Small offtopic.
maverik
Re: Small off-topic.
Post by maverik » Fri Jun 28, 2013 0:47
Possible theses to the PM.
Thank you.
ВикторРусс
Post by ВикторРусс » Sat Jun 29, 2013 17:56
Twist chopper Rinat, in the first week attacked zhor,there is like a lot of everything,for 2nedeli ate, I decided to try to drink some water and Popo charged to others. the water from the matrix and has more obvious effects than just water. observed after administration in the morning and before posleobeda comfort in thoughts and a General tactile impression:her hands are heated and covered with spots, the heat is not felt, superficially feels like wearing a coat with fur inside. alkagolik neighbor drinking a Cup of sweated it out and said something strange the water,do I want to work ,he did not notice,perhaps so very active,working Tajiks also noted that after she also wants to work,so my subjective opinion drunk off of water be kind and sympathetic. the symptoms of too high dose resemble a mild poisoning of the organism with vegetable poison.
Анор
Post by Анор » Tue Jul 02, 2013 3:53
Victorysa couple of things:
How many rpm your turntable?
How long you have been daily in her presence?
How long to charge the water?
And too large a dose is how much?
Post by Михаил_ » Tue Jul 02, 2013 4:07
Can answer your last question, about the dose is very individual.
Анор
Post by Анор » Tue Jul 02, 2013 4:38
I.e. the better the health, the dose can be more?
Post by Михаил_ » Tue Jul 02, 2013 5:19
well, not health, and the General condition of the cocoon, including the energy and not the physical level, i.e. for pure body to the normal raw food diet think special restrictions no
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Tue Jul 02, 2013 6:44
Don't know whether it was to be felt with the wheel, but I have a spinner (wheel) at full speed (the engine from a server disk for 10 000, the regulator model aircraft like the helicopter, a bunch of CDs - 3 large and 2 small - server, the edges) worked initially without any aluminum rim, and then with him - never felt overweight. Last time when I included it, and was some time there, then felt his body povishennoy energy, but weakly, i.e. you had to be there for some time (15-20 minutes) to feel.
Melt water after charging, the feelings, the tastier it becomes - softer.
ВикторРусс
Post by ВикторРусс » Tue Jul 02, 2013 10:11
The chopper rotates at 12,000 Rev/min continuously,1диск at 95mm,the edge keenly sharpened,the clearance between rim and disc less than 0.5 mm, the “wheel“ gift of Michael underneath. the water in the mug, put directly on top of the rim, charged 10min, for me, half a glass is acceptable for half a day,then still possible, any load from work is not felt, during the day, turn to the mandala with thoughts different to give me support, on subjective sensations the contact is in the distance. the gasoline charge without rims but in the pan, without the mandala,1 hour minimum,and best of 3hours, short-term are next to no load is not asosau. continuing the idea of Michael for BioLink ,it is possible that the water enclosed in the vortex, too, like a link to the vortex on a physical level, well, after a while the body restructures and loses the link, from the water above all else, felt improved mood...
Анор
Post by Анор » Tue Jul 02, 2013 10:24
I hesitate to ask, but what is "wheel"?
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Tue Jul 02, 2013 10:45
Mandala "the Wheel" to manage (collection and distribution) flows from a variety of sources, a little earlier in this thread about it written.
Sincerely, MAG.no 〠
Андрей Ермаков
Post by Андрей Ермаков » Wed Jul 03, 2013 6:56
ВикторРусс wrote:Chopper rotates at 12,000 rpm constantly
A turntable with a magnet?
ВикторРусс
Post by ВикторРусс » Wed Jul 03, 2013 8:47
Turntable without magnet. I propose to introduce the imaginary unit, the efficiency of the fan, say at 10000 rpm per minute and current in the windings 1A with the 95mm drive, take the 1st power of turntables...based on this unit to recalculate the efficiency for a high-speed turntables, current is better to measure by the oscilloscope, with the same current value for different engines may have different speed and Vice versa with the same value of the current speed can be different on different engines
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Wed Jul 03, 2013 9:04
ВикторРусс wrote:Turntable without magnet. I propose to introduce the imaginary unit, the efficiency of the fan, say at 10000 rpm per minute and current in the windings 1A with the 95mm drive, take the 1st power of turntables...based on this unit to recalculate the efficiency for a high-speed turntables, current is better to measure by the oscilloscope, with the same current value for different engines may have different speed and Vice versa with the same value of the current speed can be different on different engines
So... this is where the operator plays a significant role. Ie roughly speaking, the same meter can work with varying effectiveness for different people.
I'm so in the example of this fan, which is flogging a dead horse... What with wheel, without wheel 19800 rpm with three sharpened with disks, the effect is not felt no. I thought that with her flowers will take longer to stand, but no...
Only one do not forget the effect, after a week robots with the balcony, when I turned it off the glass and the whole lining is tightened with frost and didn't thaw for two months...
Владер
Post by Владер » Wed Jul 03, 2013 9:34
Different turntables and different controllers to them, it is impossible to compare current. Can't even compare the power, although it's more than adequate. As it is very different from many factors (the optimum feed control pulses, the control method, the clearance between the puller and wheels, the clearance between the discs, the quality of the alignment, the presence of cover and the density of its fit, the material and thickness of the ring puller, number of disks and their form of sharpening, etc.)
Post by Михаил_ » Wed Jul 03, 2013 10:47
In addition to technical factors and the influence of the operator(really strong) will affect more the place of installation (much), time of year (not much but significant), the material and thickness of the disks (all different), the presence of a grinding region, the material remover. So no units can enter will not work :) in addition, the dependence on speed is clearly not linear.
And there are other factors about which I say nothing.
ВикторРусс
Post by ВикторРусс » Wed Jul 03, 2013 16:48
Михаил_ wrote:in addition to the technical factors and the influence of the operator(really strong) will affect more the place of installation (much), time of year (not much but significant), the material and thickness of the disks (all different), the presence of a grinding region, the material remover. So no units can enter will not work :) in addition, the dependence on speed is clearly not linear.
In my experience the "vitushishnikov" is the trend, the momentum to do as much as possible.. And it turns out the place is affected badly, and it is possible more in detail? Can be height from ground level? The presence or absence of some objects?
Post by Михаил_ » Wed Jul 03, 2013 17:00
the speed affect range, sensitive people set comfortable (although, despite what).
and about the place - well, it's all known information. Each seat has an individual power. So it's not the height of the objects and geo-features. Well you can, for example, Valerin movie to see, although in reality is more difficult of course, especially if not on the scale of large areas.
Yes this is all known information who have been in the subject, for example, any Tesla stuff for different work, the Joe cell, too, and so on. And understandable reasons. The high places, and objects nothing to do with.
Андрей Ермаков
Post by Андрей Ермаков » Thu Jul 04, 2013 22:12
Воффка wrote: Only one do not forget the effect, after a week robots with the balcony, when I turned it off the glass and the whole lining is tightened with frost and didn't thaw for two months...
I had the same case with the chopper. Ball helium charged and hung from the ceiling more than two months, even began to alert the guests :). These balls are usually a maximum of a week to live. Another turntable without magnet, removes bad memories, but with the duty to communicate with her disturbed sleep and is exacerbated by Chrono :) (chronic diseases).
Владер
Post by Владер » Fri Jul 05, 2013 6:50
Chrono is not exacerbated, and steps out of the shadows - the usual healing process.
Post by Михаил_ » Fri Jul 05, 2013 19:15
Yeah, that's about the ball is a typical example of VISIBLE growth of the quality parameter.
Post by Михаил_ » Fri Jul 05, 2013 19:16
Tactfully I want to note that, in General, all products of my line, too, they are actively engaged, only for the man himself. Well true and a lot of it useful.
We thought turntables to serialize including in the line uhh (in the sense amplifiers) but decided for several reasons that it is not so advisable for fumbling.
Анор
Post by Анор » Mon Jul 08, 2013 16:47
Андрей Ермаков wrote:I had the same case with the chopper. Ball helium charged and hung from the ceiling more than two months, even began to alert the guests . These balls are usually a maximum of a week to live.
The chopper improves the structure of the material. Even metal fatigue cures.
Анор
Post by Анор » Mon Jul 08, 2013 16:49
Michael_ your expert opinion (maybe not in this thread):
It is really possible in this way to obtain atomic gold?
Post by Михаил_ » Tue Jul 09, 2013 3:17
nonsense I think :) and very easy to check = to take water for spectrometric analysis.
ie theoretically of course, you can do anything about so to.... but practically .... here quality can rewrite.
Анор
Post by Анор » Tue Jul 09, 2013 4:32
removed
