9,9,4,7,3,9,9,3,7,4,9,3,9,4,5,1,5,3,8,7,1,5,2,1,0,3,5,4,0,1,3,1,1,3,5,4,0,7,2,6,8,7,6,1,6,3,9,5,1,6,8,5,5,1,0,4,0,2,0,8,1,6,2,8,0,7,7,9,1,1,5,0,4,4,1,6,8,1,0,9,6,4,6,1,6,3,7,9,5,6,8,4,6,6,5,1,8,4,6,6,9,6,0,6,6,6,3,3,4,7,7,7,1,0,6,8,0,0,8,3,1,1,2,2,2,8,1,5,1,5,5,8,0,6,3,7,0,9,1,1,0,4,9,4,4,8,5,9,9,2,3,2,9,5,9,7,3,9,9,8,6,0,3,1,0,9,6,4,0,2,6,6,4,4,6,3,9,5,4,3,7,9,0,8,7,5,1,1,5,6,5,6,3,4,1,4,0,1,2,0,0,6,4,0,7,9,3,8,2,0,1,0,6,6,1,6,3,8,8,9,8,6,5,0,2,2,5,7,2,5,5,7,3,8,4,8,7,4,4,8,3,4,1,6,4,1,6,9,4,0,2,4,5,4,2,0,3,5,8,1,1,9,1,8,1,7,9,2,4,9,2,1,6,8,0,5,9,4,5,8,5,1,3,3,0,7,6,2,9,9,7,1,5,7,6,2,6,0,5,2,7,6,8,4,6,6,9,6,2,1,2,4,1,2,2,6,8,3,7,1,2,5,7,4,6,9,2,5,5,8,8,7,8,8,5,6,7,4,7,1,5,8,8,2,2,0,4,8,0,8,2,3,0,8,0,6,7,7,7,2,6,2,3,2,4,4,8,4,9,0,8,0,3,4,4,1,4,5,6,4,1,2,2,1,9,5,6,7,9,9,8,6,3,3,9,8,7,2,4,3,0,7,3,1,8,1,1,9,1,5,8,7,5,4,1,6,3,3,3,1,1,4,7,3,9,5,8,7,5,6,0,1,2,4,7,1,0,0,8,9,4,6,3,7,7,0,0,5,4,8,0,3,4,8,2,5,4,0,3,3,8,4,9,0,3,9,9,9,8,1,5,9,0,1,0,2,2,3,4,2,0,5,0,7,7,7,3,2,1,2,4,2,4,0,1,6,6,3,3,8,7,0,0,8,9,8,7,3,7,8,0,0,5,0,9,2,2,6,1,2,0,3,5,5,7,3,6,5,2,1,9,3,8,5,7,7,2,9,3,3,7,0,6,6,5,3,7,0,1,8,3,7,8,8,1,0,6,5,8,6,8,5,4,2,7,4,3,6,7,1,0,3,9,2,4,7,3,2,9,2,9,1,4,2,6,2,9,2,9,1,8,8,9,4,2,0,1,2,1,7,1,7,8,8,8,6,8,4,7,3,3,2,7,5,4,8,0,4,8,5,4,7,3,1,3,3,7,4,7,8,1,1,7,9,4,1,9,9,1,0,6,6,4,7,0,1,4,9,9,5,6,7,8,8,9,9,8,9,8,2,7,2,9,4,3,9,2,7,2,8,7,4,9,1,0,3,1,8,1,0,9,6,6,0,0,6,7,3,8,3,
if only this is what I understand the bracelet paper making from it:
the printout on the sheet to roll several times and secure with scatches on the commas?
or it is possible without degradation of its influence and in the pocket to wear?
as better?<
Бисо
Has thanked: 49 times
Been thanked: 38 times
Post by Бисо » Thu Jun 11, 2015 23:47
Hello Edward,
For AMB layt layt eats only the digital matrix.
On the wrist would be better. (IMHO)
Wait until the end of the month. Michael promised to post a video for AMB light. It will be much stronger than the digital matrix.
Андрей Ермаков
Post by Андрей Ермаков » Fri Jun 12, 2015 6:31
Yeah paper bracelet is very easy to do http://www.youtube.com/watch?v=Nb9nDB9UYgg. Also, it is possible to make from the storyboard video of AMB.
Post by Михаил_ » Fri Jun 12, 2015 22:54
Please understand - in the storyboard, a lot of frames and they are all important. Video AMB very much kadrikov :) take 20 or 100 of them will ...ERM... not... so what about AMB do not make a storyboard, it will not be true. There you can apply the whole video. Only.
Edward, AMB a very complex product. Complexity he sorazmerit with dozens of articles linked together. And there each in his place. Therefore, the activating matrix no. It is very difficult to do. To do this would be to connect at a certain level all these parts into a whole, and the SBA would lose its identity due to the formation of the core.
Therefore, matrix no.
Digital matrix this is not of AMB and some sketch test status of AMB, a very simplified version. But use is still possible/useful.
What I'll post is a basic video of the old "charger" (the word used here, charging purely conventional) system, they provide output of AMB, but it is not like the commercial product. Will be weaker, but fully functional.
Some funny people manage to test the bracelets to connect to packages and to seal in the tape and thus obtain the long-acting products :) I do not mind :) although they certainly are for quick testing and are not for annual socks ...
ДмитрийКО
Been thanked: 3 times
Post by ДмитрийКО » Sun Jun 14, 2015 22:02
A video storyboard is for download or where I missed :shock:
Post by Михаил_ » Mon Jun 15, 2015 4:32
I promised to post a video for the Lite version of AMB later, now there is no such technical possibility, it was about the end of June. I will let you on his forum and here about the fact that the video became available. Yet.
Эдуард
Post by Эдуард » Sun Jun 21, 2015 7:48
АндрейКо wrote:Drunk sign language Interpreter
You can then the bracelet in the light to charge and carry (wood costs 150 rubles from the force...)
I understand that you can wooden bracelet charge through video? if there is a link - please share
Эдуард
Post by Эдуард » Sun Jun 21, 2015 9:34
that is, if the neck crystal rhinestone - will be to destroy cocoon?
only temporarily for 5 minutes turns out to use it and remove?
Эдуард
Post by Эдуард » Sun Jun 21, 2015 10:24
did a couple of days ago 2 paper AMB - feeling nothing. but I am very sensitive to energies, you should do close to feel. No swing, no visible effects on the physics there. How will any situation be sure to write.
slept 6 hours woke up at 5 which is very happy, but I have the intention formulated to 5-6 hours of sleep, maybe it played a role.
usually more sleep.
if someone wants to obtain the result of wish-fulfillment, I recommend the theme of the subconscious in psihilogii= techniques=> the peat taxis. After the topic and by eliminating because of this reason - the goal is very quickly implemented, and with AMB think the speed will be fantastic, with proper formulation of the intention to achieve the goal.
you can make a theme - how to work with SBA and other products something like this topic.
the main thing for effective change in yourself, but this topic is not noticed on the forum, if you have one, you can link pliz.
Эдуард
Post by Эдуард » Sun Jun 21, 2015 21:12
just as long as no obvious changes or I have not registered by consciousness.
it's not that I do not write what is not satisfied.
it's two different things
Бисо
Post by Бисо » Sun Jun 21, 2015 23:00
Hello,
I decided to share my experience from the use of two bracelets AMB. I decided to do it now because a few days ago my friend, which also uses two bracelets, the SBA, and have shared with me their observations after 40 days of application. He has four bracelets AMB, but he began now to use the other two.
And seeing the lack of results from the application of AMB in some people, I decided to bring hope and optimism.
I use AMB from 18 February, is already 4 months.
I was surprised when I saw that our observations coincided by 80-90 percent.
He used homemade bracelets from the black hole, before AMB about a year. My experience with homemade bracelets from CHD to AMB about a year and a half.
I must say that we both worked with the disk A. Patrushev.
I have Svetlitsa Blaga, but somehow did not feel her work than other things.
He felt a surge of energy. I felt a surge of energy after the connection stream PC+, it happened two months after the acquisition of AMB.
He achieved the first results in the field of his activities - he said things went. I could say the same for myself. In the middle of last year I had an idea that I started working about a month after the acquisition of AMB. You can say that I had an inner confidence, or rather the knowledge that this should be done without thinking about the end result.
He began to think very positively. I have lost negative expectations, or rather, worries about the future. I started to feel very well here and now.
He began to forget very quickly the negative moments. I never had this problem.
He had the confidence in their own abilities. For me, this translates into inner peace and equanimity.
After the acquisition of AMB I felt and as 3.0.
Post by Михаил_ » Wed Jun 24, 2015 9:09
Эдуард wrote: that is, if the neck crystal rhinestone - will be to destroy cocoon?
Crystals have their own consciousness, operating on different principles and on other frequencies than the human. They are successfully used by many as some tools, and can be pressed down/muted if they are treated as just a medium of human mental shape, but if you just take the pure crystal, he, with a long stay in the cocoon turns a symbiotic human and known serious problems associated with it. For example, a large expensive diamonds many stories about the untimely deaths of their owners. In simple crystals such not to :) but in General, it turns out that the man is as it were disconnected from the world and begins to see everything through the prism of the crystal. It's a fun explanation, but it conveys the meaning. It always is a good thing - ? I don't know, I think that I am not aware of a case where well. So if I used crystals (such as Druze first and homemade stabilizers), then charged them as BJ, it partially solves the problem with unstructured entities (drosou, there would be a million minds crystals, or well a lot).
So, philosophical question, but WHY hang on the neck a rhinestone?
I do not presume to judge the products of other manufacturers, where the crystal is only a component because I do not know the production technology as a whole. Here in improvised SP or whatever they are "cakes" out that mental crystal not processed to avoid this problem. In other cases - don't know. Here's what just a "thought form" can not do nothing.
In some cases, probably charging a panacea can completely or partially solve the problem, but I'm personally very wary of any contact with the inorganic forms is artificially put into a personal box for a long time. There are good reasons that are beyond the scope of this discussion.
This does not mean that does not work, it means that I see the possible side effects for a prolonged period of time.<
Post by Михаил_ » Wed Jun 24, 2015 10:17
About AMB - homemade. Edward, sorry AMB light gives the setting to "drive" condition, but does not give a full AMB albeit in a weaker, home-made version. Before I opublikoval video, to create a Lite version, though plan to do so in the next few days, wait a bit.
As for the reviews about the AMB - naturally, as with any BJ, and indeed any similar products will not be 2 identical users. I have just returned from a 2 week trip in which had fellowship with a group of first users. Among them there is one very successful lady in which everything in life is good and stable, it is AMB and it feels like something "strong" in her words (she was asked about it by my friend and is since then), but it for a couple of years there have been no drastic changes, but she's not committed and don't particularly want them, so everything is OK. in fact, her SBA more like 2.9/panacea works at her own request.
And at the same time talked to another person who received the first AMB in the USA and he is actually in his words, "completely changed his life", then talked a lot more. There was a high willingness and desire to change.
I recommend:
1) not committed to the SBA if there is no desire to change. Not to be confused with the desire to obtain new things in life without any changes yourself.
2) although in case when there is no need and/or desire strongly to change yourself, the SBA, as a kind BJ, though far from classic 2.x/Panacea - is well suited.
3) do not strive at all for AMB and you can always start with the probe. Samples is available, if in a particular place no - ask, it's solved. The probe can be worn more than a day and get a serious and meaningful feedback to yourself and life from it. Probe obviously stronger than the light version.
4) and after all this, I always recommend first to understand whether AMB. Firstly there are plenty of other BJ, from which much can be done in a quite effective homemade products. The second AMB is the agent of change in itself. It is not a means of solving their problems without a change in yourself. From the point of view of the human subconscious, something that he perceives as problems, it often is because of human limits internally.
PS well after the publication of the video will be available more powerful and more full version than the Lite-Lite digital series, giving a greater understanding of what AMB, in fact, it can be used as a complete solution, just less power.<
