Planned changes in the commodity row of the entire line BJ-SK, etc.
Re: proposed changes in trademark row the entire line BJ-SK
Post by Михаил_ » Tue Sep 24, 2013 4:39
at remnants cards transfer 2.0 and 2.1 are announced sale - 30% off when you purchase any pair of cards. The number of cards is limited!
Post by Михаил_ » Tue Sep 24, 2013 4:40
be removed from production исн1-исн2-исн3... but not yet :) but not for very long....
Багвати
Post by Багвати » Tue Sep 24, 2013 14:58
And when, when, when, Misha, you make me 3.1? :)
Post by Михаил_ » Tue Sep 24, 2013 15:17
.... :oops: .....
the fact is that technologically they can (should) do from 20 pieces, otherwise wasted time, (well, I this is simplistic of course, but the process 20 is the same as process 2, except finish work and some other things.
And I have unfortunately still have some old not completed the process that began earlier, your order 3.1 :)
But 3.1 has already entered the first stage of production, so I guess I should say "relatively soon" :) I'm sorry.
Багвати
Post by Багвати » Tue Sep 24, 2013 15:32
Thanks for the reply, Mich, as-is :) nothing that I do not understand why this is my old 3.1 from the bracelet came off and decided to run away from me :wiz
Хастред
Post by Хастред » Tue Sep 24, 2013 18:25
Михаил_ wrote: by the way, I want to note that the new 2.6 very interesting (it is quite different, as well, and all 2.x in broadcast mode). We can say that it is a lot more powerful in his manifestation of qualities.
And will change/improve as the old 2.6 was improved 2.1 to 2.2, or such other version will be available only in the broadcast? Or does the capacity of the product is understood as the speed of developments the quality and the end result is the same?
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Tue Sep 24, 2013 20:10
and something will come to replace the ink cartridges V?
and in the new modulator will use cartridges?
Post by Михаил_ » Tue Sep 24, 2013 23:34
димыч wrote:and something will come to replace the ink cartridges V?
let's wait and see... so far nothing.
Post by Михаил_ » Tue Sep 24, 2013 23:40
what do we mean?
2.6 will be released without changes, the new version is only available in the broadcast, while technology is not to change the production process to the new 2.6 version and not sure if something will change.
СтАвР
Post by СтАвР » Wed Sep 25, 2013 10:04
Михаил_ wrote:- and products "normalization of sexual energy"
here the question arose, with this card, or stream, in General, it is not, need further work? if so, what practices to apply :)
of course you can, as always, to trust my instincts :?
Post by Михаил_ » Wed Sep 25, 2013 12:32
no, there is no need to work, she creates the trend in the leaching of different units and krivosta in the cocoon, and the energy sector, since many of the most traumatized part of the society and, simultaneously, a Foundation to build cocoon with the bass range, a good tool for self-healing in General, and to change the perception of the transition to internal motivation.
СтАвР
Post by СтАвР » Wed Sep 25, 2013 16:57
Thank you :)
Post by Михаил_ » Tue Oct 01, 2013 4:42
card transfer 2_2 finally arrived in the place of their sales.... :)
Карта переноса 2.2
Хастред
Post by Хастред » Mon Oct 07, 2013 17:36
And the cover matrix which blocked the spontaneous transfer from the card to the object, this kartochku works too?
Post by Михаил_ » Mon Oct 07, 2013 18:29
well if You want it for complacency, then Yes, it works... and so do fine without her.
Post by Михаил_ » Fri Oct 11, 2013 16:39
having technical ability to handle products of the customer converting them to any version without sending it to the office (and even without sending it anywhere). Pricing and other policies on this subject have not yet been developed.
Quality .... a few steeper serial products.
Легенда
Been thanked: 9 times
Post by Легенда » Fri Oct 11, 2013 23:10
I suppose that this stream of the subject. Too unique and universal turned out stream )))
Post by Михаил_ » Fri Oct 11, 2013 23:29
in General - Yes, that's right.... although in General I would like to know :) :) :)
ie more likely than not, but no and no and no :)
but seriously - some of the concepts are similar, and some are excellent.
Trudoemkost slightly higher (about 20 how to configure broadcasts).
uses special conditions (punctured space is created in which is placed the charging facility).
But the mechanism of transmission is similar.
To translate this technology for primary production - will not.
Otherwise it will be too dependent on me, although the effects will grow.
Specially made 2 batch 2.2, for personal comparison. The differences are immediately noticeable (in favor of the new method).
Really used it internally .... is not familiar to me material in a meaningful way with the tendency to increase volume.
Here by the way interesting high "selectivity" - i.e., additional items, how many of them do not put in special space or similar objects (e.g. from the same batch) and other similarity did not fall under "process".
For example, I took out a special space that one, threw in something else, and charging system to change forgotten - nothing got corrupted :) because be passed on continues, the item described and no other.
Positive features - this technology can do something on the media of the customer, but because of high labor cost it makes sense only for high-end products. (the fee is not invented, but a low it will not).
Ie you can make an analogue of 3.0 S++ no meteor and engraving, Nariman bracelet women's hours and the effects will be stronger than on top of the product line. (well, just as an example).
Thus there is a unique opportunity to get rid of the kind of serial products completely... however, there is also some thing - to start the process you need to describe an object that requires manual intervention to me, and with a significant investment of time, and it is absolutely not interesting to me employment, so the final price tag for the service probably will not be small.
Anyway, I brought it to your attention that this is possible, the rest will be determined later.<
Post by Михаил_ » Sat Oct 12, 2013 15:51
appeared in the office probes (paper) wristbands 2.2
Ольга К
Сотрудник mindmachine.ru
Been thanked: 17 times
Post by Ольга К » Fri Oct 18, 2013 14:36
Михаил_ wrote:for a long time That discounts were not :) in connection with the renewal of the series Ah
declared a clearance sale old type
travel
keys and doors
road
humanity (as far as I know has ended but apparently there are a couple of pieces in the "Artifacts")
at the reduced price of -50%
until the completion of the inventory (there is 1-2 pieces of each type).
in General, the relevance of these products did not become less - so catch the moment....
The remains of the old versions..
price 1950 RUB.
AK "Keys and Doors" (label) - 3 PCs
AR "Companions"(label) - 7 PCs
Рандориан
Post by Рандориан » Sun Oct 20, 2013 14:39
Good afternoon, I wanted to clarify and "Roads" already left?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Mon Oct 21, 2013 1:13
Рандориан wrote:Good afternoon, I wanted to clarify and "Roads" already left?
Roads only in the new version, discount is already over.
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Mon Nov 04, 2013 21:32
Михаил_ wrote:yeah, it is very likely points would be interesting to add insoles with similar properties, that is to say for the symmetry (the channels of the legs are connected to ground and typically do not work well due to the use of shoes and asphalt-floor buildings instead of raw earth).
Insoles are...interesting. :)
Post by Михаил_ » Mon Nov 04, 2013 21:45
well, now it is not planned... yet....
Шломо
Been thanked: 3 times
Post by Шломо » Tue Dec 03, 2013 15:02
Михаил_ wrote:well, in General you need to think whether... and then I just recently accidentally dug up a few blocks to hell knows when the set is quite hard and not very deliberately :) I mean at home, on the unconditional response. Already ofigel. Apparently once thought you had, but I think it was a curve, a simplified measure.
and how can I look for at the junk blocks?
thank you.
